#71 |
Drives: Neptune GR86
That's what I assumed.
#72 | ||
Drives: '13 BRZ Ltd
I had the rush of air sound, like a flutter or air pulses of exhaust. Only under load, couldn't replicate at idle or idle revving. At first I thought it might just be "header noise" due to thinner walls, aftermarket, etc, but it sounded too much like a leak to me. Couldn't feel any leaks during idle (held up thin plastic to see if it wavered anywhere at the joints), didn't find anything. Removed the header, checked gaskets, and there were soot blowby marks on 2 of the 3 gaskets (header/overpipe and passenger side header/engined). This was evident after only a day of driving. I used all new gaskets and torque'd to spec. The car also seemed sluggish. I'm in the process of contacting Borla. Luckily the swap is so easy that removing/replacing is not a big deal. |
#73 | |
I'll check mine out tomorrow. I've had it on for about 2 weeks so I'm assuming it should be fairly obvious to see the soot if there is any. Let us know how the contact with Borla goes.
#74 | |
Drives: DGM BRZ 6MT
For me, it seems like the whooshing sound is coming from the right of where I'm sitting. I suspect it might be where I unbolted the front pipe from the midpipe to push the pipe back to pull the headers out.
#75 |
Drives: '13 BRZ Ltd
Oh, after 2 weeks it will def be noticeable if there is anything. I think I drove about 50 miles total lol
#76 | |
Drives: '13 BRZ Ltd
#77 |
Checked mine out, didn't see any signs of soot where it shouldn't be.
Tightened everything back to spec, went for a drive and it seemed less pronounce. Probably just placebo since I just tightened it all, I dunno.
#78 |
Drives: DGM BRZ 6MT
I just checked the gaskets. Same here. No soot where it shouldn't be. Bolted everything back up and torqued to spec. Took my car for a ride and the sound is still there, louder than ever. I guess it's just a part of how it is. I'll have to learn to live with it.
#79 | |
Drives: '13 BRZ Ltd
#80 |
My gaskets were clean, just the typical color change from heat.
#81 | |
Drives: DGM BRZ 6MT
![]() ![]() I did a lot of searching on this whoosh sound. Some possible reasons may be the shape of the flex-joints deflecting the air a certain way, or the more likely reason, the thin tubing of the Borla being less effective at sound deadening than the OE headers. I did hear from one guy who switched from Borla to some other header commented on how thin the Borla headers are compared to others. The next time I'm under the car, I might check around the welds and see if there are any leaks there. If you're still unsure, you can go to an exhaust shop and have them test for leaks.
#82 |
Drives: FRS Argento 6mt
Do we absolutely have to use a 02 sensor wrench? If we unplug it and drop the header can we just use a 22mm box end wrench?
#83 |
You don't have to If you have the appropriately sized wrench.
#84 |
Drives: '18 STi
Just out of curiosity, is it recommended to install a brand new header (UEL in this case) along with an overpipe at the same time? If not, would it be fine to simply install an aftermarket catless header while keeping the stock overpipe? I know for a fact an aftermarket overpipe isn't going to give any significant or noticeable horse power improvement over the stock overpipe, but is it worth it to upgrade to an aftermarket overpipe (performance wise)? Is it worth it to spend a couple hundred bucks on an overpipe for slightly better flow- is my real question. (I feel like this second question is redundant and voids my aforementioned question lol) Comments, suggestions, and opinions are greatly appreciated!
| Tags |
| borla, header, unequal length |
| Borla UEL Header - Pics / Videos / Dynos - FT-86 SpeedFactory Review | FT-86 SpeedFactory | Engine, Exhaust, Transmission | 533 | 04-01-2015 12:10 AM |
| >>>>Rev Works UEL (Unequal Length) Header - Specs, information, & Customer Review<<<< | Rev Works | Engine, Exhaust, Bolt-Ons | 917 | 08-04-2014 11:52 PM |
| BORLA UNEQUAL LENGTH HEADER NOW IN STOCK @ NINJA AUTOSPORTS!!! | NJA | Announcements, Contests, Giveaways | 6 | 04-03-2013 05:47 PM |
| unequal length headers | 001BRZ | Engine, Exhaust, Transmission | 10 | 07-21-2012 01:20 AM |
