Old 06-04-2014, 06:17 PM   #57
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
I'm tuning RehabJeff's car on the dyno right now
Shiv@Openflash is offline   Reply With Quote
Old 06-04-2014, 08:26 PM   #58
FrsDuke
Fanboy
FrsDuke's Avatar
Drives: 2013 ultramarine frs
Any chance we may see an off the shelf variant of this tune down the line? I'm extremely eager to see your results! Rehabjeff have power blocks by chance?
I'm done helping those who won't help themselves.
TL;DR:
-Duke
FrsDuke is offline   Reply With Quote
Old 06-04-2014, 08:58 PM   #59
Shiv@Openflash
Drives: 2013 FRS
That's up to RehabJeff. He paid for custom tuning so the results belong to him. Yes, he was running power blocks
Old 06-04-2014, 10:23 PM   #60
Deathreaper
Drives: 2013 Scion FRS
were you guys able to replicate the torque mountain?
Deathreaper is offline   Reply With Quote
Old 06-04-2014, 10:26 PM   #61
FrsDuke
Fanboy
FrsDuke's Avatar
Homeboy needs a kickstarter
TL;DR:
-Duke
Old 06-04-2014, 10:42 PM   #62
Shiv@Openflash
Drives: 2013 FRS
I don't know what constitutes are torque mountain but torque is reasonably flat from ~3500 and up. The torque dip is still there but it's been moved downwards a few hundred RPM. So the 2500-3500rpm range is relatively weak compared to other headers (or even stock header). But it does well in the 3500-4000rpm range, where most other headers have their dip. Up top, it's comparable to other headers we have tested. The one interesting bit is that it needs 3 back to back runs to make max power. The headers does need to get some heat into it. It was ceramic coated FWIW
Also worth mentioning that the OTS Stage 2 EL map was pretty spot-on. The only significant gains I could muster after 1.5 hrs of dyno tuning was in the torque dip area (made it a bit narrower). AFR and timing was already pretty spot on.
Cheers,
Shiv
Old 06-04-2014, 10:58 PM   #63
RehabJeff86
RehabJeff86's Avatar
Drives: 2013 WhiteOut FR-S
Hi, to all Nameless header + BPB forum members,
The car feels great after the custom tune, much smoother in low end power and torque.
Per Shiv - he will be releasing an OTS soon
2013 Scion FR-S whiteout
2012 Porsche Panamera S carbon grey
2008 Range Rover Sport SS black - sold
2004 BMW M3 alpine wies - sold
RehabJeff86 is offline   Reply With Quote
Old 06-04-2014, 11:47 PM   #64
Sargy
Long Distance Driver
Sargy's Avatar
I would love to share this file as OTS on Vishnu Website, it would be greatly appreciated if the cost of the custom dyno by Shiv can be covered - of course not fully, I have to pay for my share as well.
Im OK for Shiv to post the Dyno graphs from today's tuning, but as for now, I will keep the tune file discretely to myself.
Im just not sure how to work this out, any suggestions are welcome!!
are you running E85 Stage 2 custom? I just payed for custom e-tuning and will be doing nameless header, trd intake, motiv overpipe, motiv catted front pipe, stock mid pipe and trd quad axleback on e85.
great to hear a smoother low end power+torque. thats mainly what I wanted!
the low end grunt gets wonky at times. after repeated runs it gets better after getting some heat in
Sargy is offline   Reply With Quote
Old 06-05-2014, 01:30 AM   #65
RehabJeff86
No, Im running 91 octane! If you do E85 you will completely eliminate the torque dip i think - i will let Shiv to clarify that.
Old 06-05-2014, 01:36 AM   #66
Sargy
Sargy's Avatar
Well then... this should be interesting. I will be emailing logs back and forth for a bit.
Old 06-13-2014, 02:52 PM   #67
Brahsbrah
Drives: 2013 BRZ Sport Tech White Pearl
My Nameless headers should be arriving this Tuesday. Off next weekend, and headers are definitely going on. I probably won't be able to wait until the weekend though and try and do the install the night I get them who am I trying to kid.
Brahsbrah is offline   Reply With Quote
Old 06-23-2014, 09:07 PM   #68
Brahsbrah
Currently running OFT Stage 2 EL with the nameless. Definitely more power everywhere in the revs. The punch at 3800 is niiiice right to redline now. 3rd and 4th especially seem to pull a lot harder in higher rpms.
Old 06-23-2014, 11:33 PM   #69
Syklonious
Syklonious's Avatar
Drives: GT86 Grey 6Mt
I was running the Oft stage 2 e85 with the nameless header. it was fantastic!! I have switched back to the 98 tune now because my closest e85 station was about an hour away. the 98 tune is a massive improvement over stock but the e85 tune was phenomenal! My girlfriend said "the whole car feels lighter" that summed it up pretty well i think
Syklonious is offline   Reply With Quote
Old 06-26-2014, 10:44 PM   #70
Brahsbrah
I think she really did sum it up well even for the stage 2 91 octane.
OpenFlash Header Shiv@Openflash Engine, Exhaust, Bolt-Ons 2334 06-14-2016 08:37 AM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 05:42 PM
INTRODUCING ***VISHNU*** OPENFLASH HEADER FOR FR-S/BRZ Garrett@Openflash Engine, Exhaust, Bolt-Ons 7 12-19-2013 06:37 AM
OpenFlash Header Ride Along Video Rombinhood@OpenFlash Engine, Exhaust, Transmission 26 12-04-2013 03:08 PM
FS: Borla EL Header & Openflash Unit toekneehair Engine, Exhaust, Bolt-Ons 12 11-25-2013 04:38 PM
