Old 06-03-2014, 11:04 AM   #1
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
How do you get around OBD2 Testing in GA? (System Not Ready)
Fellow GA 86's.
I believe if you remove Cats, your Emmisions system will show "not ready" in the OBD2 monitor...
Then, if you use the EVAP soleniod line for boost control, that is a second system that will show "Not ready"....
So how do you get around this in GA? (Having two systems not ready for OBD2 yearly test)
@Reaper @dwx @ATL BRZ
The Following User Says Thank You to Sportsguy83 For This Useful Post:
IBill4You (05-28-2015)
Old 06-03-2014, 11:07 AM   #2
2pt5RS
Berz
the readiness should go away after about a week. I've had that before (not in my BRZ, but in another car). After driving roughly a full gas tank, the readiness was...ready.
We don't need emissions yet for our cars. I believe next year will be the first year. I think it's 3 years after the car comes out is when you need emissions to get your tag... and even then it is/was only in metro atlanta. The rest of the state, unless I'm mistaken, doesn't have emissions.
2pt5RS is offline   Reply With Quote
Old 06-03-2014, 11:11 AM   #3
Sportsguy83
Drives: Limited BRZ
Thanks. I was reading the law and it seems emmisions is only 13 counties within ATL metro area, but the OBD2 test is everywhere? Might be mistaken, I don't live there just reading up in the GA page for emmisions.
Is one system allowed not be ready like in other states? Or all systems are required to be ready?
Old 06-03-2014, 11:27 AM   #4
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
I know that my tuner has disabled the DTC for cat readiness so I've never seen it, but then again I've never actively monitored that metric in Torque in regular driving so it may not be actively "ready" even though the DTC is disabled. I'm not sure how that works. As far as I know we do not have visual inspections in Fulton county. I have a secondary cat but I never bothered to move the secondary O2 sensor aft of it since there's no point to. Worst case scenario I have my OEM header and can swap it on the lift if I absolutely needed to.
The Following User Says Thank You to ATL BRZ For This Useful Post:
Sportsguy83 (06-03-2014)
Old 06-03-2014, 11:37 AM   #5
Sportsguy83
Drives: Limited BRZ
I need to actually drive the car around now that I'm not flashing it 3 times per drive to see what the monitors read... Maybe they all show ready and I don't even know.
Old 06-03-2014, 11:38 AM   #6
Lawn_Mower
Lawn_Mower's Avatar
Drives: GTI, BRZ
I had tons of issues dealing with customers cars without cat and with tunes in the Volkswagen world here in NC (OBD2 only inspection testing) curious to see what's needed to get catless and tuned cars though inspection on this platform.
The issue we ran in to with inspection was when the tune disabled the fault codes for the missing catalyst, the ECU no longer checks to make sure it's working so the readiness test wont run and it will be unset. Obviously different tunes can handle that differently, but what we had to do was run a O2 spacer and the stock tune, then force the readiness tests using our scan tool, get it inspected and then flashed back to the stage 2 programming. PITA like I said.
Lawn_Mower is offline   Reply With Quote
The Following User Says Thank You to Lawn_Mower For This Useful Post:
Old 06-03-2014, 11:39 AM   #7
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
it's 2014
can people stop ripping the cats out of their daily driven cars?
Old 06-03-2014, 12:51 PM   #8
Sportsguy83
Drives: Limited BRZ
Originally Posted by 7thgear View Post
it's 2014
Not really.. Also good to note, I don't daily drive my car.
[ame="https://www.youtube.com/watch?v=umDr0mPuyQc"]NO GOD! PLEASE NO!!! NOOOOOOOOOO - YouTube[/ame]
Old 06-03-2014, 01:17 PM   #9
J_kennington
Drives: 2013 asphalt scion FRS
FYI, the state of Georgia allows 2 sensors to not be ready before auto failing the test. If a sensor shows not ready, you need to put between 65-150 miles on the car. Then it should pop ready. A tune should not matter, in fact...it theoretically should help pass emissions. Other than that, there is no way to "sneak" an obd2 car. Unlike an obd1 where you can manually input info, obd2s do it all automatically from the port.
2013 raven frs(dd/grocery getter)
1990 mitsu eclipse gsx(street/strip car)
1995 gmc 1500 4x4(off road toy)
2005 Yamaha yz250f
J_kennington is offline   Reply With Quote
The Following User Says Thank You to J_kennington For This Useful Post:
Old 06-03-2014, 01:59 PM   #10
Sportsguy83
Drives: Limited BRZ
2 sensors to not be ready allowed is good enough. That is the exact info I needed. Ecutek boost control tunes will have at most 2 sensors not ready. Thanks!
Old 06-03-2014, 02:55 PM   #11
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
@Sportsguy83 I am exempt from emissions testing in 49 states.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
The Following User Says Thank You to Reaper For This Useful Post:
Old 06-03-2014, 02:57 PM   #12
Sportsguy83
Drives: Limited BRZ
GRRRRRR....
Old 06-03-2014, 02:58 PM   #13
Reaper
Reaper's Avatar
Drives: violent
Sorry.
Old 06-03-2014, 03:23 PM   #14
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
New job offer?
WheelDude.com | Stivo Racing Exhaust System - in stock and ready to ship! WheelDude.com Engine, Exhaust, Bolt-Ons 13 10-20-2013 05:59 AM
FA20CLUB CAI V2 SYSTEM NOW READY FA20Club.com Engine, Exhaust, Transmission 51 10-03-2013 07:26 AM
INJEN and aFe Intake System, In stock and ready to ship!! 10k Redline Engine, Exhaust, Bolt-Ons 5 10-03-2012 04:05 PM
