Old 06-05-2014, 04:36 PM   #729
BennyBRZ
Drives: 14 BRZ Limited - DGM
Can anyone who has installed the oem usb adapter [ame="http://www.amazon.com/gp/product/B00EAYYQDO/ref=oh_details_o04_s00_i01?ie=UTF8&psc=1"]Amazon.com : Axxess by Metra AX-TOYUSB USB Adaptor to Retain the OE USB in Select Toyota/Lexus Vehicles : Vehicle Audio Video Power Adapters : Car Electronics[/ame] help me out?
I pulled my usb plug but it doesn't fit. Any help would be appreciated.
BennyBRZ is offline   Reply With Quote
Old 06-05-2014, 04:44 PM   #730
BennyBRZ
Originally Posted by enjoi23 View Post
Also I'm completely wire illiterate. How do we hook up that amp wire to the stock harness? I try pushing it in but it doesn't fit lol. Can anyone take a picture of what it looks like?
I took Shifter's advice earlier in the thread and used the SWC wire that's not needed. Basically clipped it in half and pulled the wire from the end connector (the white end).
Pin 9 on the Ca-fi harness isn't used so I put the SWC wire into that spot and then used solder to connect the end of that wire with the blue amp wire.
Good to go and doesn't require any modification of the stock harness.
Old 06-05-2014, 05:13 PM   #731
psyke
Drives: Toyota GT86
Originally Posted by DC2R View Post
USB on the go is to connect full size USB to micro USB. What are you trying to accomplish?
Sent from my SM-G900T using Tapatalk
USB otg:
[ame="http://en.wikipedia.org/wiki/USB_OTG"]USB On-The-Go - Wikipedia, the free encyclopedia[/ame]
I am thinking about buying this dashlinq, because the oem headunit does Not have a linear frequency response and is equalizing the lower frequencys depending on the Volume. Sure i could buy any alpine Double DIN Unit and would be done with it., but i would like to Keep the oem-Look.
But i am Not absolutely sure if the dashlinq is not also non-linear.... So a Solution would be to Hook up an external USB sound Card to the dashlinq. So i would get a android hu with a perfect frequency Response.
Some android tablets are Working with These Cards, the Nexus for example.
psyke is offline   Reply With Quote
Old 06-05-2014, 05:14 PM   #732
DC2R
Drives: 2014 Scion FR-S
Originally Posted by morphius88 View Post
Got my unit yesterday. 2 weeks went by before they shipped it out. I guess they have many orders. Anyways, got everything installed thanks to Shifter and others for their posts in this thread. Helped alot.
My question/problem:
I read there was an update out and I was unable to find it on their site, so I found it here. How do I know my unit isnt updated already since it was shipped out after the update came out?
Heres a pic of what mine is running:
Also, yesterday I paired my phone with the device thru bluetooth and the music played fine. Today I turn it on and its skipping. I tried restarting the app, as well as restarting the unit (not resetting). Any ideas?
Just checked. You are running the latest updates
DC2R is offline   Reply With Quote
Old 06-05-2014, 05:25 PM   #733
DC2R
Bought this sucker a month ago but never actually shipped and seller unresponsive. Any other recommendations? The one i have doesn't work
Old 06-05-2014, 06:23 PM   #734
Deathalo
Drives: 2013 WR Blue Limited Manual BRZ
Originally Posted by BennyBRZ View Post
Can anyone who has installed the oem usb adapter Amazon.com : Axxess by Metra AX-TOYUSB USB Adaptor to Retain the OE USB in Select Toyota/Lexus Vehicles : Vehicle Audio Video Power Adapters : Car Electronics help me out?
I'm not sure exactly what I'm looking at with that picture, but I know USB was the easiest thing to hook up. You unplug the USB hookup from the old HU, plug that into the adapter you bought, and then plug the USB end into the USB in on the new HU. It's simple and easy.
Deathalo is offline   Reply With Quote
Old 06-05-2014, 06:24 PM   #735
Deathalo
Huh?
Old 06-05-2014, 06:53 PM   #736
DC2R
Originally Posted by Deathalo View Post
Huh?
Lol link didn't go through
[ame="http://www.amazon.com/gp/aw/d/B008U1MOM8/ref=redir_mdp_mobile?redirect=true&ref_=ox_ya_os_p roduct_refresh_T1"]iSaddle Super Mini ELM327 V1.5 OBD2 OBD-II Bluetooth CAN-BUS Auto Diagnostic Tool for Windows XP, Vista, Win7, OSX and Android:Amazon:Automotive[/ame]
Old 06-05-2014, 06:56 PM   #737
morphius88
R0GUE
morphius88's Avatar
Drives: 2013 Whiteout Scion FR-S
Huh?
I dont think you got the correct harness.
Sent from planet Mars using HTC One
morphius88 is offline   Reply With Quote
Old 06-05-2014, 07:03 PM   #738
BennyBRZ
Thanks guys, I thought it was wrong since it should just plug into the oem harness for the usb port.
Be careful if you order this from amazon as there are multiple sellers of the item.
For reference, mine came with a brown boot and plug which I pulled it off for that picture.
Old 06-05-2014, 07:35 PM   #739
dabocx
dabocx's Avatar
Drives: Scion FRS
Hopefully oem audio supports this unit and it sees a update to 4.4
dabocx is offline   Reply With Quote
Old 06-05-2014, 09:50 PM   #740
Prog
Prog's Avatar
Drives: 2016 Cadillac CTS
Is that a picture of the adapter you bought or the stock plug in your car? It looks like you pulled the cable out of the port?
Prog is offline   Reply With Quote
Old 06-05-2014, 09:52 PM   #741
SilverlightPony
SilverlightPony's Avatar
Drives: '13 Subaru BRZ, '06 Toyota 4Runner
Someone here sent their Dashlinq4 to OEM Audio so they could work on making a DSP amp firmware tuned for it.
Is there any word on that, btw? That was a while ago.
SilverlightPony is offline   Reply With Quote
Old 06-05-2014, 11:05 PM   #742
Orisai
Drives: Hyundai ix45
I went into the build.prop to change those lines, but they weren't there, I added them and put them as false but nothing changed. I realize that the Radio's built in EQ still works, so that's probably blocking Viper somehow (kinda like Poweramp did before turning it off in the settings), it's ok though, since every other app works with Viper; Slacker, Pandora, TuneIn, Poweramp, so the radio I can live with using the regular EQ.
In fact, it's working as intended. FM/AM radio tunning is done through a tuner chip, which is handled by the Radio app itself, instead of Android like in a music player or Internet radio (Pandora, TuneIn, etc). When you have the FM radio app open, it channels it's audio directly to the MCU, then to the speakers.
Sorry I thought it was a Music app that didn't work with the Viper EQ.
Orisai is offline   Reply With Quote
REVIEW: Ca-Fi Toyota Universal - Stock Fitment ANDROID Stereo SHIFTER Electronics | Audio | NAV | Infotainment 16 06-13-2017 06:23 PM
Android, bluetooth, Music, and the FR-S stock pioneer stereo JayNutter Electronics | Audio | NAV | Infotainment 27 12-18-2014 03:54 AM
How to: Torque on an android powered stereo with no hacking v. Ca-Fi Dashlinq4 SHIFTER Electronics | Audio | NAV | Infotainment 29 04-07-2014 04:58 AM
