Old 06-02-2014, 05:56 PM   #99
eric6
eric6's Avatar
Drives: 93 MR2 Turbo; 2014 BRZ
Originally Posted by glamcem View Post
I have a quick question, looking at the instructions (on page 4), do we retain the plastic panel in the picture or it is not necessary after installing this splitter? @FT-86 SpeedFactory
thanks in advance
http://ft86speedfactory.com/instruct...stallation.pdf
It is cannot be used after installing the splitter.
Rear diffusers are a great way to add downforce to the rear of a car. The other option are wings. Both have their positives and negatives.
eric6 is offline
Old 06-02-2014, 06:01 PM   #100
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
and what are those ?
How about adding wing/spoiler and rear diffuser at the same time? Would there be too much of penalty (air drag)? Maybe I should simply start adding the splitter and diffuser first then take it from there
Btw, I actually would love to get rid of that heavy plastic part so it's a win win for me
glamcem is offline
Old 06-02-2014, 06:04 PM   #101
nyfries
Drives: 14 FRS Whiteout
very interested in this. my car will be dd/ autox and the occasionally track day. however i also live in an area with snow and i will be driving it in the snow. how will this hold on in the snow? do i have to take it on and off throughout the year?
nyfries is offline
Old 06-02-2014, 06:23 PM   #102
eric6
eric6's Avatar
Rear diffusers, when properly designed, can generate A LOT of downforce for little drag penalty. However, given most street car chassis setups, a proper designed diffuser is near impossible, making them less effective (I am NOT saying they do not work). Wings create massive amounts of drag per pound of downforce. However, they are less vehicle/chassis specific because of their placement and that makes them a more repeatable way to produce downforce.
I would start with underbody aero first, but that's my personal preference.
eric6 is offline
The Following 2 Users Say Thank You to eric6 For This Useful Post:
glamcem (06-02-2014), Gunman (06-12-2014)
Old 06-02-2014, 06:25 PM   #103
eric6
eric6's Avatar
The material will work fine with water/snow and should actually hold up better than fiberglass or carbon fiber. Both of those materials splinter and crack where this material will not do that.
eric6 is offline
Old 06-02-2014, 07:45 PM   #104
plucas
plucas's Avatar
Drives: Subaru
@plucas, at my latest track event I noticed that the high speed corner stability is becoming an issue, especially after my Supercharger install so I am considering to add a front splitter and also thinking combining this with a functional Driveway labs rear diffuser ( if the fitment is not an issue with my Tsudo catback) so my question is; is there any other way to reduce lift or adding down force to keep the rear end a bit more stable at higher speeds?
What would be your input when combining this front splitter and maybe a rear diffuser with something like a wing or big spoiler?
http://ft86speedfactory.com/seibon-c...r-gt-1269.html
and to the link the spoiler I am considering
http://ft86speedfactory.com/greddy-r...g-v2-1279.html
I would personally do the splitter with the Driveway Labs diffuser and see how you like the car. If the car oversteers greater than what you as a driver are comfortable with at high speed (many people like cars setup differently), then I would look into a rear wing. I would not do the rocket bunny spoiler. There are some good wings out on the market and some bad ones. Do not believe the numbers thrown out by any of the companies as they do not apply unless tested on these cars. I am also not a fan of the 3d profile, unless it was designed for a specific car.
I agree with this. Underbody is more tricky to create downforce, however it doesn't come with the large drag gain that wings do. Being that these cars are very underpowered, I would only tackle a wing if you can't make the downforce in other areas.
plucas is offline
The Following 2 Users Say Thank You to plucas For This Useful Post:
glamcem (06-03-2014), Wonderbar (06-03-2014)
Old 06-02-2014, 10:03 PM   #105
nyfries
That good to know. What if I had to drive through I plowed area and snow collects on the spliter?
nyfries is offline
Old 06-03-2014, 08:04 AM   #106
plucas
plucas's Avatar
Drives: Subaru
It is not a snow plow so if treated like one, you could see damage to it or your bumper. However, it can handle some snow just collecting on the top side of the splitter.
plucas is offline
The Following User Says Thank You to plucas For This Useful Post:
nyfries (06-04-2014)
Old 06-03-2014, 11:54 AM   #107
glamcem
glamcem's Avatar
that's what I am planning to do,
Do you think that adding rear diffuser and splitter increases the oversteer? or do you mean that if I still have the oversteer after adding those?
I am also pretty skeptical about the functionality of the many aftermarket parts. Btw, what exactly do you mean by the 3d profile?
How about a trunk that already has a built in spoiler that looks more functional than the OEM one?
something like this
AFAIK, with the spoiler extension there is no drag penalty like the wings, well at least it works great with the new Camaro Z28s but then again it may be because it's designed for the car
how would you compare the wings to the duckbill trunks ?
Thanks again
glamcem is offline
Old 06-03-2014, 01:07 PM   #108
Wonderbar
Driveway labs.
Wonderbar's Avatar
Drives: '13 BRZ Limited, 6sp, SWP
A rear diffuser should reduce oversteer as it is adding load to the rear wheels.
Too much aero on the front makes oversteer. Too much on the rear makes under steer. You've gotta maintain a balance.
-'13 Subaru BRZ Limited, SWP. (Mods: Driveway Labs full aero, MCA, etc)
-'06 Mitsubishi Eclipse 3.8L, UV blue. (Mods: turbocharged, full suspension, too much to list)
-'13 Town and Country Limited (Mods: too many kids)
Wonderbar is offline
The Following User Says Thank You to Wonderbar For This Useful Post:
plucas (06-03-2014)
Old 06-03-2014, 02:16 PM   #109
plucas
plucas's Avatar
Drives: Subaru
something like this
Thanks again
If I still have the oversteer that is uncomfortable after adding those (splitter and diffuser), then maybe look at adding a wing. I personally like a car that has slight oversteer.
You should be skeptical of a lot of aftermarket parts. Many in fact do the opposite of what they claim.
A 3d wing profile is one where the profile changes down the cord length.
3D profile is below:
2D Profile is Below:
Spoilers work and work well. However, they won't create as much downforce as a wing(properly designed of course), but they usualy create less drag. Deciding between the two or any at all should be determined after you do the other mods and see how the car drives.
I will be having an analysis coming out soon on this splitter paired with the V1 diffuser from Driveway Labs. Hopefully soon after that, I can have one also with the V2 diffuser. This should help people have an idea about how their aero will effect the characteristics of the car.
plucas is offline
The Following 8 Users Say Thank You to plucas For This Useful Post:
civicdrivr (06-03-2014), gkubed (07-05-2017), glamcem (06-03-2014), JDKane527 (06-03-2014), Malt (06-04-2014), Rosticles (06-03-2014), subielife (06-03-2014), Wonderbar (06-03-2014)
Old 06-03-2014, 02:19 PM   #110
Wonderbar
Driveway labs.
Wonderbar's Avatar
^ much excite. So anticipation.
Old 06-03-2014, 06:00 PM   #111
Model Citizen
Lacking brains
Drives: frz
Timeframe on analysises?
Lol autocorrect
Originally Posted by cjsporl1996 View Post
If this thread is not deleted I can file a lawsuit.
Model Citizen is offline
Old 06-03-2014, 10:40 PM   #112
plucas
plucas's Avatar
Drives: Subaru
Lol autocorrect
2 weeks maybe. I have a few other things I am working on.
plucas is offline
Just Added APR front splitter and side splitter Pekingduck Cosmetic Modification (Interior/Exterior/Lighting) 42 08-31-2016 10:22 AM
What front splitter? Takumi788 Cosmetic Modification (Interior/Exterior/Lighting) 7 04-30-2014 06:20 PM
Perrin Oil Cooler - Impressions, Pics, and Data swift996 Engine, Exhaust, Transmission 36 04-29-2014 09:03 AM
BRZ Front Splitter Jive Turkey Cosmetic Modification (Interior/Exterior/Lighting) 43 01-26-2014 03:29 PM
Front Air Splitter sw20kosh Tracking / Autocross / HPDE / Drifting 6 02-17-2013 05:41 PM
