Old 06-01-2014, 11:58 PM   #15
MyEvilMonkeys
Drives: 2013 Scion FRS
When my camber slipped, the toe went with it. It drove without pulling left or right but the steering was off by a couple inches. Realigned and all was well. Not so sure since you are stock and there isn't as much that can slip. Let us know what you find tomorrow.
FA500 Coils/Swift/Radial Upgd, Cusco R.LCA, SPC R.Toe Arms, TqSol. R.SubFrame Bushings, MTEC Shift Springs, Perrin Shift Bushing/Trans Mount, Greddy SP Exhaust & Intake, RPF1 18x9.5 +38, 255/35-18 SDrives, Raceseng Ashiko Knob/Lockout
MyEvilMonkeys is offline   Reply With Quote
Old 06-02-2014, 12:42 AM   #16
Dezoris
Dezoris's Avatar
One of my first autox in this car when I did the review and the car was stock, my alignment/toe went completely off. Had about 1.5" toe out and wheel was off center by large margin.
Nothing broken or damaged, just a massive toe change from very bumpy surface. Could be as simple as getting an alignment here.
Old 06-02-2014, 02:29 AM   #17
troek
troek's Avatar
Drives: 2012 Toyota 86
i put my car up a 10" high curb and had no alignment changes. you should get jdm tie rods.
troek is offline   Reply With Quote
Old 06-02-2014, 10:42 AM   #18
wparsons
wparsons's Avatar
Front or rear toe? If it was front, there is no way that happened without something bending. Front toe is changed by threading the inner tie rod in or out of the rack, and the setting is locked by a jamb nut against the outer tie rod. Bumpy surfaces won't do anything to that unless it's bending something.
Rear is a different story with the offset bushing in the toe arm, it could slip.
flickr
Old 06-02-2014, 11:35 AM   #19
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
Rolf
Jdm tie rodz
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
Old 06-02-2014, 11:36 AM   #20
Dezoris
Dezoris's Avatar
The autox was on a bumpy concrete surface, the wheel was turned to 11 o Clock position after finishing. I drove home on it after inspection
When I got to the alignment rack next day which I did myself, we were somewhat dumb founded. Don't know if the issue was in the steering rack or what. But re-aligned, and have had about 40 events and 20 alignments since (over 1.5 years), 80% which I assisted or did myself. After every track day so far, there are always very small changes in toe front and rear. I re-align after every 2-3 track days.
I did pro-actively change the control arm, bolts, support bracket and outer tie rod much later on after the Ohlins setup because I am so anal. But even after that toe is always changing after a few events, but never as bad as that autox. @wparsons
Old 06-02-2014, 01:01 PM   #21
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
i literally snapped a rear toe arm, you would not be able to drive. the car IMMEDIATELY lost control and the rear snapped around. only solution is to call a tow truck. unless the car feels 100%, DO NOT DRIVE IT
Jive Turkey is offline   Reply With Quote
The Following User Says Thank You to Jive Turkey For This Useful Post:
wparsons (06-02-2014)
Old 06-02-2014, 06:58 PM   #22
jshum
jshum's Avatar
Drives: Scion - FRS
So I had it checked today. The people said nothing major and nothing was bent or damaged except that the alignment is very off. Here is the picture.
jshum is offline   Reply With Quote
Old 06-03-2014, 02:57 PM   #23
Dezoris
Dezoris's Avatar
That was my situation as described just align and move on.
Old 06-03-2014, 09:16 PM   #24
jshum
jshum's Avatar
Drives: Scion - FRS
Nothing really went wrong after?? Just wondering
Old 06-03-2014, 10:24 PM   #25
Dezoris
Dezoris's Avatar
Nothing wrong been on track, autox plenty. But also have had about 20 alignments.
Old 06-03-2014, 11:33 PM   #26
jshum
jshum's Avatar
Drives: Scion - FRS
were those 20 alignments done just because you wanted to?
or do you actually feel after that incident, the alignment is easy to go slightly off?
Old 06-04-2014, 12:41 AM   #27
Dezoris
Dezoris's Avatar
I am not a normal car owner, I can tell when the alignment is off front or rear by a fractional amount mainly from karting so much. Usually after about 3 hard core autox I can feel the toe is uneven in the front although the wheel is still center. Same with track days usually after two I re-align.
Its not needed but I am very particular.
So the short answer is I have never had the wheel go off center like you had except at that that one event and it was a very rough surface, that was a year ago for me.
So I would not worry.
As long as your strut bolts are tight, control arms, brace, tie rods, ball joints are all tight just drive it like you want.
So i broke my wheel speed sensor bkblitzed Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 11-18-2016 04:04 PM
My ECUTEK usb key broke.. JerryMichaels7 Software Tuning 6 02-07-2014 12:53 PM
Broke down and did the interior. jybrd Cosmetic Modification (Interior/Exterior/Lighting) 20 07-15-2013 08:49 PM
Broke Screw on OEM FRS mudguard :( shellslinger Scion FR-S / Toyota 86 GT86 General Forum 7 06-20-2013 11:29 PM
Oh-Oh's, I Think I Broke It! track_warrior Issues | Warranty | Recalls / TSB 232 06-12-2013 10:58 PM
