Old 06-04-2014, 11:40 AM   #393
kanundrum
Drives: 2013 Whiteout FR-S
Originally Posted by Blizzz View Post
Heading out around 3:00 am tomorrow to go pick it up (traveling from Massachusetts). I'll have a nice 420 mile drive to test it out on the way back, and looking forward to it
I have a nice pic of your car and I am Jealous your getting the water meth before I do . Its looking great!
Old 06-04-2014, 02:30 PM   #394
Blizzz
Awesome, send it to me I actually will not be able to pick up the car tomorrow unfortunately... PTuning being as meticulous as they are (and much appreciated) want to hang on to the car for a few extra days to test it in non-dyno conditions in different temps etc to make sure it will be ready for pickup. We're kind of testing new territory with a 93 octane tune as a fail-safe for an empty WMI tank, or if the flow rate is not correct as well as dialing in a full 50/50 water meth tune for everyday driving. For clarification, should a fail-safe condition occur where something isn't right with the water meth injection, the ECU will automatically swap over to the 93 octane tune effectively making a pretty seamless transition without need for driver response. I plan on always running it on WMI, but in the case where you might run out of boost juice or something it's always nice to know you can still run the car and run it hard without worrying about the tune. It should definitely be interesting, and I'm sure worth the wait.
Blizzz is offline   Reply With Quote
Old 06-04-2014, 02:38 PM   #395
kanundrum
pm me your email or phone # haha.
I also heard you can run some windshield washer fluid from Walmart as Water meth according to a good friend who is recently running water meth as well.
Old 06-04-2014, 03:02 PM   #396
AllDayJonRay
Drives: 2013 Ultramarine FR-S
Windshield washer fluid does often contain alcohol (as an antifreeze agent), which makes it a water/alcohol blend. That said, it also contains dyes. I can tell you from first hand experience that those dyes settle, cake, clog, and disrupt/jam solenoids with WMI systems.
I highly recommend finding unadulterated alcohol to mix with water. After my issues with the dyes, I switch to denatured alcohol/distilled water mix.
'13 Ultramarine 6MT FR-S || K&N Drop-In, SpeedFactory V1 Cat-Back || Moto-East tuned
Join the 86 Owners Clan on Clash of Clans: "86 Owners" Password: "fa20" || Help us take over the world || Thread
AllDayJonRay is offline   Reply With Quote
The Following User Says Thank You to AllDayJonRay For This Useful Post:
kanundrum (06-04-2014)
Old 06-04-2014, 03:04 PM   #397
kanundrum
Ill be sure to relay that information! Its funny though because most of them will have some sort of dye in it, even the snow performance boost juice has pink dye
http://www.snowperformance.net/boost-juice.html
Thanks!
Old 06-04-2014, 03:33 PM   #398
sw20kosh
Drives: 2013 Black FR-S
Thanks!
You can just use the yellow Heet bottles found at the autoparts stores. I think it is like 99% Pure methanol with no dyes or anything. That's what I used when I was running a meth system.
Windshield washer fluid here in the bay area CA doesn't contain alcohol. I think during the winter some shops near the mountains are allowed to sell it with alcohol but otherwise I think it is illegal in CA.
The Following User Says Thank You to sw20kosh For This Useful Post:
Old 06-04-2014, 03:40 PM   #399
AllDayJonRay
I was fortunate enough to work at a dealership at the time, and we always have 5 gallon cans of denatured alcohol to 'borrow'.
If you're going to be running WMI on a regular basis, it's probably worth it to take a look around and see if you can get some alcohol that hasn't been rebranded by distributors with a premium applied.
Old 06-05-2014, 04:42 AM   #400
DrewsBRZ
Drives: 2013 BRZ Limited
Does anyone with the kit know if you can run a Perrin oil cooler and not interfere with anything? I'm running the Perrin OC now and want to make sure the piping wouldn't interfere with the sandwich plate.
DrewsBRZ is offline   Reply With Quote
Old 06-05-2014, 01:07 PM   #401
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
Just by looking at the photos I would say no. But do call Patrick at PTuning as he is the resident expert with compatibility questions.
Looking at the Perrin blog photos, the lines run down the same path as the cold side IC piping and the cooler looks like it bolts right where the IC sits.
http://blog.perrinperformance.com/pe...-s-oil-cooler/
Driver side cool pipe path.
Intercooler
rb6freak is offline   Reply With Quote
Old 06-09-2014, 02:30 PM   #402
mkivsoopra
@ptuning How's the oil coolers coming along? The weather's starting to heat up.
mkivsoopra is offline   Reply With Quote
The Following User Says Thank You to mkivsoopra For This Useful Post:
rb6freak (06-09-2014)
Old 06-09-2014, 04:41 PM   #403
JerryMichaels7
Drives: Whiteout FRS
For those of you who installed this yourself how bad was it? and about how long do you think it would take? I have access to a lift and all the tools I could want
life's greatest stories usually start with the words, "fuck it!".
JerryMichaels7 is offline   Reply With Quote
Old 06-09-2014, 04:46 PM   #404
rb6freak
rb6freak's Avatar
Drives: 23 BRZ
Pretty easy when following the PTuning install guide. You should be able to install over a weekend no problem, less the clutch. I would suggest getting the clutch done in advanced. I took my time and did it over a few week period. @mkivsoopra on the other hand knocked it out by himself in like 8 hours, including clutch gauges etc.. He's an animal.
Old 06-09-2014, 04:49 PM   #405
JerryMichaels7
Yeh planned on doing clutch in advance. Old guy that runs the hobby shop on base is cool as shit and even tho he doesn't have to help he has helped whether I needed it or not, plus I have another buddy that will help.
Old 06-09-2014, 04:53 PM   #406
mkivsoopra
LOL.. not that fast. My own install took the better part of the weekend with some extra hands, then a few evenings after work to wrap up some loose ends.
I helped another member install his kit and we knocked it out overnight.
ptuning, turbo kit
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
Full Blown Turbo Kit Owners Topic King Tut Forced Induction 2637 12-27-2020 03:44 PM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
P&L Turbo Owners Topic Thread GTB/ZR-1 Forced Induction 4 09-01-2013 06:27 PM
