Old 06-09-2014, 09:43 PM   #6119
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
Originally Posted by Stormalong View Post
So, my car is basically stock except for the ESC. I told myself I was only going to get the ESC and then I'd be done with mods. But...
What do you guys think is the best bang-for-buck mod to enhance the ESC? I'm just looking for "the next step", not "this plus this plus ....".
assuming like others, that you have a tune already, You could just drop in a K&N (~$45). Should be good for an extra ~5hp over 4500 rpm, or just wait till your next scheduled replacement and get one then, so you will only be spending a little more than just replacing the factory unit. Really no downside to this. Someone in here with an esc recently did multiple dyno runs with various mods on/off, like intake/snorkle. Maybe we can find it.
Other than that I would probably say the 1.5 dump pack is about $200 for an extra what.. 10~12 hp starting at 5000 rpm?. If you already have the smaller starter battery, then there really is no down side to this either.. but just my .02c
*most of these numbers are from my vague memory and may not be accurate.
Target70 is offline   Reply With Quote
Old 06-09-2014, 09:49 PM   #6120
shif7i7down
Erected Member
Drives: frs
Originally Posted by robwbright View Post
Based on what you're doing there, it would appear that I'm losing time by saving my clutch at the change to 2nd gear. I haven't been hitting it hard enough to get much wheelspin at all switching to 2nd... much less a significant amount of wheelspin like you're getting.
I believe that with better summer tires the stock frs + esc can do 13.9xx at the track not to mention the actual strip has better grip then the bumpy hwy
Edit; time to update the spread sheet in the phantom owner thread lol
shif7i7down is offline   Reply With Quote
The Following User Says Thank You to shif7i7down For This Useful Post:
DAEMANO (06-10-2014)
Old 06-09-2014, 10:06 PM   #6121
nlowell
nlowell's Avatar
Drives: 2013 Scion FRS
Here's a little video of my last run at Buttonwillow. The ESC was pretty hot by this point with pretty much back-to-back 20 minute sessions. With the ESC I could get 103-105mph on the main stretch, without I could only get ~97mph.
I'm using Harry's Lap Time + ODBII Bluetooth Reader + GoPro Hero 3+ Black + new software I came across called Dashware. I was sold on it when I saw they had custom made gauges for the FRS/BRZ
nlowell is offline   Reply With Quote
The Following 3 Users Say Thank You to nlowell For This Useful Post:
Andrew025 (06-09-2014), DAEMANO (06-10-2014), Robftss (06-10-2014)
Old 06-09-2014, 10:07 PM   #6122
TM
TM's Avatar
Drives: DGM BRZ 6MT
Just received my 1.5 conversion tray and installed the 0.5 dump pack. Any more height with the extra tray and I wouldn't be able to screw in my battery tie-down, as the washers are only a couple of treads in before it became tightened. Looks like it fits just right.
TM is offline   Reply With Quote
The Following User Says Thank You to TM For This Useful Post:
Old 06-09-2014, 10:24 PM   #6123
robwbright
Drives: '13 BRZ Limited WRB Phantom ESC 1.5
Originally Posted by shif7i7down View Post
Yeah, i got 5.8 0~60 and 14.02 with a passenger.
And with 5.46 0~60 and 14.01 without passenger but i had so much wheel spin on 2nd. The car kinda fished tail a bit.
Here's the other 2 runs just to check for consistency
Maybe Torque Pro just reads really slow... I have trouble seeing how I'm losing 0.8 seconds to you - even if I'm not hitting it quite so hard. That's a heck of a lot of time.
And the fact that Torque Pro read a 6.3 when starting in 2nd gear. It felt like a 7.3 compared to hitting it hard in 1st.
'13 BRZ Ltd MT WRB Phantom ESC 1.5
2012 Honda Accord Coupe
2006 Saab 9-3 2.0t
1997 Honda Accord Coupe
1995 Honda Prelude VTEC
robwbright is offline   Reply With Quote
Old 06-09-2014, 10:30 PM   #6124
VR46
are you Jeff Vader?
VR46's Avatar
Drives: Black BRZ Limited
Talking my thought after reading today's posts in this thread
VR46 is offline   Reply With Quote
The Following User Says Thank You to VR46 For This Useful Post:
shif7i7down (06-09-2014)
Old 06-09-2014, 10:31 PM   #6125
fenton
here's the 1/4 mile run and 0-60 that i promised earlier,
I'm sure that i could do better but the stock tires just don't grip when going into 2nd gear -_-
0-60 time is at the 14 sec mark at 5.46
the other two videos will be up shortly, just kinda slow uploading
Awesome run man. That was the perfect launch and awesome shift into 3rd. Love chipping third :-)
fenton is offline   Reply With Quote
The Following User Says Thank You to fenton For This Useful Post:
Old 06-09-2014, 10:39 PM   #6126
gtfapollo
gtfapollo's Avatar
Drives: Velocity Orange
@shif7i7down
Snapping second and stepping out with wheelspin like that with this ESC?
Oh dem feelz...
gtfapollo is offline   Reply With Quote
The Following 2 Users Say Thank You to gtfapollo For This Useful Post:
DAEMANO (06-10-2014), shif7i7down (06-09-2014)
Old 06-09-2014, 10:41 PM   #6127
shif7i7down
Erected Member
Drives: frs
Most likely it's torque that's giving you the bad readings, go grab a gtech, only 200usd for the new gtech pro ss and its the most accurate non actual strip measurement. It's known and accepted by many car enthusiast community, all of which agrees to the Claims of+/-.01 accuracy.
robwbright (06-09-2014)
Old 06-09-2014, 10:55 PM   #6128
robwbright
Not too expensive - I'll have to look into it... but the upcoming family Disney trip will likely prevent further car expenditures for awhile.
2006 Saab 9-3 2.0t
Old 06-09-2014, 11:30 PM   #6129
Bu-Tang
Drives: 2013 Scion FR-S, Nissan Pathfinder
@fenton lets meet up this week, I wanna go for rip lol,
anyways, Rob and I rigged a temp boost gauge few weeks ago just for fun.
[ame]http://youtu.be/anNCP4own3w[/ame]
This isn't the best video as I was having camera issues but 2nd gear 2RPM-4th, not shifting aggressively but just to show the gauge.
Im consistently hitting 4.7PSI according to the logs and just under 5 on the gauge @ 3K rpm when the batteries are all warmed up. I've noticed with the dumps you really gotta drain them a few times before they get going.
I might have to go give a 0-60 after seeing some of yours.
Bu-Tang is offline   Reply With Quote
The Following 2 Users Say Thank You to Bu-Tang For This Useful Post:
Old 06-09-2014, 11:34 PM   #6130
mid_life_crisis
Drives: FR-S 10 #103 AT
Originally Posted by gtfapollo View Post
@shif7i7down
Oh dem feelz...
with apologies to the Beach Boys
I get pushed out of shape and it's hard to steer,
when I get rubber in the first three gears,
she's a little E S C,
you don't know what I got...
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
The Following User Says Thank You to mid_life_crisis For This Useful Post:
fenton (06-10-2014)
Old 06-10-2014, 12:53 AM   #6131
JD86
Drives: 2013 Toyota 86 GT
Thanks for clarifing that with your additional (1,000usd?)mods plus the avo stage 1 (4.4k usd)kit with custom(500usd?) tuning(non ots) that you made 245whp. Great hp value for the money i assume?
Edit: as I've stated before, I'm not trying to down play any turbo kit, simply saw your dyno post and thought hey that's pretty close to mines, if that's the avo stage 1 tune, the it's pretty comparable"
I'm sure you'll make lots more hp in the future and dominate the streets, more power to you bro,
Please don't put words in my mouth. It didn't take any additional mods to hit 240hp (yes 240, not 245, sorry I rechecked old numbers to be accurate). All it took was to replace the wastegate actuator with one that held pressure, and plugging a leak in my headers. That's all. Once I did that and was no longer leaking boost like a sieve the off the shelf AVO tune was good for 240hp. So yes the $100ish for a new waste gate actuator was a fantastic investment for an additional 60 hp.
Any comparisons to my stage 1 dyno are really kinda useless. I had all sorts of dramas and parts that weren't working correctly at the time of that dyno. My car was only holding 3psi at redline. I just didn't air all my grievances in the dyno thread as they're covered in my build thread. Actually I was pretty specific about how disappointing I found the car when that dyno was done and the issues I had at the time. Then I found even more underlying dramas down the line that would have affected that dyno as well. Just I found them long after I stopped caring about updating my build thread.
If you want a better look at what a stage 1 AVO kit with an OTS tune can do look at my dyno chart directly below the one you quoted. It's the custom tune, but that only netted me 10% extra power so 27hp, over the AVO tune. The shape of the graph was pretty much the same. As mentioned the only mod between that and my stage 1 was a 7psi actuator, because my stage 1 actuator wasn't working. I have the dyno of the AVO tune around somewhere, but it was done nearly a year ago and even then had issues so really can't be bothered finding it.
Anyways just thought you should be aware that the dyno chart you were comparing it to had a lot of underlying problems and was only 3psi. All that really matters at the end of the day is you're happy with your car and your ESC.
JD86 is offline   Reply With Quote
Old 06-10-2014, 01:01 AM   #6132
fenton
Sure thing sounds good.
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
