Old 06-09-2014, 02:54 PM   #85
Malcolm Lawson
Drives: Scion FRS 2014
Originally Posted by DrDuquette View Post
Just changed my jack stands. Welded on some pieces to help support the car without bending the crimp spots. Attachment 70750Attachment 70751
AT LAST, thank you @DrDruquette someone with a satisfactory design for a jackstand pad.
After reading this thread and following most of the links I am afraid that a lot of people are putting themselves and their cars at RISK. Just because something works once, twice or a dozen times does not make it safe.
The seam weld is not meant to support the car. As far as I can deduce the actual jack point is INSIDE of the seam. If you look at the OEM jack you will see that the slot in the top is deeper than the height of the seam - no load on the seam when supporting the car. You will also see that the slot in the OEM jack is offset. When in place notice that the outer (narrower) part of the pad does not contact the car. All of the weight of the car is resting on the inner (wider) part of the pad.
@DrDruquette I would suggest a modification to your design, the slot should be offset and the cheek on the inside of the seam should be at least 1 inch wide. The center of the larger cheek should be on the center-line of the jackstand.
Malcolm
Malcolm Lawson is offline   Reply With Quote
The Following User Says Thank You to Malcolm Lawson For This Useful Post:
BirdTRD (03-20-2015)
Old 07-07-2014, 07:48 AM   #86
86Toyobaru
Drives: 86 & GRB
Safety is top one priority when I work under car. Big brand name (better quality control) and good design jackstands is all I want. I use BAL for my main jackstands. Take a look its pin design. Its more secured when you lift up jackstands. And a rubber pad on the top is for pinch welds like our car but its sell separately. For ratchet handle type jackstands, I use them as backup one. So I always have 8 jackstands to support car when I go under it. Plus floor jack and OEM jack.
86Toyobaru is offline   Reply With Quote
The Following 2 Users Say Thank You to 86Toyobaru For This Useful Post:
funwheeldrive (03-25-2015), JeremyR (08-22-2017)
Old 08-28-2014, 12:51 AM   #87
DavidBob
DavidBob's Avatar
Drives: 2013 WRB BRZ
I jacked my car up on the wrong jacking point in the rear, could i have damaged anything?
DavidBob is offline   Reply With Quote
Old 08-28-2014, 02:24 AM   #88
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Depends on what you jacked it up on...
Old 08-28-2014, 11:19 AM   #89
DavidBob
DavidBob's Avatar
Exactly where the jack is just on the black part before it
Old 01-16-2015, 09:17 PM   #90
flightmaster
flightmaster's Avatar
Drives: Subaru BRZ
Are there any issues with jacking the car up from either side of the pinched welds? Are they strong enough to support the weight of itself? Just asking because I need to jack the car up from the side and then transfer it to a jack stand. But because the jack stand will be taking the weight of the car on the pinch welds, I need to jack the car up from another point but my jack isn't long enough to reach the front jacking point.
I hope this made sense!
Education is important but racecar is importanter
flightmaster is offline   Reply With Quote
Old 01-16-2015, 09:26 PM   #91
zeal86
zeal86's Avatar
Drives:
I made this out a rubber sanding block I bought at Harbor Freight. I still have to cut out the knotch for the pinch welds.
The jackstand is also from Harbor Freight.
2014 6-speed Monogram (37J)
zeal86 is offline   Reply With Quote
The Following User Says Thank You to zeal86 For This Useful Post:
Astroboy (09-13-2015)
Old 03-20-2015, 03:18 PM   #92
zeal86
zeal86's Avatar
Drives:
Ok so my little mod did not last long but that is ok because I came across these are Harbor Freight. I believe they were $6.99 for a pair.
projekt zeal86 build
The Following 3 Users Say Thank You to zeal86 For This Useful Post:
Bimble Bamble (04-12-2015), BirdTRD (03-20-2015), chanomatik (03-20-2015)
Old 03-20-2015, 03:39 PM   #93
HATED1
HATED1's Avatar
Drives: 86
for those of you who are cheap and worried about messing up your pinch welds, look for an old pair of rubber slippers, cut to the appropriate size, put it between the weld and jack stand. Done.
HATED1 is offline   Reply With Quote
The Following User Says Thank You to HATED1 For This Useful Post:
nzer (03-20-2015)
Old 03-21-2015, 12:43 PM   #94
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
Exactly what i use
Old 06-22-2015, 01:00 PM   #95
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
My passenger side pinch weld collapsed and actually damaged my fender (pushed it up and out) So that sucked...I got the fender lined back up, but bottom is bowed out a little now and the pinch weld is mucked up...Cross member for now on.
Old 06-22-2015, 01:21 PM   #96
zinzan
zinzan's Avatar
Drives: Subaru BRZ 2014 Limited WRB
Pics?
zinzan is offline   Reply With Quote
Old 06-22-2015, 06:49 PM   #97
flightmaster
Drives: Subaru BRZ
Ah that's rough... Which cross member are you using? Maybe some photos would help us out
Old 09-12-2015, 10:37 PM   #98
isolato
Drives: 2015 Subaru BRZ; 2001 Mazda Miata
Thumbs up
I have used jacks and jack stands for years, but never before had fully supported a car at all four pinch-weld locations to get under it for a major project. Many of the comments in this DIY thread were very helpful.
I ended up going with the Esco 5"-wide flat-top style jack stands, and used the "slit-in-the-hockey-puck" method to protect the pinch welds (image attached). The car was super solid during the whole job with no damage to the pinch welds. Here's a link to the jack stands I used:
[ame="http://www.amazon.com/gp/product/B0019JVIPM"]Amazon.com: ESCO Jack Stand - 3-Ton Capacity, Model# 10498: Industrial & Scientific[/ame]
Thanks to Phaedrus29 for the recommendation on this monster jack from Harbor Freight ... weighs a ton, but it's solid and lifts 23" high:
http://www.harborfreight.com/2-ton-l...ump-68050.html
isolato is offline   Reply With Quote
Jacking up car - using garage jack NYNOMAD BRZ First-Gen (2012+) — General Topics 2 06-27-2012 08:36 AM
Front jacking point dsgerbc Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 05-30-2012 05:19 PM
Supporting Mods Double4Free Scion FR-S / Toyota 86 GT86 General Forum 5 02-21-2012 05:33 PM
Unacceptable: Toyota/Subaru among group of auto manufacturers supporting SOPA. Mitch Other Vehicles & General Automotive Discussions 43 01-09-2012 08:07 AM
