Old 06-05-2014, 11:35 AM   #757
JMoore412
Drives: 2014 Scion FRS, 2014 GTI, 2013 Golf
I have been reading a lot and wondering if anyone knows if a 18x9.5 +40 will fit up front with a 255/35? I just have lowering springs and Bilstein shocks. Spent most of the night reading up on this and found some that say they will fit and others say I have to have coil overs to make this work. Looking for a solid answer on this.
JMoore412 is offline   Reply With Quote
Old 06-05-2014, 12:38 PM   #758
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
It will be close. This is the best picture I have to give you an idea of what an 18x9.5 +40 wheel looks like in the front:
It all depends on how the tire ends up sitting on the wheel.
Old 06-05-2014, 12:48 PM   #759
sdemo
sdemo's Avatar
Drives: '13 SWP ZC6 R
^ Also depends on how you're achieving camber. If it's via camber bolts in the strut / knuckle mounting point, then your wheels will be closer to the strut. If it's via adjustable top hat, you maintain more clearance.
I really don't see 255/35/18 on 18x9.5 +40 fitting well with stock struts.
sdemo is offline   Reply With Quote
Old 06-05-2014, 01:28 PM   #760
JMoore412
I think I might just take the safe road and go with 245/35 all the way around or go with the 245/35 in the front and 255/35 in the rear. From reading most are saying not to go with a staggered setup so that leaves 245/35 all the way around. Which from what I have gathered will work without any problems with just lowering springs someone please correct me if I am wrong.
Old 06-05-2014, 01:41 PM   #761
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Here are a couple more photos of 18x9.5 +40 with the stock struts. It's pretty close.
HRTROB is offline   Reply With Quote
Old 06-05-2014, 02:11 PM   #762
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
Originally Posted by z3ro View Post
What about meatier tires in the other direction; height? I'm thinking about dropping down to 16" rims (Sparco Terras) and doing a taller tire to get a more rally-esc look. Opinions?
I've done it with two different tires and 16" rims and it seems to go fine.
BRZZZZZZZZZZ is offline   Reply With Quote
Old 06-05-2014, 02:12 PM   #763
JMoore412
That is pretty close what size tire are you running? I have the Bilstein B8's struts and not the stock ones and will be using Swift Spec R springs.
Old 06-05-2014, 02:23 PM   #764
JMoore412
My biggest issue is the car is the car isn't at the house and don't have a way to check before it goes to get them put on. So trying to figure everything out without having the car in hand which is a PITA and stupid but not much of a choice.
Old 06-05-2014, 03:49 PM   #765
z3ro
Pic's?
z3ro is offline   Reply With Quote
Old 06-05-2014, 03:52 PM   #766
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Your other option would be run the 255 and if it is too close, then go with a 5 mm spacer.
Old 06-05-2014, 04:26 PM   #767
Kdej1
Colten Drew
Kdej1's Avatar
Drives: '13 Fr-s // '95 Civic // '09 Vette
Originally Posted by Jive Turkey View Post
changing to a 265+ wont necessarily give you more traction. it all depends on your suspension/alingment all in combination with the kind of tire you're using.
better to have a 245-255 in a great tire (mpps/zII/RE11/rivals..etc) thant a 265-285 in a not so good tire.
Originally Posted by SmsAlSuwaidi View Post
What @Jive Turkey said is correct ! Most my buddies running over 350whp and 3xx torque cant hook up 275/265, while i have 255 r compounds and hook up perfectly
Sent from my IBrick
Sticky tire also falls in to play with the suspension, alignment and so on when you're on the quest for more traction.. Reason I would be getting 265s is simply because the tires I would be getting are offered in 245/40/18 or 265/40/18 and I definitely would not step down to a 245. The more rubber on the ground the better it will help if you're comparing the same suspension setup with the same type of tire.. And if I were to build my engine, I probably wouldn't stop until I was 650+..
Kdej1 is offline   Reply With Quote
Old 06-05-2014, 08:17 PM   #768
mfbmike
Drives: 2013 FRS, 2008 R32
Originally Posted by mkivalex View Post
Do you guys find a 265 is "too much tire" for stockish power levels. Im looking at doing the NT03's on 265/35/18's I love the look and would love the endless amounts of grip. I will probably up the power to hit around 200WHP, but do you guys find its too much tire, and can be a negative?
18x9.5 NT03's on 265/35 Michelin PSS
Nope, not too much.
Wheel are for sale btw.
mfbmike is offline   Reply With Quote
Old 06-05-2014, 08:55 PM   #769
mkivalex
Drives: 13 Scion FRS, 93 JDM Toyota Supra
Actually looking for nt03s but looking for black and shipping to canada will be brutal
mkivalex is offline   Reply With Quote
Old 06-05-2014, 11:07 PM   #770
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
This may only register 4.0 on the meaty Richter Scale but it's my meaty. Kosei K4R 17x8 with 245/40/17 Continental ExtremeContact DWs. Also lowered an inch with Bilstein B14s.
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
The Following 2 Users Say Thank You to Apoc For This Useful Post:
Jive Turkey (06-06-2014), Khyron686 (06-09-2014)
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 06:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 07:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 01:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 02:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 04:05 PM
