Drives: Firestorm FR-S AT
Effect of cat delete
Hey guys, I'm new to this stuff, so forgive the noob question.
What would be the sound and performance effects of a cat delete on the stock exhaust? (I already know it will make you fail the emissions test). I'm curious if anyone actually knows the answer to this, because it seems like something people never do (ie if they do a cat delete they also change other things at the same time, so you can't isolate the effects of just the cat delete).
Phantom Electric Supercharger with Procede controller, GReddy SP Elite, CA-FI Dashlinq4
#2 |
Drives: Toyota 86 TRD Version AT
Are you keeping the stock header? If you are, you will just gain some volume in your exhaust note. If you will be swapping a catless header, your exhaust note will be raspy.
#3 |
Drives: 2014 Pearl BRZ Limited
Not sure about performance gains/losses, but here are a couple sound clips comparing 100% stock vs resonated cat delete.
[ame]http://youtu.be/ytvCLr-XM2U[/ame] [ame]http://youtu.be/SF8uvoWga7E[/ame]
| OFT & Stg2 e85 Tune | Perrin Intake Tube & High Flow Filter | Perrin Lightweight Crank Pully | | Tomei UEL Header/Overpipe | HFC/Perrin Catback | Tom's Tails | Enkei RPF1's | RS*R SuperDowns | |
| The Following 3 Users Say Thank You to edeekeos For This Useful Post: |
#4 |
Junior
Drives: a car
Performance wise, yes there will be an increase over stock. That said, the difference between a cat delete pipe and a HFC pipe is like 1 hp, but with the addition of being able to pass emissions, and less rasp.
| The Following User Says Thank You to cdrazic93 For This Useful Post: | mattbenich (06-14-2014) |
#5 |
Drives: 2013 Subaru BRZ Limited (WRB)
Funny, as I was about to ask the same thing. I'm getting a Milltek exhaust system installed on Friday, and am trying to decide on the primary catback (secondary cat delete) or the secondary catback (no cat delete), and if I'd notice any difference between the two in sound or performance (with no tuning). Any recommendations?
#6 | |
Drives: Turbo BRZ & Supercharged E90 M3
Yes it'll be noticeably louder/ faster. Factory cats are restrictive. High flow cats would be good alternative if you wanna keep emissions.
#7 |
Until someone has passed emissions, it's all speculations at this point.
There is no rasp if your remove header only, otherwise if you have the right CBE, no rasp either. Not much performance wise after replacing headers unless FI. People make the mistake of doing back to front, should definitely attempt from header back in terms of sounds and performance.
#8 | |
Drives: 2014 Ultramarine 6MT FR-S Monogram
Is it really possible to pass emissions testing with a HFC? I've yet to see a post on this board where someone says they have. Is there anyone out there who can speak from direct experience? My gut feeling is that any changes to the header or cat will likely lead to failing the emissions test, but what do I know, I only stayed in a Holiday Inn Express a couple of weeks ago.
Borla axleback exhaust * mud guards * Michelin Pilot Super Sport tires * Opti-Coat * BRZ trunk lid liner * Rexpeed Wide Mirrors (heated)
#9 | |
Seems Legit
Drives: Toyota
There's no blanket statement for passing emission testing. Each state is different. In the states that my car is registered (VA, AL, GA) I know what the requirements are to keep my vehicles street legal, all the way down to the tint requirement. With that being said, a cat is a cat, in those states, whether it's built into the header or is a HFC. In California that previous statement isn't true. In the states I listed only 1 cat is required, not 2 so a free flowing header can be added and a front pipe that incorporates an HFC. In regards to emission/smog testing you'd be better off knowing the laws for your state and county. For example, only in GA only vehicles registered in the counties adjacent to and within the city limits of Atlanta have emission testing, all the others do not. Some states require a visual test, some only require an OBDII readiness check...it's best to know your own laws than rely on a blanket statement on a forum.
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here] Last edited by ecko04; 06-10-2014 at 11:46 AM. |
#10 |
There is no cat in the midpipe.
#11 |
Drives: 2013 brz
#13 | |
Yea holy shit how the hell you manage to necro a thread from 4 years ago with a response like that
| The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post: | jflogerzi (08-16-2018) |
| Does Turbo effect gas milage?? | beesmiff07 | Forced Induction | 86 | 10-30-2014 10:25 PM |
| Effect of using of spacers for rear-only | mit_peid | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 08-05-2013 01:06 AM |
| Carbon Effect Wing Mirrors | faz1 | Cosmetic Modification (Interior/Exterior/Lighting) | 11 | 08-25-2012 09:12 PM |
| Effect of shifter knob weight | BMWDavid | Engine, Exhaust, Transmission | 3 | 08-03-2012 11:32 AM |
| MR-S Effect... | Dimman | CANADA | 11 | 09-06-2011 11:49 AM |
