Old 06-03-2014, 10:01 PM   #1849
steve99
Drives: FT86
Originally Posted by jdv14476 View Post
Yep, key fully on. And if I try to start it, I don't even get a click. Nothing at all.
Is there a sensor or something that I might have accidently unplugged while changing the air filter? Guess I'll be calling Toyota tomorrow, rather not.
eeek, that dont sound good at all. was car running before you attempted to flash ?
the only sensor that you might have disturbed was the maf sensor in the tube at back of filter box but unlikely.
no chance you disturbed cable or turned off during write ?
it sounds like it went to write and failed, unfortunatly first process before write is to erase rom, if car wont start sound like thats what happened.
ring the oft guys they may have a trick, if you know someone with a tactrix cable they will be able to rewrite the stock rom for you . The oft will choke now as it wont be able to read the stock rom id so it does not know which rom to let you write.
Try writing stock rom back to car its your only hope
Blu-by-U (06-03-2014)
Old 06-03-2014, 10:09 PM   #1850
steve99
Drives: FT86
try wtiting back the stock rom to car from oft first protected slot ie your original rom
Luckrider (06-03-2014)
Old 06-03-2014, 10:38 PM   #1851
Blu-by-U
Some Dumb Guy
Blu-by-U's Avatar
Drives: wanting an Acabian
While looking at my cable, now that I have remove it from the car. It seems that there are two pins, in the middle opposite of the clip, that are longer than the rest. Is this normal? Didn't pay attention to that when I got it.
She said it was her or the car. Longest she had ever seen.
Blu-by-U is offline   Reply With Quote
Old 06-03-2014, 11:58 PM   #1852
DC2R
Drives: 2014 Scion FR-S
Are you using any type of extension? I know that my extension would let me data log but would fail when flashing
Sent from my GT-N5110 using Tapatalk
DC2R is offline   Reply With Quote
Old 06-04-2014, 12:02 AM   #1853
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Yes, this is normal.
Shiv@Openflash is offline   Reply With Quote
Old 06-04-2014, 12:19 AM   #1854
Blu-by-U
Some Dumb Guy
Blu-by-U's Avatar
Any ideas about my situation?
Old 06-04-2014, 12:31 AM   #1855
steve99
Drives: FT86
About all you have left would be remove batt terminal to reset ecu and try again, but sounds like rom is erased.
Old 06-04-2014, 02:07 AM   #1856
meeks
slide to unlock
meeks's Avatar
Drives: 2013 FR-S Raven Black
Got my open flash today. Really excited but after reading my ecu to proceed to the next steps to tune, the tablet doesn't even have an option to write or read (after the tablet saved my stock rom file). Can anybody help?
meeks is offline   Reply With Quote
Old 06-04-2014, 02:28 AM   #1857
Shiv@Openflash
Drives: 2013 FRS
Once you read your ROM, the Read selection will be greyed out. No need to read it again. If the right option is also unavailable, that means the OFT did not recognize your stock ROM and was unable to auto-generate maps. This usually happens with ECUs that previously had an Ecutek tune on it (even if it was flashed back to "stock". Either way, simple solution is to just manually load the desired tune ROMs using OF manager software. Takes a couple extra minutes and requires a laptop. But if you call the office tomorrow, we can walk you through it quickly.
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
meeks (06-04-2014)
Old 06-04-2014, 02:29 AM   #1858
Shiv@Openflash
Drives: 2013 FRS
I really just sounds like your battery is dead. Are you able to flash your original ROM back to your ECU?
Old 06-04-2014, 02:37 AM   #1859
steve99
Drives: FT86
was trying to help him earlier, he tried to flash back original but still get "opps error writing to ecu" error. kind of looks terminal
Old 06-04-2014, 03:25 AM   #1860
meeks
slide to unlock
meeks's Avatar
My car was never flashed with ecutek. I tried doing what you just said right now and when it went to complete the updates..it says error in32 or something and just quits the program if I press quit or just freezes if impress continue. Thank you for your prompt reply, shiv!
Old 06-04-2014, 08:09 AM   #1861
Blu-by-U
Some Dumb Guy
Blu-by-U's Avatar
Will give this a shot after work before I call my dealer. Is there some kind of residual charge that the battery needs to be disconnected from a given amount of time? Will wait 15 minutes for the hallibut.
If a power off reset doesn't work, I'll try a dead jump from a battery pack.
Old 06-04-2014, 01:35 PM   #1862
meeks
slide to unlock
meeks's Avatar
UPDATE:
Thank you. you guys are awesome! i spoke to Robert over the phone and he resolved the issue with me. it was just a matter of downloading the right file to the tablet and writing that on the car's ECU. did i tell you guys that you guys rock? car feels way better now without the "soggy" throttle pedal feel that i had before the flash with the UEL installed.
The Following 2 Users Say Thank You to meeks For This Useful Post:
Shiv@Openflash (06-04-2014), YEAHdams (07-29-2014)
cat overtemp
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 07:35 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 02:19 PM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 01:39 PM
