Old 06-09-2014, 08:51 AM   #1457
TmP
TmP's Avatar
Drives: A bunch of 'em...
Originally Posted by post_break View Post
I did 94ft lbs and the pulley bolt fell out later that day. I went to 120 after that. And rechecked it a dozen times.
Say what????
TmP is offline   Reply With Quote
Old 06-09-2014, 08:52 AM   #1458
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Originally Posted by TmP View Post
Say what????
Yes. The bolt came out. My pulleys were hanging on by a thread. Check your torque, don't just torque and assume it's good. Check it warm and cold.
post_break is offline   Reply With Quote
Old 06-09-2014, 09:06 AM   #1459
J_kennington
Drives: 2013 asphalt scion FRS
Very possible that it fell out. You don't measure a "90* turn" with torque. You measure it with an angle torque wrench.
2013 raven frs(dd/grocery getter)
1990 mitsu eclipse gsx(street/strip car)
1995 gmc 1500 4x4(off road toy)
2005 Yamaha yz250f
J_kennington is offline   Reply With Quote
Old 06-09-2014, 10:03 AM   #1460
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
Sh!t, going to check mine right now.
zoth is offline   Reply With Quote
Old 06-09-2014, 11:09 AM   #1461
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
That's like negative 10-15.
Originally Posted by zoth View Post
Mine never goes less than -10
I hope you guys aren't talking inHg because you both definitely have a vacuum leak if you are. These motors should be pulling -19 to -20 inHg at idle and can go higher when off throttle in high vacuum situations. Remember not every boost/vacuum gauges reads in inHG and PSI though.
Old 06-09-2014, 11:17 AM   #1462
post_break
post_break's Avatar
This is what mine says at idle.
Old 06-09-2014, 11:43 AM   #1463
zoth
zoth's Avatar
Mine always reads like that even before SC. Picture is with E85 flex tune.
Old 06-09-2014, 11:43 AM   #1464
captain_jack
captain_jack's Avatar
Hey how do you like that gauge pod,I have it and haven't bought the failsafe yet.
may the schwartz be with you....
Old 06-09-2014, 12:14 PM   #1465
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
Originally Posted by FR-S Matt View Post
Are you guys running 0w-20 after supercharging for your daily drive? Not looking to get into an oil debate, but just wondering if that weight will suffice for DD and a little spirited driving or should I bump up to a bit heavier weight? I've got an oil change up coming up soon.
user manual states that the 5w-30 can bu also used and that's what many people with FI use on their cars..being in Texas, I would never consider 0w-20
I am not sure how is that even possible, I've attended 2 track events after the KW kit and after many many pulls I didn't run into any issues.. I will check by torque again to make sure..
btw, why did you torque it to 120 ft/lbs? Is that just a random number?
glamcem is offline   Reply With Quote
Old 06-09-2014, 12:53 PM   #1466
MAPerformance
Drives: Asphalt FRS
Looks like you might have A/F reading in the LCD screen, and your boost/vacuum in the LED portion.
MAPerformance is offline   Reply With Quote
Old 06-09-2014, 12:59 PM   #1467
post_break
post_break's Avatar
I read somewhere in this thread others were torquing to 120. After torquing to that it hasn't budged. I even tried to remove the bolt to replace it with a brand new one and couldn't get it to budge. So said screw it, she's staying in.
AFR is on the LCD, vacuum on the LED yes.
Old 06-09-2014, 01:35 PM   #1468
King Tut
NASA SpecE30 Racer
King Tut's Avatar
(-10) pounds per square inch = -20.3625437 inHG
We have to make sure everyone is talking in the same units. It appears that both of you guys are pulling the correct amount of vacuum at idle.
Old 06-09-2014, 01:40 PM   #1469
zoth
zoth's Avatar
We'll that's good to know, thanks.
Sent from my SM-N900T using Tapatalk
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1
DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit
Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time)
DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler
Old 06-09-2014, 01:54 PM   #1470
NCItaly
Drives: 2013 BRZ Limited
Are you getting afr off the obd2?
NCItaly is offline   Reply With Quote
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
All SUPERCHARGER kits compilation thread subatoy Forced Induction 76 03-10-2016 12:38 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
