Old 06-10-2014, 09:52 PM   #25537
RedLeader
RedLeader's Avatar
Drives: 2013 Firestorm FR-S
Originally Posted by jack43 View Post
Attachment 81580
So my 1.5 year old just did this.
Any of u bright minds out there with a solution?
The tongs are spring loaded and won't turn the other way in the bottle.
I'm thinking something elaborate with magnets and string
Metal coat hanger, you'll destroy it in the process, but which is easier to replace: a coat hanger or a pair of tongs and 5 gallon bottle?
No elaborate use of strings and magnets required.
The Following User Says Thank You to RedLeader For This Useful Post:
jack43 (06-10-2014)
Old 06-10-2014, 09:55 PM   #25538
RedLeader
RedLeader's Avatar
Originally Posted by SirBrass View Post
I now have a long-term project goal for my BRZ. It will definitely scream "NERD!", but I don't care. It will be awesome.
A TARDIS-themed BRZ that is not just for show. That means changing color to TARDIS blue for starters (a bit deeper blue than WRB). I think a light on top of the antenna, instead of going with the ever-popular shark-fin is another thing for it. Then of course the exterior design stuff. Going to do an interior color redesign anyway, so that'll work as well.
Do this, and I will love you forever! No homo.
Why not try to recreate the light from the top of the TARDIS to function as an antenna cover?
I think the TARDIS blue is basically the Ultramarine but without the metal flake in it? Depends on which TARDIS you're trying to model this after.
You should also find a way to remove the rear seats and move the front seat mounting points back a few inches, that way people might actually say "Its bigger on the inside" without lying through their teeth.
Old 06-10-2014, 10:00 PM   #25539
Vis101
Vis101's Avatar
Drives: 2013 Limited BRZ
Jack, Red Leader is on to it with the coat hanger.
Sent from my HTCONE using Tapatalk
Vis101 is offline   Reply With Quote
The Following User Says Thank You to Vis101 For This Useful Post:
jack43 (06-10-2014)
Old 06-10-2014, 10:04 PM   #25540
MaddBaggins
MaddBaggins's Avatar
Drives: Big guy in a little car...
Your welcome to try out my recaros.
Sent from Spaceball 1
I do want to try those out.
14 FRS - daily driver "Dory"
11 Rav4 - wifes ride "Ruby"
94 Landcruiser - camping/hunting rig "Tortuga"
MaddBaggins is offline   Reply With Quote
Old 06-10-2014, 10:06 PM   #25541
oldpueblo
oldpueblo's Avatar
Drives: Scion FR-S 10 #853
I have little to add other than which Doctor/interior design are you going to go with? That and you have to rewire your horn to make the tardis sound.
Also this is a good excuse to post the tardis costume I made my daughter for comicon last weekend.
More pics for the nerds:
http://imgur.com/gallery/cEqrE
oldpueblo is offline   Reply With Quote
The Following User Says Thank You to oldpueblo For This Useful Post:
MaddBaggins (06-10-2014)
Old 06-10-2014, 10:08 PM   #25542
MaddBaggins
Yes!!
The Following User Says Thank You to MaddBaggins For This Useful Post:
SirBrass (06-11-2014)
Old 06-10-2014, 10:15 PM   #25543
MaddBaggins
Started making the billiard ball shifters. I'm keeping the 7 and the Cue ball. I might keep the 2 also. The others, I can make for sale if anyone wants one.
[IMG]http://i421.photobucket.com/albums/pp298/MaddBaggins/Dory/9EE00***-C001-4D7D-8620-D21028266E0D_zpsdnhbimpv.jpg[/IMG]
Old 06-10-2014, 10:18 PM   #25544
EZWood
BAMF
EZWood's Avatar
How much you thinking? Dibs on the three.
Old 06-10-2014, 10:26 PM   #25545
MaddBaggins
I was thinking $25 plus shipping unless we club ship or meet up. I'll start a dibs list in my phone, you get 3.
I need a night to make each one, line it up on my shifter and let the epoxy set for a while before doing the next one. If it doesn't line up perfectly on your shifter, stuff some tissue or little bit of foam or rubber into the end to tighten things up.
Old 06-10-2014, 10:31 PM   #25546
MaddBaggins
I will have to order more of the fittings also. I only ordered 3 to start with in case no one was interested.
Old 06-10-2014, 10:41 PM   #25547
Cross
It's the Mad Cow
Cross's Avatar
I am considering 4 or 10 not sure yet.
Old 06-10-2014, 10:42 PM   #25548
Lischynski
Weendog
Lischynski's Avatar
Drives: 2014 Scion FR-S
I'll take 10 if you decide on 4. Otherwise I'll take 7.
Old 06-10-2014, 10:49 PM   #25549
MaddBaggins
I'm keeping 7 and Cue, possibly the 2 also.
I'll order some more fittings. I can probably have them all done in 1-2 weeks from now.
Lischynski (06-10-2014)
Old 06-10-2014, 10:55 PM   #25550
MaddBaggins
I put you guys on the dibs list.
