Old 06-02-2014, 09:05 PM   #71
Turdinator
Señor Member
Turdinator's Avatar
Originally Posted by celek View Post
Spot the differences?
The counter weights look different. Is one a FA20 crank and the other a FB25?
1974 TA22 Celica
2013 86 GT
The Following User Says Thank You to Turdinator For This Useful Post:
celek (06-03-2014)
Old 06-02-2014, 09:09 PM   #72
celek
Resident Gear Head
celek's Avatar
Here is a HUGE announcement for the project.
I have been working on this for a LONG time. Lots of R&D. Specifically made for the 86 Chassis. Bolt on plug in play.
celek is offline   Reply With Quote
The Following User Says Thank You to celek For This Useful Post:
whataboutbob (03-18-2015)
Old 06-02-2014, 09:28 PM   #73
Turdinator
Señor Member
Turdinator's Avatar
Electric water pump?
1974 TA22 Celica
2013 86 GT
celek (06-03-2014)
Old 06-03-2014, 02:17 AM   #74
Kronos
Kronos's Avatar
Drives: Asphalt FR-S MT
Originally Posted by Panda Mao View Post
I'd be happy with 200-250whp if possible with an NA build will be costly but anything for this car is already costly lol
200whp is a little more attainable than you might think. A catless header and an E85 tune will get you to 200whp. And you can obtain that for as low as around $1000
Kronos is offline   Reply With Quote
The Following User Says Thank You to Kronos For This Useful Post:
celek (06-03-2014)
Old 06-03-2014, 05:11 AM   #75
Staf00
Drives: SWP DZE
There is a small problem with a 90 mm bore.
This problem is that there is not gasket manufacture that makes a gasket larger than 89.5mm.
As for stroke I have something special planned for the crank. I will know once it is looked over. and it will be cheaper than HKS
What would happen if you bored the Darton sleeves out to 90mm but used the 89.5mm gaskets? Is the 0.5mm difference that significant? Can the gaskets possibly be machined to 90mm as well?
Staf00 is offline   Reply With Quote
Old 06-03-2014, 08:29 AM   #76
celek
Resident Gear Head
celek's Avatar
Correct
Old 06-03-2014, 08:32 AM   #77
celek
Resident Gear Head
celek's Avatar
The Cometic MLx gasket uses a folded over center layer like HKS's Stopper Gasket for better sealing and less bore distortion. Cutting it away would make it fall apart. Using a 89.5mm bore gasket on a 90mm cylinder would result in the gasket hanging in and glowing red hot pre igniting the fuel. This would be bad
Old 06-03-2014, 08:54 AM   #78
Turdinator
Señor Member
Turdinator's Avatar
Correct
Which is which?
1974 TA22 Celica
2013 86 GT
Old 06-03-2014, 10:51 AM   #79
celek
Resident Gear Head
celek's Avatar
Which is which?
25 on the bottom
Smaller Rod width and diameter
Turdinator (06-03-2014)
Old 06-03-2014, 07:49 PM   #80
Panda Mao
Panda Mao's Avatar
Drives: 2014 Scion FRS
and where the heck am I gona find E85 around here? lol
that ethanol stuff is rare around the boston area at least I havent found any
Panda Mao is offline   Reply With Quote
Old 06-03-2014, 07:51 PM   #81
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
Its a fog machine! So people can't see how fast he's going!
The Following 2 Users Say Thank You to tahdizzle For This Useful Post:
Ingen (06-16-2014), lbroskee (06-03-2014)
Old 06-03-2014, 10:06 PM   #82
d.liang
Drives: 13 whitout frs
http://www.ethanolretailer.com/flex-fuel-station-finder
d.liang is offline   Reply With Quote
Old 06-03-2014, 10:55 PM   #83
Panda Mao
Panda Mao's Avatar
Originally Posted by d.liang View Post
thanks I just used the link search site and honestly there are a few places in the boston area but it really isnt worth it at least for now imo since for me as a dd car its kind of a pain to get to these areas just for e85 and hell no am I driving through chelsea I hate the streets I feel like I am gona blow my shocks or drive like a drunker avoiding every possible pot hole then theres the traffic....
I also plan to cross country in the frs so until there is more of them around (probably within the next 10-20 years) becomes more of a common fuel than a specialty fuel sort of I will just stick to 93 octane which is like everywhere for the most part
Old 06-07-2014, 02:32 PM   #84
celek
Resident Gear Head
celek's Avatar
ran into problems with the waterpump mounting but came up with a solution
2.3ltr, all motor, helpful, hks, hks stroker, informative, na brz
Beginner STX Build Whiteout FRS Build Thread Hachi86Roku Tracking / Autocross / HPDE / Drifting 21 03-31-2020 07:52 PM
Ultimate coilover thread, What do you run on your car? got REVIEWS post it up! THMotorsports.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 12-11-2013 05:25 PM
The *ULTIMATE* Exhaust Thread by ECS Motorsports! | Over 2 Dozen Options! + FREE S&H! AJ@ECSMotorsports Engine, Exhaust, Bolt-Ons 27 09-05-2013 09:14 AM
*--->>ULTIMATE COILOVER THREAD<<---* The Best Deals + Free Shipping FT-86 SpeedFactory Brakes, Suspension, Chassis 95 01-30-2013 07:48 PM
Who's in for the long haul? Laika BRZ First-Gen (2012+) — General Topics 47 07-09-2012 09:48 AM
