Northern California NorCal
Old 06-02-2014, 11:20 AM   #1
buzznasa
LOL PWR
buzznasa's Avatar
Drives: Whiteout FR-S; Scion tC
OFT comments for Summer Kickoff
I know that normally a discussion about engine tuning belongs in the tuning thread but I wanted to put this here so that those that are planning to attend the Summer Kickoff would be sure to see it.
@shiv and his crew from Vishnu Tuning were at 86Fest last fall and had a stack of Open Flash Tablets for sale at the event for a discounted rate. He sold out of them fairly quickly. My guess is that they may do the same again at the Summer Kickoff.
I picked one up from them a few months ago. Here are my impressions of it.
Since I am pretty much bone stock, other than a drop-in air filter, I ran a Stage 1 tune. Installing the tune is very easy because the touch screen OFT device gives you step-by-step instructions as you are doing it.
After installing the tune we drove it around and I could feel a difference in acceleration. I didn't put it on a dyno to baseline it but the "butt dyno" noticed. However, I noticed that the engine would get raspy around 3500 to 4500 rpm. This is because of the change in injector usage to try to curb some of the torque dip. I should say, that is what I gleaned from reading other posts about it. @PMok noted that he heard it was a change in intake valve timing. Either way, the reasoning is the same.
Last week I got the fuel pump replaced under warranty so I flashed the car back to stock. The raspiness was gone but as I drove it to a from the dealership I noticed the drop in power. But, on the plus side, I got a new pump and the crickets are gone. Huzzah!
After talking with @PMok and a few others I decided to run the tank almost dry and make the e85 switch. This was so easy because the OFT has a ELH tune for e85 that Shiv already programmed. After filling up I drove across the street to an empty business park and installed the e85 tune. It took about 5 minutes to write it to the ECU and afterwards, the car fired right up with no issues. So, I drove it easy for next 10 miles so that all of the previous 91 gas got used up that was still in the fuel lines. Then I drove like normal for the rest of the day.
Now that the car is sipping the booze the engine feels so much more smooth (through idles and up to around 4k). It pulls even harder than the previous Stage 1 tune. "Butt dyno" says probably 10~20hp, maybe a little more. I am very happy with the results and I don't see myself going back any time soon.
Here are some Pros and Cons of the OFT that I have noticed.
Pros:
Moar Powah!!!
Easy installation
Free tunes (download them at their website)
Cheaper than most other tuning options. No need for dongles, licenses, nor the need to pay a trained tech for your custom tune.
Data logging
Real-time analytics. More of a "neato!" thing but it looks cool seeing your engine parameters in real-time
Best bang-for-your-buck power upgrade available, period.
e85 is about $1.00 cheaper per gallon (see caveat in Cons)
Cons:
Well, let's be honest, $500 is $500. But, it is cheaper than alternatives.
Raspiness of engine to compensate for torque dip.
Lack of e85 stations in West Southbay (That isn't a fault of the OFT, it just sucks that you have to go out of your way to find a station.)
Aftermarket tunes can void warranties
You get fewer miles per gallon on e85 due to the stoichiometric combustion difference between petrol and ethanol. Basically, Air-Fuel-Ratio is lower meaning it takes more fuel for the combustion to take place.
Long term effects on your engine are not known at this time.
Vishnu Tuning doesn't do any advertising. They don't need to. Just ask anyone using the OFT. Word of mouth from actual owners will tell you that this is a great deal.
They will be at the event this weekend and I would bet that they will have another stack of Open Flash Tablets on hand (possibly at a volume discount). So, if you were on the fence about it, maybe this will help you decide to make the leap. When you see Shiv at the NorCal86 Summer Kickoff, tell 'em Battlebot Buzz sent ya.
*edit* added some information that I forgot to mention thanks to a well informed discussion in this thread.
It's not a midlife crisis if you never grow up.
buzznasa is offline   Reply With Quote
The Following 14 Users Say Thank You to buzznasa For This Useful Post:
akahenry (06-03-2014), BRZChix (06-02-2014), Clipdat (06-02-2014), finch1750 (06-02-2014), garfull (06-02-2014), Garrett@Openflash (06-05-2014), jher (06-02-2014), mkivsoopra (06-02-2014), NorCal_Guy (06-03-2014), PMok (06-02-2014), Pwolf (06-02-2014), RC51ed (06-02-2014), Robert@Openflash (06-05-2014), Simpleviet (06-05-2014)
Old 06-02-2014, 11:39 AM   #2
mkivsoopra
Welcome to the world of E85
mkivsoopra is offline   Reply With Quote
The Following User Says Thank You to mkivsoopra For This Useful Post:
buzznasa (06-03-2014)
Old 06-02-2014, 11:56 AM   #3
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
What if you are on a road trip and there's no e85 around. Can you run the tank low and then flash back to a 91 octane tune and then fill up?
Originally Posted by humfrz
I'm old and lazy
Old 06-02-2014, 11:58 AM   #4
s2d4
s2d4's Avatar
Yes.
The Following User Says Thank You to s2d4 For This Useful Post:
Old 06-02-2014, 12:02 PM   #5
Clipdat
Proud of BOXER
Clipdat's Avatar
Nice, that's good to know.
Another question: Do the OFT tunes also contain the various "fixes" that are in the standard dealership/official tunes? Meaning the adjustments for the idle rpm dip, transient ignition tables adjustment/rumored fix to protect DI seals above 6K rpm, etc.
Originally Posted by s2d4 View Post
Yes.
I'm old and lazy
Old 06-02-2014, 12:24 PM   #6
PMok
Codename: Stitch
PMok's Avatar
Yes. One of the reasons I chose to buy the OFT was that my local dealership declined to give me the ECU upgrade to deal with those issues. I believe the Vishnu OTS maps are all currently based on the A01 factory map.
I pretty much agree with everything that Buzz said above. With one correction, the raspiness that you experience happens only if you are running the EL stg 1 tune (ie you do not have UEL headers). And my understanding is that the raspiness comes from rapid intake valve timing changes, not injectors. But yes it is there to try and reduce the dip. I also understand it's not unique to Vishnu tunes, users of other stage 1 ECU tunes (I.e. Ecutek) experience the same thing.
The Following 5 Users Say Thank You to PMok For This Useful Post:
buzznasa (06-02-2014), Clipdat (06-02-2014), garfull (06-02-2014), jher (06-02-2014), Pwolf (06-02-2014)
Old 06-02-2014, 01:29 PM   #7
Pwolf
Pwolf's Avatar
Drives: 2013 GBS BRZ Limited
I'm a noob but I think I already know the answer... once you've flashed the ECU, does OFT need to remain plugged into the OBDII port?
Pwolf is offline   Reply With Quote
Old 06-02-2014, 01:42 PM   #8
mkivsoopra
Nope!
Pwolf (06-02-2014)
Old 06-02-2014, 02:09 PM   #9
EastBayCanuck
Drives: Ultramarine FR-S
Pmok gave a great demo of OFT at the meet the other night, I'm seriously debating getting one, and may if they have em on discount at the BBQ this sunday.
EastBayCanuck is offline   Reply With Quote
Old 06-02-2014, 02:30 PM   #10
garfull
garfull's Avatar
Drives: FRS(sold), AP2, R35, FJC, ED9
yup same here, went into dealership and asked for the ecu upgrade and they gave me the BS does not exist statement and you dont know what your talking about look.
buzz shouldnt be complaining about the rasp, his stereo is soo fn loud to hear the rasp. which is a good thing.
garfull is offline   Reply With Quote
The Following User Says Thank You to garfull For This Useful Post:
Old 06-02-2014, 02:35 PM   #11
Pwolf
Pwolf's Avatar
Originally Posted by mkivsoopra View Post
Nope!
Thought so... There are tuning options that require that right? Wasn't sure if that's an ECU/Vehicle specific thing or based on the tuning device.
Old 06-02-2014, 04:55 PM   #12
Clipdat
Proud of BOXER
Clipdat's Avatar
This thing sounds sweet and like there's no downsides except maybe the price.
I'm old and lazy
Old 06-02-2014, 05:06 PM   #13
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
Ima personally go ecutek
bkblitzed is offline   Reply With Quote
Old 06-02-2014, 06:16 PM   #14
Clipdat
Proud of BOXER
Clipdat's Avatar
Care to share your reasons? Just curious.
I'm old and lazy
June 8th, 2014 - NorCal86 Summer Kickoff finch1750 Northern California 266 12-12-2014 02:50 PM
Southbay Caravan to NorCal86 Summer Kickoff buzznasa Northern California 41 06-12-2014 12:41 AM
PMU HC+800 - Comments Please sprintamx Tracking / Autocross / HPDE / Drifting 23 06-11-2014 06:28 PM
Sacramento Caravan to Norcal86 Summer Kickoff June 8th Byoki Northern California 24 06-11-2014 04:19 AM
Gaming at the NorCal86 Summer Kickoff buzznasa Northern California 11 05-30-2014 10:42 PM
