Old 04-03-2012, 12:25 PM   #1
robotvoice
Drives: 07 STI
Rear Fog Light Thread
I haven't seen any specific threads for this yet so I thought I would make one.
The BRZ/FR-S will be equipped with a rear fog light in countries where cars are required to have one (like those in Europe) and the US versions will get a non-functioning reflector in its place. The light is located in the red upside-down triangle on the rear bumper between the reverse lights:
Since US regulations don't require rear fog lights on our vehicles here, not many people know what this light is actually for. The entire purpose of a rear fog light is to make it easier for drivers behind you to judge where your car is in bad weather. It's as simple as that. It's also not a good idea to drive with this light on in clear weather because it actually becomes very distracting for other drivers on the road because it runs at the same brightness intensity as your brake lights.
Some people will try to incorrectly wire the rear fog light as an additional brake light. While this doesn't hurt anything, that is not what the light is intended for and your car is already designed from the factory with more than enough brake lights.
Hopefully this thread will help provide some info for those looking to make their rear fog light functional. Some members have verified that there is an empty spot for a bulb in the rear fog so it should be fairly easy to wire the light up.
robotvoice is offline   Reply With Quote
The Following 2 Users Say Thank You to robotvoice For This Useful Post:
akrazor (06-04-2012), Fly Guy (06-22-2012)
Old 04-07-2012, 05:58 AM   #2
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
Is it turned on via a switch/button or does it automatically come on with the fog lights or headlights?
Bristecom is offline   Reply With Quote
Old 04-07-2012, 06:12 AM   #3
Kunzite
Drives: Toyota Auris
You should have a "fog switch" with 3 positions: Off, front and front+back; or Off and front, for US (in Europe, the front fog light can be missing, which means Off and back)
The car's headlights (low beam) must be On, afaik, for it to work.
Kunzite is offline   Reply With Quote
Old 04-07-2012, 07:32 AM   #4
Saibot
Saibot's Avatar
Drives: 01 Toyota Corolla / Porsche 911 C2
I see these on lots of JDM YO! cars lol
Saibot is offline   Reply With Quote
Old 04-07-2012, 11:47 AM   #5
azian_advanced
*****istrator
azian_advanced's Avatar
Drives: 2013 Scion FR-S 10-Series M/T
i imagine it being just like the IS300. just a push-button on/off switch. i've only used mine a couple of times. but it's nice that it's mounted low, close to the ground, where visibility is at its best during foggy conditions.
azian_advanced is offline   Reply With Quote
Old 04-07-2012, 12:18 PM   #6
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
It seems like a pretty pointless regulation when you consider the two (much brighter) LED taillights that already pretty low and would be lit under limited visibility conditions.
Ill pass, but some nice LED reverse lights will be considered.
chulooz is offline   Reply With Quote
Old 04-07-2012, 12:35 PM   #7
robotvoice
Drives: 07 STI
I'm not 100% sure about the BRZ yet but in the 08+ Imprezas, the Euro rear fog is turned on and off from the stalk where you would turn your regular fog lights on and off so I am assuming it might be the same for this car. The Euro stalk is a little expensive though so I wound up wiring mine to turn on with my front fog lights.
Rear fog lights operate at the same brightness of your BRAKE lights, not your regular running lights in your tails, so actually the rear fog is MUCH brighter than the regular tails...hence the reason they are used in bad weather.
Old 04-07-2012, 03:09 PM   #8
Kunzite
and that's also the reason why they should never be used in good weather.
Old 04-07-2012, 06:27 PM   #9
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
I plan to turn that into a "Rain Light". I stuck my head under the bumper of a BRZ demo that's rolling around. It still had a reflector inside and it looked like it just didn't have the hole for the Bulb socket cut out. Should be rather easy to wire up.
Old 04-07-2012, 10:10 PM   #10
robotvoice
Drives: 07 STI
Absolutely correct, it's actually pretty distracting in clear weather at night.
Very cool, I didn't know if anyone had looked under there yet. It sounds like we're going to have to get the EDM/JDM light to be able to put a bulb in and wire it up correctly. The GR STI sedan guys have to do this as well if they want to run a rear fog.
Old 04-09-2012, 05:08 PM   #11
Lighting Red
Habitual Line Crosser.
Lighting Red's Avatar
Drives: ^ Two of my favorite things.
My little brother has an 2007 MINI Cooper S with the rear fog lights factory fitted. The rear fog lights are actually brighter than the brake lights. I have driven behind him during heavy rains, and those rear fogs are AMAZING! I would like to find out if the bulb MINI specifies for their rear fog light would work on the Subaru.
I think swapping the reverse lights for LEDs and inclusion of the rear fog lights would be my first modifications. The reverse lights are not very powerful, and since they are so low I am afraid those conditions may contribute to other drivers not seeing that I am backing up.
But, but, but... It's only 200 hp?!
Lighting Red is offline   Reply With Quote
Old 04-09-2012, 05:12 PM   #12
Lighting Red
Call me intolerant, but in general I think people who use fog lights when the weather conditions do not call for it should be shoed in the nuts or ovaries. Especially if it's use of the rear fogs that are being abused. In nice weather they are annoyingly bright.
The Following User Says Thank You to Lighting Red For This Useful Post:
Ayrton (08-01-2015)
Old 04-10-2012, 06:51 AM   #13
[M]
[M]'s Avatar
Drives: Toyota Celica GTS
I've never had a reverse fog before, I may have this be one of my first additions just to see.
[M - Subaru BRZ]
[M] is offline   Reply With Quote
Old 04-10-2012, 09:52 AM   #14
LSxJunkie
LSxJunkie's Avatar
Drives: Car
This. I was stuck behind a 2011 Cayenne with its rear foglights on 2 nights ago. Mind you, those fog lights are in the taillight housing, right below the brakelights and are at eye level. It looked like he was riding the brake and his CHMSL was out until he hit the brake and I was actually dazzled by the amount of light coming off the back of his car. Asshat.
LSxJunkie is offline   Reply With Quote
The Following User Says Thank You to LSxJunkie For This Useful Post:
Ayrton (08-01-2015)
Third brake light...(top mount) Slide Cosmetic Modification (Interior/Exterior/Lighting) 103 02-22-2017 03:47 PM
Red tail light photoshops OwenK FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 68 02-06-2013 04:48 PM
Odd question: License plate light? Double4Free Scion FR-S / Toyota 86 GT86 General Forum 23 02-20-2012 09:29 PM
Subaru FT86 still not have the green light! ft86cbx Scion FR-S / Toyota 86 GT86 General Forum 23 07-08-2011 05:57 AM
FR-S Rear brake light... MF_DEUCE FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 70 05-05-2011 04:53 PM
