Old 06-07-2014, 02:07 PM   #1443
gramicci101
Off Topic
That's a question for @CSG Mike or one of the other race drivers, but I'll contribute. You don't want the car tuned to oversteer, but it'll oversteer anyways if you give it too much power in a corner. Think spinning doughnuts vs. carving circles. It's easy enough to crank the wheel over, floor the throttle and whip the rear end around into a spin. It's less easy to crank the wheel over, give it enough throttle to break the rear wheels loose, then counter steer and turn your spin into a sustained and controlled drift that goes where you want it to go. It's much less easy to turn in on the correct line, ease in just enough throttle that the rear end barely starts to come around, don't counter steer at all, and then hold your car on that line by using throttle inputs to rotate the car through the corner. That's what throttle steering is.
Old 06-07-2014, 02:39 PM   #1444
RFB
RFB's Avatar
Drives: FRS
Then that must be what I am already doing.
Thanx.
CERBERUS
RFB is offline   Reply With Quote
Old 06-07-2014, 07:30 PM   #1445
orthojoe
Originally Posted by jsimon7777 View Post
I did not cord mine but did warrant them through Michelin because they wore out in 11k street miles. They wore faster on the insides by 3mm or so. Stock alignment.
No way. Your alignment must have been screwed up or the tires were screwed up to wear out OEM tires on 11k street miles.
2013 Subaru BRZ
orthojoe is offline   Reply With Quote
Old 06-07-2014, 08:24 PM   #1446
becauseracecar1
becauseracecar1's Avatar
Drives:
Is it ok to push the pistons back with my fingers when changing back to stock pads after a track day? Thank you!!
2014 Ultramarine Scion FR-S
facebook.com/86motorsports
becauseracecar1 is offline   Reply With Quote
Old 06-07-2014, 08:43 PM   #1447
DatApex
Drives: 2013 WRB BRZ Limited
Haha, if you can. Good luck, though.
DatApex is offline   Reply With Quote
Old 06-07-2014, 08:51 PM   #1448
gramicci101
Off Topic
I use a wood clamp. Before you remove the caliper from the bracket, hook one end of the clamp behind the caliper and use a socket as a spacer on the bracket. Then you can just ratchet the clamp shut; it pushes the caliper pistons against the rotor and forces them back into the caliper. Since the caliper is sliding on its pins and it's pushing against the rotor, the pistons get pushed straight in and there's no chance of them getting cocked in their bores.
Old 06-07-2014, 09:00 PM   #1449
dp1
driving smoother faster
Drives: Sold
You can use a small crowbar wrapped in painters tape at the elbow and tip to prevent scratching metal bits when you push against piston edge
dp1 is offline   Reply With Quote
Old 06-07-2014, 09:35 PM   #1450
troek
troek's Avatar
Drives: 2012 Toyota 86
Sounds like the next step is for you to learn to drive while maintaining a good slip angle (on the oversteer side, not the understeer side), without actually countersteering. Essentially, throttle steering, which is, technically, a subset of drifting. This is a faster way to corner that most people never reach.
i see guys doing this on the 100r at fuji, while they pas me, lol. i wondered if it was my eyes playing a trick on me or not.
troek is offline   Reply With Quote
Old 06-07-2014, 10:26 PM   #1451
CSG Mike
CSG Mike's Avatar
Originally Posted by RFB View Post
Interesting. My FRS it is balanced and neutral through the corners, no tendency to under or oversteer.
Im tracking the Mosport Gran Prix track next week (long high speed straights and corners).
Any tips on how to better throttle steer ?
CERBERUS
If there's no tendency to under or oversteer, then you still have tire grip left. Enter the corner faster and/or give the car more gas mid-corner, and power out earlier.
Throttle steer? You need a near-neutral car to do it. You literally... press on the gas more until your car starts rotating mid corner, and you control that rotation with the gas pedal.
Having an aftermarket LSD makes this throttle steer window substantially larger.
CSG Mike is online now   Reply With Quote
Old 06-07-2014, 10:27 PM   #1452
CSG Mike
CSG Mike's Avatar
When I hit a corner harder my rear does not fish tail. All 4 tires screech and the whole car slides slightly outward off my intended apex line. Letting off on the throttle (if I haven't gone too far) gets me back.
Does that mean I am throttle steering ?
CERBERUS
That's understeer.
Thanx.
CERBERUS
See above...
Old 06-07-2014, 10:28 PM   #1453
CSG Mike
CSG Mike's Avatar
When I don't hit the corner harder and push harder through the corner the rear end does not oversteer.
I can tune the car for oversteer with tire pressure but I'm slower (always correcting for fish tail).
What would I do to be faster with oversteer ?
And no I don't experiment with close walls LOL !
CERBERUS
You're tuning the car for oversteer by reducing rear tire grip. Instead, you want to increase front end grip. How you do this varies.
Old 06-07-2014, 10:29 PM   #1454
CSG Mike
CSG Mike's Avatar
If you can, it means your caliper is in great shape!
Old 06-07-2014, 10:30 PM   #1455
CSG Mike
CSG Mike's Avatar
A common setup we get requested is a car that oversteer at low speed, where risk is low and the car is easy to manage, and understeers at high speed, where risk is higher.
This way, you can easily rotate around the low speed stuff, and have confidence in the high speed stuff.
I consider a neutral car one where you can dictate whether you under or oversteer, at will with steering or weight transfers, and can be throttle steered. A car with a ton of power that uses that power to oversteer is not necessarily a neutral car. Any car with big power can break tires loose.
Old 06-07-2014, 10:32 PM   #1456
CSG Mike
CSG Mike's Avatar
Those guys are serious drivers
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
