go_a_way1
Old 06-02-2014, 06:03 PM   #2339
S1CNSTY_SUBIE
S1CNSTY_SUBIE's Avatar
Drives: Subaru BRZ
Some pics of my new setup from a car show this past weekend. I need to add some spacers, rear UCA's, and figure out how to get my ST coilovers to go lower to make it more aggressive.
Wheel specs:
OZ Futura's in a Prima Donna finish drilled to 5x100
fronts are 18x9 +35
rears are 18x9.25 +25
S1CNSTY_SUBIE is offline   Reply With Quote
Old 06-03-2014, 12:39 AM   #2340
moomoopanda
moomoopanda's Avatar
Drives: Argento FRS
Originally Posted by Kosmos View Post
Yeah the hole. I meant if I could use the stock bolts for the upper strut tower when I notch it
Sent from my SM-N900P using Tapatalk
Yeah, you can. Just make sure to tighten it properly, or loctite it so it doesn't loosen and slip.
moomoopanda is offline   Reply With Quote
The Following User Says Thank You to moomoopanda For This Useful Post:
Kosmos (06-03-2014)
Old 06-03-2014, 12:40 AM   #2341
Kosmos
Kosmos
Kosmos's Avatar
Drives: Scion FR-S
Alrighty I appreciate it a ton
Kosmos is offline   Reply With Quote
The Following User Says Thank You to Kosmos For This Useful Post:
nab335 (06-03-2014)
Old 06-03-2014, 05:04 AM   #2342
nab335
nab335's Avatar
Drives: e92 335i, FRS, Lexus ls400
yes make sure, for mine it seems like it can't help it, i need alignments like every 3 weeks because every time i hit a big bump it loses its place and messes up my alignment.
IG: nabb335
nab335 is offline   Reply With Quote
The Following 2 Users Say Thank You to nab335 For This Useful Post:
Kosmos (06-03-2014), MikoV (06-03-2014)
Old 06-03-2014, 12:41 PM   #2343
Kuzuri
__(X)__
Kuzuri's Avatar
Drives: '11 Legacy, '89 190E, '78 GS1000
Working on these a little more now
and finally got my plate after complaining how I wanted it for the last year
IG: @dustin_faulkner
Kuzuri is offline   Reply With Quote
Old 06-03-2014, 03:22 PM   #2344
Kosmos
Kosmos
Kosmos's Avatar
Drives: Scion FR-S
3 year unlimited alignments from ntb near my house with a flat rack
Old 06-03-2014, 03:59 PM   #2345
NigelA
Drives: 2014 Whiteout Scion FRS
Hey Guys, am i aggressive enough to play?
Volk CV Pro
17x8 +46
17x9 +33
NigelA is offline   Reply With Quote
The Following User Says Thank You to NigelA For This Useful Post:
nab335 (06-05-2014)
Old 06-03-2014, 04:06 PM   #2346
boucher
Leaux Down Krewe
boucher's Avatar
Drives: 2014 SSM Limited
Nope
Follow me on IG: @rougarou86
boucher is offline   Reply With Quote
The Following 7 Users Say Thank You to boucher For This Useful Post:
Boom (06-03-2014), JustBoostin (06-03-2014), jwbrocloud (06-05-2014), Kuzuri (06-04-2014), PEWPEW (06-04-2014), stancypants (06-03-2014), VADER (06-04-2014)
Old 06-03-2014, 06:07 PM   #2347
636
636's Avatar
Drives: '23 CWP BRZ
Crap, was he being serious?
636 is offline   Reply With Quote
The Following User Says Thank You to 636 For This Useful Post:
Kuzuri (06-04-2014)
Old 06-03-2014, 06:42 PM   #2348
Simply_the_best
Tom's Racing ADDICT
Simply_the_best's Avatar
Drives: 2013 Toyota 86, 1999 Toyota Corolla
Enkei RPF1 17x9
Nitto Invo 245/40
Check out my car journal!
"Straights are for fast cars. Corners are for fast drivers."
Instagram: @simply_the_best
Simply_the_best is offline   Reply With Quote
The Following 5 Users Say Thank You to Simply_the_best For This Useful Post:
dori. (06-11-2014), Kosmos (06-03-2014), Kuzuri (06-04-2014), trigger happy (04-07-2016), Trmx2 (06-25-2014)
Old 06-03-2014, 06:46 PM   #2349
Kosmos
Kosmos
Kosmos's Avatar
Drives: Scion FR-S
Volk CV Pro
17x8 +46
17x9 +33
Too much wheel gap. You want it nice and tight
Old 06-03-2014, 10:46 PM   #2350
s13Henry
s13Henry's Avatar
Drives: Black BRZ/Black S13 Silvia
Seems like 18x9/10 +4 shouldnt be hard to fit then. Is 215/35 225/40 good size tire for the wheel sizes?
im new this fitment game for frs/brz, my s13 had the above size but +14.
So i kinda got an idea based and going though this thread a bit. Thanks for the help.
s13Henry is offline   Reply With Quote
The Following User Says Thank You to s13Henry For This Useful Post:
Kosmos (06-03-2014)
Old 06-03-2014, 10:48 PM   #2351
Kosmos
Kosmos
Kosmos's Avatar
Drives: Scion FR-S
Go with 215
Old 06-03-2014, 11:05 PM   #2352
ChandlerSwyng
ChandlerSwyng's Avatar
Drives: 2013 Red Subaru Brz
Finally decided to get coilovers Name:  ImageUploadedByTapatalk1401847553.246834.jpg
WDE
The Following User Says Thank You to ChandlerSwyng For This Useful Post:
MikoV (06-04-2014)
dontlike?dontlookmoveon
Post the Wheels You want On your FRS/BRZ!! Zaku Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1738 10-11-2017 05:29 PM
RPF1 and PF01 aggressive fitment size requests Crossover Auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 10-22-2012 03:30 PM
post VIN with any problem thread? fistpoint Issues | Warranty | Recalls / TSB 0 10-04-2012 11:11 PM
Do aggressive offsets cause more debris to kick up into the paint? switchlanez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 09-26-2012 11:03 PM
Scion FR-S / Toyota FT-86 / Subaru with Aggressive Body & High Wing! + VIDEO! Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 538 06-15-2011 03:20 AM
