Old 06-06-2014, 03:49 PM   #1429
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
Originally Posted by Admired View Post
So I was able to make 305 WHP on the dyno with my kit with 93 gas, 450cc injectors and fuel pump. My question is, can more power be generated from this kit because the tune was at 9 psi so I am assuming I can run a higher pressure? Now by doing this, if I were to raise the boost pressure would I need to get it retuned at that pressure or how does this work? My goal is 350+ or 375 if possible. What do I have to do to achieve this? New internals or just increase boost pressure? Thanks guys
for what its worth, my avo kit on e85 with 700cc injectors is at 86% injector duty cycle @400whp. on 93 octane, the average "safe" numbers seem to be around 320whp. again, i said average for the cars that have been running that power for a while. some are higher, some are lower.
e85 is pretty much needed to make higher power with the 12.5:1 compression ratio and proper timing. but also, e85 needs much more fuel so you need a decent amount of injector and 450cc probably wont cut it on corn
Old 06-06-2014, 03:51 PM   #1430
Admired
Drives: 2013 Scion FRS
So to achieve 350+ on 93, what is required? Larger injectors and just higher boost or internals too?
Admired is offline   Reply With Quote
Old 06-06-2014, 03:52 PM   #1431
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
You wont get over 400whp on e85 with those injectors. I had 550s and had problems over 400
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Old 06-06-2014, 03:55 PM   #1432
Admired
I'm not sure if your talking to me, but I am looking for 350+ on 93.
Old 06-06-2014, 03:56 PM   #1433
spitfire481
Drives: 2JZ FRS
you might be able to get it on 93 with stock internals, id just be weary of the timing pulled out of it to keep it from knocking. i limited my car to 300whp on 93 because the high compression is kind of iffy as far as knock is concerned. i am not a tuner, so dont take my word 100%, but i do have a decent understanding as to what im talking about. dropping the compression of the motor would allow you to make great power on 93 with higher boost levels
Old 06-06-2014, 03:56 PM   #1434
Reaper
Reaper's Avatar
Drives: violent
Wont happen reliably without e85 or new pistons
Old 06-06-2014, 03:59 PM   #1435
Admired
Ok so new pistons is the answer, maybe something like the full blown shortblock?
Old 06-06-2014, 04:01 PM   #1436
Reaper
Reaper's Avatar
Drives: violent
Yup.
Old 06-21-2014, 06:51 AM   #1437
Dan@AWD
Drives: 2013 Argento FR-S
Upgrades
Well my car was down for a while with a spun rod bearing.
Looking to get to get it back on the dyno soon.
Upgrades from the old setup:
  • Full Blown Walbro 485 Fuel Pump Kit
  • Full Blown Single Exit 3"
  • AEM AFR & Boost Gauges
  • New Non Restrictive K&N Air Filter
Dan@AWD is offline   Reply With Quote
The Following User Says Thank You to Dan@AWD For This Useful Post:
lbroskee (06-21-2014)
Old 06-21-2014, 07:10 AM   #1438
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
So you decided to keep your kit. You should close your FS thread.
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
Old 06-23-2014, 02:23 PM   #1439
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
You have a nail in your tire it appears.
alpine (06-24-2014)
Old 06-23-2014, 02:27 PM   #1440
Dan@AWD
Yeah. I know about it.
Old 06-23-2014, 03:42 PM   #1441
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
slowly creating snow tires dude
lbroskee is offline   Reply With Quote
Old 06-24-2014, 09:50 AM   #1442
BadBRZ
Drives: Subaru
Dan, are you doig all your own tuning?
BadBRZ is offline   Reply With Quote
0-60 in 22million sec, beam, best of all, doyen done done it again!, fa20club header, fa20club.com, fa20crap, fa20crud.com, frs turbo kit, i like turbos, turbo frs, turbo kit, turbocharged brz, visconti 2.0?, welding4noobs, www.p&lclub.com, you'llneedamuletoride
FA20CLUB TURBO KIT T3/T4 60 86pro Forced Induction 50 07-26-2014 11:48 AM
Fa20club turbo install issues Mikegraves777 Forced Induction 8 07-25-2013 12:56 AM
FA20CLUB 60 Trim Turbo 16 PSI Results Are In FA20Club.com Forced Induction 148 07-22-2013 08:00 PM
FA20CLUB V2 Turbo Kit Progress FA20Club.com Forced Induction 40 05-17-2013 01:26 PM
