Old 06-04-2014, 11:59 PM   #1
zERoTu
Drives: 1st RBv2 10 Series FRS
clutch/gear box getting softer
its getting way to soft for my liking, is this normal?
what i feel is like, if someone doesnt know how to drive a standard car, they probably can with my car.
there is no play for the clutch. the clutch isnt slipping cause it pulls well.
its the initial engagement of the gear and the clutch.
hmmmmm....time to change clutch? its at 17,xxx kms
zERoTu is offline   Reply With Quote
Old 06-05-2014, 12:01 AM   #2
jhh3000
Drives: BRZ Limited 6MT
Mine's at 17k miles and I'm getting the same feeling. And a lot more play in the diff. Like clunking from gas off to gas on at low rpm in gears 1-4. Maybe it's just drivetrain wearing in.
jhh3000 is offline   Reply With Quote
Old 06-05-2014, 12:03 AM   #3
zERoTu
I have a diffbrace. Dunno if that's actually making it worst or not though. maybe syncros????
Old 06-05-2014, 08:18 AM   #4
SportInjected
SportInjected's Avatar
Drives: for the sake of driving
It's just parts wearing in. You can remove the clutch return spring to gain some stiffness back in the clutch pedal.
'13 Argento FR-S
SportInjected is offline   Reply With Quote
The Following User Says Thank You to SportInjected For This Useful Post:
zERoTu (06-05-2014)
2nd gear grind while slowing down NO clutch Muskokan Issues | Warranty | Recalls / TSB 12 07-18-2017 01:35 PM
Display current gear without clutch engaged? cfusionpm Scion FR-S / Toyota 86 GT86 General Forum 45 03-26-2013 04:08 PM
Clutch Masters Clutch Kits | Island Import Performance IslandImportPerformance Transmission and Driveline 1 07-20-2012 12:06 PM
Transmission rattle while revving in gear with clutch both engaged and disengaged robo_robb Engine, Exhaust, Transmission 2 06-16-2012 01:35 AM
