Old 06-02-2014, 11:39 AM   #43
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
Why do u think oe is el???
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
Old 06-02-2014, 11:51 AM   #44
mike the snake
Originally Posted by wtrxprs007 View Post
Exactly what I was trying to say but couldn't really word it. Thank you
The cylinders still are firing every 90 degress, which sounds EVEN, no rumble.
It is the ll-rr firing order, COMBINED with the unequal length header that creates the rumble.
With an EL header, the collector sees evenly spaced pulses. 1 medium, 2 medium, 3 medium, 4 medium length tube (time) pulses, all evenly spaced apart=no rumble.
With an Unequal length header, the collector sees 1 short, 2 short, 3 long, 4 long. Short-short, long-long, in that order creates the rumble.
Old 06-02-2014, 01:57 PM   #45
ramiram1984
Drives: 2016 STi DGM
I like el and uel aftermarket. I've had the pleasure to run: revworks, and borla uels, and hks el.
[ame="https://www.youtube.com/watch?v=UX7hnoSkSzk"]BRZ headers and exhaust - YouTube[/ame]
here's another
[ame="https://www.youtube.com/watch?v=IUCjHTC7ma0"]FR-S borla headers and exhaust - YouTube[/ame]
-2014 SSM BRZ MT
ramiram1984 is offline   Reply With Quote
Old 06-02-2014, 02:44 PM   #46
chiefshayan
chiefshayan's Avatar
Drives: 2013 AT Firestorm FRS
Originally Posted by wparsons View Post
No. How much boxer rumble do you hear in any of these?
H6 swapped impreza (still a boxer)
Older 911 (yes, those are boxer engines too)
New 911 (yep, still boxers)
Yet another 911 (again, still a boxer)
There are two main reasons the (non FRS/BRZ) Subaru 4 cylinder boxers sound so different.
1) The stock manifolds are VERY UEL and merge the ports right at the head instead of having individual runners for each cylinder.
2) They have different firing orders than most engines, and fire both left cylinders then both right cylinders.
The firing order combined with the manifold design is why they rumble so much stock. If you swap out to an EL manifold you'll definitely get rid of the rumble.
I think we're saying the same thing. In general, UEL doesn't make the boxer rumble. Just because a car has UEL headers doesn't give it a rumble-sound.
It's a combination of the flat motor and uneven length headers that makes the unique sound in boobaru's.
chiefshayan is offline   Reply With Quote
Old 06-02-2014, 03:43 PM   #47
wparsons
wparsons's Avatar
It has nothing to do with the motor being flat...
[ame="https://www.youtube.com/watch?v=IZBUVlbeAbU"]First s2000 with unequal length header, invidia catback sounds like subaru - YouTube[/ame]
Stock subaru's are more pronounced because of how UEL the manifolds are, and because they merge right off the head, but a UEL manifold alone will make it rumble even on an inline 4 with a "normal" firing order.
flickr
Old 06-02-2014, 04:00 PM   #48
Celadrielas
Celadrielas's Avatar
Drives: 2013 Asphalt Fr-S
In terms of power gains, isn't the EL "better"?
Old 06-02-2014, 08:43 PM   #49
wparsons
wparsons's Avatar
Properly designed and optimized an EL is better than UEL, but a crappy EL will perform worse than a quality UEL.
I know not everyone will agree, but I would love to see individual EGT and AFR for each cylinder with a UEL header, I would worry that there would be quite a discrepancy.
flickr
Old 06-02-2014, 11:36 PM   #50
Nafe
Nafe's Avatar
Drives: Mt Fuji Red 86 GT
Its called "boxer rumble" because that is less syllables than "Subaru rumble" or "unequal length header rumble" ;-) who else other than Subaru and Porsche use boxer engines?? That's right, no one. And how many Porsche's rumble?? Oh yeah... None ;-)
My quality EL headers do not rumble. When I worked a Subaru we had an older STI come in with EL headers. No rumble... Sounded similar to an sr20det ;-)
Nafe is offline   Reply With Quote
Old 06-03-2014, 12:27 AM   #51
STV3
Señor Member
STV3's Avatar
My Scion has a boxer engine...
STV3 is offline   Reply With Quote
Old 06-03-2014, 03:38 AM   #52
wtrxprs007
wtrxprs007's Avatar
Drives: 2006 Toyota Prado 4.0V6
BMW does in their motorbikes :P
wtrxprs007 is offline   Reply With Quote
Old 06-03-2014, 04:48 AM   #53
Mars2
Drives: GT86, AUDI RS2, VW T5 R32 Vortech
Ferrari, Volkswagen, Alfaromeo and Citroen used to.
Mars2 is offline   Reply With Quote
Old 06-03-2014, 05:29 AM   #54
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
What are some good catted ELs? Looking around all I really see is JDL EL catted. Would the sound be significantly different (louder? tone?) vs stock headers?
Been looking forward a catted setup since I don't want to piss off my neigbhors.
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
Old 06-03-2014, 05:41 AM   #55
Mars2
UEL result
http://www.ft86club.com/forums/showp...&postcount=729
Old 06-03-2014, 09:17 AM   #56
w00t692
Drives: 2008 Civic Si
Originally Posted by Mars2 View Post
Glendale is at 1150 ft elevation. Probably a healthy correction factor.
w00t692 is offline   Reply With Quote
stupid question about brz andrewmay9 BRZ First-Gen (2012+) — General Topics 55 05-17-2014 03:10 AM
Really stupid question regarding oil hansthegerman Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 10-08-2013 07:56 AM
Potentially headlight stupid question BentAnat Cosmetic Modification (Interior/Exterior/Lighting) 7 08-21-2013 02:32 AM
Stupid Question on Controls Naughty AFRICA 32 04-19-2013 04:51 AM
Stupid Question Canibuz Engine, Exhaust, Transmission 24 03-05-2012 09:50 AM
