Old 06-10-2014, 11:14 PM   #1919
kincito
Drives: Raven FRS
Anyone else been getting a CEL p0420? That's the code I have since changing the exhaust. Mods are front pipe,overpipe, perrin exhaust, and ft86speedfactory catted header.
kincito is offline
Old 06-10-2014, 11:28 PM   #1920
etherealfall
Drives: Toyota 86 GTS Storm Black
Is your front pipe catted?
Sent from my HTC_0P6B using Tapatalk
etherealfall is offline
Old 06-10-2014, 11:33 PM   #1921
355rockit
Drives: Sci FR-S, Fer F355, Toy Highlander
Originally Posted by Kronos View Post
i am going to be that guy and ask you kindly for a video (preferably some drive bys outside the car)
I'll see what I can do ... it may be later this week or weekend.
355rockit is offline
Old 06-10-2014, 11:40 PM   #1922
kincito
Drives: Raven FRS
yes, catted perrin front pipe
kincito is offline
Old 06-11-2014, 12:18 AM   #1923
CamryDS
Drives: 2003 Camry Blue | 2013 FR-S White
Originally Posted by 355rockit View Post
I flashed the OFT Stage 2 UEL OTS firmware to the ECU this afternoon. Before with the change from stock to FT86SF Catted UEL header + TRD intake, I was very happy with the increased performance. Add in the Stage 2 UEL OTS and you have a tiger. It pulls fast and strong to 6000RPM (didn't go over that... yet). It is very easy to modulate the throttle from stop, but has enough torque to easily spin the wheels. I am extremely happy so far with the upgrade. No issue with idle dip and hear no valve noise or tapping. I am doing a long drive with the car club on Sunday, so I'll see how it matches up to the other sports cars.
I heard from Shiv that stage 2 runs too lean for catted headers. Can you upload any data logs to see if this is true since you have OFT? I'm planning to do stage 2 as well, but I'd love to know for sure, otherwise i'd just run stg 1 at this time.
Also what version of the rom are you utilizing? (I think latest ins 1.59).
Thanks for the info in advanced and congratz!
CamryDS is offline
Old 06-11-2014, 10:57 AM   #1924
355rockit
I am using the most recent, 1.59. My ECU firmware is ZA1JB01C. So far car runs fine and doesn't seem to be running lean. Pulls very strong. I downloaded a log, but inadvertently pulled .prolog and will have to pull the log again and convert to .csv. I can then upload on the site.
The Following User Says Thank You to 355rockit For This Useful Post:
CamryDS (06-11-2014)
Old 06-11-2014, 03:46 PM   #1925
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
I am very eager.
I"m just like @Kronos, the power gain between catted and catless is less important to me than sound.
unsurety is offline
Old 06-11-2014, 06:49 PM   #1926
CamryDS
I would love the see the logs from it =) glad you were able to get at it before me, I was going to do exactly the same.
Thanks!!!! =)
CamryDS is offline
Old 06-11-2014, 10:07 PM   #1927
355rockit
I get a weird message 'File RTIME not found' when trying to download the log from logging via the OpenFlash manager. I may not have initiated loggin properly. I'll need to hook up the OFT again and try logging again.
Old 06-11-2014, 11:42 PM   #1928
JaguarXJ6
JaguarXJ6's Avatar
Drives: 2015 GT-R, 1993.5 Supra, 1995 XJR
Hey everyone,
After a long journey, I'm finally putting thoughts down on the cold air intake, headers all the way back exhaust, and aftermarket tune on my 2014 BRZ.
As promised, a playlist comparing the mods before and after the header+tune is below along with my dynos. I tried to replicate the conditions exactly for the comparison clips.
I don't apologize for my lack of video editing skills.
The car:
2014 BRZ purchased Dec 2013
+ Perrin CAI (front bumper cover removal)
+ FT86 SpeedFactory Catted UEL header (horray, pre-orders)
+ Perrin Overpipe
+ Berk Catted Front Pipe
+ Perrin Resonated 2.5" Exhaust
Current mileage: 52xx
Current power: 195hp/150tq dynojet, 179hp/136tq mustang dyno
Goal:
#1 - Unlock the BOXER rumble
#2 - Reduce/eliminate the torque dip
#3 - Avoid aftermarket tuning
Method:
#1 - Gentle by the book break-in for 500mi followed by raising RPM limit by 500rpm for every additional 100 miles until redline is achieved.
#2 - Complete break-in over a two week period.
#3 - Baseline dyno.
#4 - Install CAI, overpipe, catted front pipe, and exhaust.
#5 - Revised dyno.
#6 - Install catted UEL header.
#7 - Revised dyno.
#8 - Tuning, if required.
Results:
==> Success! But tuning was required.
Overview:
The stock BRZ is lawmower quiet. Neutered. It's designed to produce efficient power while reducing any (perceived) unwanted noise in the cabin or bystanders. It does this extremely well.
I wanted that RUMBLE and was prepared to mod in order to achieve it. Without it, the twins lose that character that soundtrack many enthusiasts crave.
After a baseline dyno and successful break-in, I acquired the aftermarket parts minus the header.
The BRZ runs extremely rich from the factory under power. Breathing mods increase this further.
These modifications by themselves without the header provide a great sounding car with very little highway drone. It sounds much more like what we expect from the FA20, but still lacks that deep down growl.
The revised dyno shows I actually lost a small amount of power after driving with the mods and no tune. -7hp/-5tq at the wheel.
Based on my understanding of closed loop operation, a battery reset will achieve the same thing as shutting off the ignition. Short term trims adjust on the fly to operating conditions constantly. To reset long term fuel trims, an ECU reset or clearing these values with a computer is needed.
Since fuel trims became richer, the ECU has already adjusted the fuel tables for the increased flow. This was not unexpected, but still a disappointment because it means I needed to chip or tune.
The FT86 SpeedFactory header was pre-ordered and installed 6~7 weeks ago from today and tuned by Evasive using ECUTek. The Mustang dyno is below and remember, this is with cats. I have or had the strongest catted NA in the Evasive computer.
The header improved the sound and raised the overall volume by 3-4dB under full throttle and marginally on cruise/part throttle. It now has some rumble especially in the 1,500-4,000rpm range.
The torque dip was almost completely eliminated, it may be that with fine tuning and more break-in, it will be completely flat. Driving, it's not even noticeable.
Throttle response feels improved on the initial tip-in and there's less clutch judder rolling about at parking lot speeds.
When the dealership starts it up to pull in to the back for servicing, the BOXER snarl and rumble was more noticeable OUTSIDE the car. It sounds great.
It doesn't wail or rasp anywhere through the rev range.
It has a pleasant hum, not an intrusive drone on the highway. And no stink.
When you do the Mustang obligatory 10% adjustment to equate to Dynojet, I'm right around 225hp/172tq crank and 195hp/150tq to the wheels.
That's a 15% increase over stock power levels at the final cost of parts and labor at $3700.
I can live with that. And live with the sound.
For those looking to save money, you can get the listed mods and tune without the header.
The improvement in sound from the header happens primarily on part throttle, which ends up being where you spend most of your time. That's why it was a must have for me.
5 video playlist, volume boosted 3dB to more closely match actual volume.
Hero3+ Silver with Fat Gekko dual suction mount. Resolution was lowered to 480p for small files while retaining the sound for easy, low bandwidth streaming.
#1 - Short pull, no header
#2 - Short pull, with header
#3 - Freeway merge, no header
#4 - Freeway merge, with header
#5 - Cruise up hill and deaccel
#6 - Exterior exhaust revs
#7 - Exterior drive-bys
http://www.youtube.com/playlist?list...3hqEgws7VYUv3Q
Now, onto the dyno charts and AFR.
#1 - Baseline dyno, corrected dynojet
#2 - AFR, blue line stock, red line with mods, black line hot pull
#3 - Mustang dyno
2015 GT-R Pearl White with Ivory, Premium | Stock, DD
1995 Jaguar XJR | Turquoise Metallic | I6 4.0L | Eaton M90, 11psi | 4L80E | 1 of 12 of 400
1993.5 Supra Turbo | Baltic Blue | 6spd | 3.77 Torsen LSD | SP57 | RPS manifold | ViPEC V88 | 525/500rwhp/tq
JaguarXJ6 is offline
The Following 8 Users Say Thank You to JaguarXJ6 For This Useful Post:
akahenry (06-12-2014), BigFatFlip (06-11-2014), BRZ FAMILY FUN (01-24-2017), FormulaD1988 (06-12-2014), Jyn (06-12-2014), Re~Mix (06-11-2014), Sypher (06-11-2014), unsurety (06-12-2014)
Old 06-12-2014, 12:01 AM   #1929
Sypher
Sypher's Avatar
Drives: '13 Ultramarine FR-S M/T
@JaguarXJ6 that is an AWESOME! comparison! its exactly what i wanted to do but didnt have the money/time for dyno runs and was far too lazy to make vids lol.
you sir are awesome lol
Mod List:
FT86SF Catted header / Nameless combo pipe with cat and res/ FT86SF V1 CBE / GrimmSpeed Intake / OFT STG 1 GS Tune / Fortune Auto 500's
Sypher is offline
Old 06-12-2014, 02:35 AM   #1930
akahenry
akahenry's Avatar
Drives: '18 STi
Originally Posted by JaguarXJ6 View Post
Hey everyone,
The car:
+ Perrin Overpipe
Goal:
Method:
#3 - Baseline dyno.
#5 - Revised dyno.
#7 - Revised dyno.
Results:
Overview:
#3 - Mustang dyno
Any chance for an outside of car sound clip- perhaps a drive by sound clip?!
akahenry is offline
Old 06-12-2014, 06:47 AM   #1931
FR-S Matt
Originally Posted by tahdizzle View Post
Eh, he's just upset cause he bought a JDL header and had to get a tune to remove the torque dip.
If you're not tuning a header in the first place, then why are you even buying one?
The entire point of an aftermarket header is to increase the flow of exhaust which allows more timing to be had.
FR-S Matt is offline
The Following User Says Thank You to FR-S Matt For This Useful Post:
dkx64 (06-12-2014)
Old 06-12-2014, 06:49 AM   #1932
brianhj
Drives: 2017 Camaro 1SS
Because with this header (and I'm sure others) you can see gains without a tune and without ruining your warranty.
brianhj is offline
catted uel header, ft86speedfactory header, is my order ready yet?
Invidia Catless and Catted Front Pipe - ** FT-86 SpeedFactory ** FT-86 SpeedFactory Engine, Exhaust, Transmission 107 03-29-2016 10:48 AM
catted header or catted front pipe? gabeg86 Engine, Exhaust, Transmission 28 10-13-2015 12:32 PM
P&l EL catted and coated header. wootwoot Engine, Exhaust, Bolt-Ons 8 10-11-2013 12:50 AM
Catted UEL Header Cjymiller Engine, Exhaust, Transmission 20 05-24-2013 12:01 PM
***Invidia Catted and Catless Front Pipes*** - FT-86 SpeedFactory RELEASE SALE FT-86 SpeedFactory Engine, Exhaust, Bolt-Ons 12 10-24-2012 10:12 PM
