Old 05-01-2014, 09:12 AM   #43
ericmpena
ericmpena's Avatar
Drives: Subaru BRZ Limited
They did much more than grease mine I believe. They had to take the whole transmission out to fix it apparently. I'd play it safe and just let them fix it for you. I don't think it's something you can just grease and be done with it. They had my car for over a week.
ericmpena is offline   Reply With Quote
Old 05-03-2014, 08:02 PM   #44
Liebot
Liebot's Avatar
Originally Posted by marinjim View Post
Took my 22 month old FR-S in yesterday for squeak diagnosis and is throw-out bearing that needs replacing. Covered under 5 year 60K mile Powertrain warranty. I always put the car in neutral at lights and don't ride the clutch, in fact, my 93' Lexus SC300 5 speed made it to 110K mile before needing a new clutch. I'll update when work complete, but this isn't good for a car with 24K on it.
spoilers: that's not going to stop the squeak.
Liebot is offline   Reply With Quote
Old 05-07-2014, 11:20 AM   #45
Synack
Boosted
Synack's Avatar
Drives: Sideways
Originally Posted by Hawaiian View Post
Rather than my bearing going out, it was a dry shift fork. I took mine in for warranty and had it lubricated. It took about 30m and the sound went away.
Thank you
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
The Following User Says Thank You to Synack For This Useful Post:
Hawaiian (05-07-2014)
Old 05-08-2014, 04:18 AM   #46
Khorne
Super 86
Khorne's Avatar
Drives: Red 86 GTS
Don't know if it's the same, My clutch pedal is making a click at the begining of it's stroke. Sounds to be coming from the Clutch cylinder
230rwhp/184ftlb on 98RON/93AKI
Build thread
Red 86 GTS MT | Sprintex Intercooled Twin Screw SC | Invidia N1 | Mocal 10 row | Invidia Front Pipe | Motiv Overpipe| Enkei RPF01 with Bridgestone RE002s | MCA Blue Coilovers | Radium Catch Can
Khorne is offline   Reply With Quote
Old 05-24-2014, 06:44 PM   #47
marinjim
marinjim's Avatar
Drives: 2013 FR-S MT Firestorm recd 5/31/12
It did!
Firestorm Red MT FR-S received 5/31/12 at 11 AM Novato Ca. Novato Scion, so long 1993 Lexus SC300 MT, you served me well for 18 years
marinjim is offline   Reply With Quote
Old 05-26-2014, 01:16 PM   #48
Liebot
Liebot's Avatar
It did!
I had the exact same thing done and I still have the squeak
Old 05-27-2014, 01:28 PM   #49
John86
Drives: BMW 228i TPK , 13 BRZ (LemonLawed)
I had the same problem and they used grease, which fixed it for a little, but it came right back. They just recently replaced the clutch fork and that seemed to get rid of it—at least for now. I have heard of other people on the nasioc forum having the clutch fork replaced on their WRX and that seemed to fix the problem for them as well. I hope that helps.
John86 is offline   Reply With Quote
Old 06-02-2014, 06:47 AM   #50
gonzo
Drives: frs
Got the sqeakey noise with crunchy pedal feel during the last inch or two before clutch is fully depressed. Pretty disappointing for a 25k mile car considering I never hard launch and always sit in N at lights.
Assuming it needs more than a lube job what are my chances of getting the shift fork (or whatever needs to be) replaced under warranty with a rear tranny mount and whiteline insert?
Edit: going in today so I'm about to find out
gonzo is offline   Reply With Quote
Old 06-03-2014, 02:33 PM   #51
Synack
Boosted
Synack's Avatar
Drives: Sideways
We greased/lubed up the clutch fork and input shaft really well and all noises went away.
Old 06-03-2014, 05:32 PM   #52
WRB5titch
Drives: WRBrz
How'd it go?
EBSC - dt.FF - MXP CompRS
WRB5titch is offline   Reply With Quote
Old 06-09-2014, 11:16 PM   #53
gonzo
Drives: frs
Originally Posted by WRB5titch View Post
How'd it go?
I went there asking them to lube the shift fork because of what I read on this forum. They made me wait 3 hours and said it's something "internal" so they can't just lube it. Said they'll contact toyota then get back to me. They called a few days later telling me that toyota doesn't know what's causing it yet so bring it in for a lubing (which they wouldn't do the first time I asked).
Instead of taking it back I raised my clutch pedal so that it's now barely higher than the brake pedal. The noise went away and I haven't gone back to the dealer yet.
Old 06-10-2014, 01:39 PM   #54
TagMaster11
TagMaster11's Avatar
Drives: 2014 Subaru BRZ Aimgain GTF
Hi Folks, I picked up my brand new BRZ 10 days ago, and shifting from 1st to 2nd is a bit rough and there is a clanking noise. .....
From 3rd to fourth is very smooth and all other shifting is ok.... I just sent an e-mail to my sales guy to see what he recommends. In the meantime, what do you guys recommend?
TagMaster11 is offline   Reply With Quote
Old 06-14-2014, 01:30 AM   #55
mokinbird87
BOXER FR
mokinbird87's Avatar
Drives: WRB BRZ Limited
I had this sound:
[ame]http://youtu.be/Xu8cEgt6_eY[/ame]
and got my throw-out bearing replaced. sound is completely gone and the crunchy feeling at the bottom of the clutch is also gone. get it taken care of while you have the warranty.
mokinbird87 is offline   Reply With Quote
Old 06-16-2014, 11:59 PM   #56
gonzo
Drives: frs
How'd it go?
Nevermind it's back -_-
Loud 'Squeak' Noise From Clutch? Brndn704 Issues | Warranty | Recalls / TSB 23 07-20-2020 08:58 AM
Upgraded Clutch Squeak Rybot Issues | Warranty | Recalls / TSB 116 10-09-2019 02:10 PM
Clutch pedal adjustment gone wrong? Clutch issues. PulpBrah Engine, Exhaust, Transmission 12 03-06-2017 04:08 PM
Clutch Squeak CatDaddysBBQ Issues | Warranty | Recalls / TSB 4 07-14-2015 06:44 AM
Clutch pedal squeak. merino_frs Engine, Exhaust, Transmission 1 08-25-2014 01:00 AM
