Old 05-12-2014, 08:04 PM   #393
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Originally Posted by mit_peid View Post
Anybody else running 17x9 +35 and 245/40/17 with Eibach Pro-Kit (1" drop) and only camber bolts. Any rubbing? How much poke do you have if you maximize the negative camber in front? Any fender work needed?
Im still waiting on my camber bolts, i have the prokit ready to install. I also have 255s
Sent from my IBrick
Old 05-12-2014, 08:06 PM   #394
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
Sent from my IBrick
Is that on stock height and 255/45 or 255/40? Those tires look extremely meaty!
mit_peid is offline   Reply With Quote
Old 05-12-2014, 08:08 PM   #395
SmsAlSuwaidi
Boosted
Yes sir stock highest. they are 255/40/17 toyo R888, r compounds. Sadly im still spinning them i might need to warm them up better or adjust pressure
Sent from my IBrick
Old 05-13-2014, 10:31 AM   #396
wrussi
wrussi's Avatar
Drives: 2013 frs
Originally Posted by Silver Ignition View Post
any rubbing issues?
on the rear you have to shave the bumper tabs but its no biggie. the fronts there is a small tab by the sidemarker that you have to bend a little bit if you are anal like me. besides that no rubbing
wrussi is offline   Reply With Quote
Old 05-13-2014, 10:50 AM   #397
uRBAN_Metal
Drives: '13 BRZ
I have 17x9 +35 with 255/40 RE-11s, Eibach Pro Kit, and Whiteline camber bolts set to max negative and I'm not rubbing anywhere at all. The front tires are extremely close to the spring perch, but I haven't had any rubbing issues even after some spirited cornering tests.
I don't have any more pics right now, but here's a shitty cell phone shot I had.
uRBAN_Metal is offline   Reply With Quote
Old 05-21-2014, 12:27 AM   #398
wrussi
wrussi's Avatar
Drives: 2013 frs
more from a shoot i did the other day..
Old 05-21-2014, 04:09 AM   #399
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
17x9 +35mm with Nitto NT01 235/40/17
Fortune Auto coilovers (9k/9k swift spring upgrade)
About 1.75" drop
-3.0 front camber
-2.8 rear camber
glamcem is offline   Reply With Quote
Old 05-31-2014, 05:44 AM   #400
Teku18
Drives: 2014 WRB BRZ
17x9 +35
Stock height no spacers
Front tires: 235/45/17
Rear tires 255/40/17
Front
Rear
Side
I will update when I get my coils in. I have front camber bolts to go with them if I should need it. Not sure at the moment.
Teku18 is offline   Reply With Quote
Old 05-31-2014, 03:17 PM   #401
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
Any pics of White twins on black RPF1s??
fooddude is offline   Reply With Quote
Old 06-01-2014, 11:09 PM   #402
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
My sig
1Cor10:23 is offline   Reply With Quote
Old 06-01-2014, 11:20 PM   #403
1Cor10:23
1Cor10:23's Avatar
Need an opinion - what color stickers should I run? Stock red ones that came with black wheels would definitely clash. Narrowed it down to blue, sky blue, or yellow. Thoughts?
Old 06-02-2014, 12:25 AM   #404
fooddude
Niiice! Can't wait to see it lowered
Stickers? imo, none.
Old 06-02-2014, 11:10 AM   #405
1Cor10:23
1Cor10:23's Avatar
Saving up for Ohlins R&T
Old 06-02-2014, 01:01 PM   #406
Malt
Drives: 2015 WRX
Blue. Oh and change out those side markers for clear ones ASAP
Malt is offline   Reply With Quote
Wheel Directory: Enkei RPF1 17x9.0 +45 LevinPhan Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 265 06-04-2024 11:13 AM
Group Buy: Enkei RPF1 17x9 +35, 17x9.5 +38, 18x9.5 +38 ***In Stock*** LSD Motorsports Groupbuys 246 08-29-2013 01:35 PM
WHITE Enkei NT03+M 18x9.5 / Enkei RPF1 17x9 Touge Factory Wheels and Tires 2 02-05-2013 04:53 PM
