View Poll Results: Where do you set your rev limiter?
Below 7000 37 28.46%
7000 37 28.46%
7100 5 3.85%
7200 9 6.92%
7300 8 6.15%
7400 24 18.46%
Above 7400 10 7.69%
Voters: 130. You may not vote on this poll
Old 06-08-2014, 11:29 AM   #15
Lavalover
Drives: 2014 FR-S Monogram Hot Lava
Just to be clear the FR-S does have a fuel cut off that kills power at high rpms. Not sure if the adjustment to the indicator light affects the operation of this cut off, or is it just a warning signal.
Lavalover is offline   Reply With Quote
Old 06-08-2014, 12:06 PM   #16
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
7100. By the time the light comes on and going to make the upshift, should be 7300rpm.
hmong337 is offline   Reply With Quote
Old 06-08-2014, 01:24 PM   #17
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
7k rpm for me...see the shift indicator light and hear the beep every day...
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
Old 06-08-2014, 01:36 PM   #18
Maowc
EndlessClouds
Maowc's Avatar
Drives: 2013 Scion FRS
Take your dreams and smash it!
Maowc is offline   Reply With Quote
Old 06-08-2014, 01:46 PM   #19
J_kennington
Drives: 2013 asphalt scion FRS
its just a warning. it doesn't matter if you set it at 2000 rpms. at 7500 the car will cut fuel
2013 raven frs(dd/grocery getter)
1990 mitsu eclipse gsx(street/strip car)
1995 gmc 1500 4x4(off road toy)
2005 Yamaha yz250f
J_kennington is offline   Reply With Quote
The Following User Says Thank You to J_kennington For This Useful Post:
Lavalover (06-08-2014)
Old 06-08-2014, 03:14 PM   #20
Roadcone
StreetKart
Drives: 2014 Scion FR-S Monogram
good lord some of you people are slow to react... i have mine set at 7300..
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
Roadcone is offline   Reply With Quote
Old 06-08-2014, 04:49 PM   #21
LavosTRD
Toyota Master Tech
Drives: Whiteout MT
And people wonder why their transmissions grind....
LavosTRD is offline   Reply With Quote
Old 06-08-2014, 05:33 PM   #22
BRZ_Lawyer
Hardworking
BRZ_Lawyer's Avatar
Drives: 2013 Subaru Brz, 2013 C300 4Matic
I set mine at 3500 because I simply like to hear the beep, gives me the impression I'm revving hi. Note: I'm a daily driver, not a racer/tuner and have an automatic
Sent from my Nexus 4 using Tapatalk
Lawyer in NJ and Pennsylvania.
My BRZ gets me to court quick!
2013 WRB BRZ Limited
2013 C300 4Matic
Septa, NJtransit, MTA
BRZ_Lawyer is offline   Reply With Quote
Old 06-08-2014, 05:49 PM   #23
paulca
Drives: Toyota GT86 Coupe Red (UK)
Originally Posted by Mikem53 View Post
Then raise it... You want the peak torque to fall on the next gear when you shift..
Power is what you should base shifts on. Highest area under the curve.
paulca is offline   Reply With Quote
Old 06-08-2014, 06:15 PM   #24
chrisl
Drives: 2006 Cayman S, 2007 Outback 2.5i
Yep, and you want to shift when you are past peak power. Specifically, you want to shift so that you're making the same power in the next gear as you are in the current one. For example, if you're in a car that makes 200hp at 7krpm, 185hp at 7400rpm, 185hp at 6200rpm, and you lose 1200rpm when you shift at 7400rpm, you'd want to let it rev all the way out to 7400rpm before shifting. If you shift at the peak power point at 7000rpm, you'll drop down to ~5900rpm or so, where you'll be making less than 185hp, while if you delay the shift, you'll be making >185hp all the way up to 7400, and when you shift, you'll continue making 185+hp in the next gear as well.
(That doesn't mean you always want to shift at redline, just that you always want to shift past peak power)
chrisl is offline   Reply With Quote
Old 06-09-2014, 03:01 AM   #25
paulca
Indeed and a car gear box is correctly tuned when it hits peak power at it's top speed and cannot go faster, cause if it tries to the power starts to fall and it stops accelerating.
Obviously this depends on a load of factors, most notably air temp and pressure, hills, road surface, dry/damp etc.
Old 06-09-2014, 03:54 AM   #26
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
People look at the dash while getting their F&F on?
Old 06-09-2014, 09:02 AM   #27
DarkSunrise
DarkSunrise's Avatar
The way I had always calculated it is, you have to compare torque to the ground (i.e., multiplied through the gearing) in the two gears. So to determine the shift point for the 1-2 shift, you would compare torque to the ground in 1st gear at 7000 rpm vs. torque in 2nd gear at 4500 rpm. Then 7100 rpm vs. 4600 rpm. Etc.
When torque to the ground in 2nd gear exceeds the same in 1st, that is your optimal shift point. If 2nd never exceeds 1st, then you should shift at redline.
Because of the way gearing is setup in most cars, it ends up that the optimal shift point is at/near readline in the lower gears, but gets lower as you go up the gears.
2022 BRZ Build
2013 FR-S Build
Old 06-09-2014, 09:22 AM   #28
paulca
Remember that torque does nothing unless it "operates over rotation".
Throwing units out of it for simplicity.
Power output = Torque * RPM.
So DarkSunrise your method needs to take account of the drop in RPM the torque is applied at. (As above if you just forget the units and multiply torque directly by RPM is easiest). If you actually want "Watts" or "Horsepower" there are a few more complexities.
Examples....
200Nm torque @ 3,000rpm == 100Nm torque @ 6,000rpm.
200Mn torque @ 6,000rpm > 220Nm torque @ 4,500rpm.
In terms of power output, which is the energy transferred to the car in the form of momentum. aka Speed.
EDIT: And... if your engine is delivering 200Nm torque at 6,000rpm, regardless of what gear you are in or what size of wheels you have the actual power output at the wheels is the same. In a lower gear, you will just have higher torque applied at a lower rpm, same energy.
Fast / slow rev limiter??? Mike86 Engine, Exhaust, Transmission 19 09-09-2013 10:01 AM
Lets talk rev limiter. Method Engine, Exhaust, Transmission 7 06-13-2013 09:20 PM
Top/Speed limiter for the 86? DriftEightSix AUSTRALIA 4 09-12-2012 01:53 AM
Rev limiter? feldy Scion FR-S / Toyota 86 GT86 General Forum 4 06-03-2012 10:47 PM
<3 my rev limiter NESW20 Other Vehicles & General Automotive Discussions 1 05-02-2010 11:05 PM
