Old 06-01-2014, 08:31 PM   #141
tracerit
Drives: '13 SSM BRZ Limited 6MT
whgat are the correct size lugnuts to get for this wheel?
tracerit is offline   Reply With Quote
Old 06-01-2014, 11:05 PM   #142
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
same size as any other Twin's lugnuts....
Old 06-02-2014, 12:09 AM   #143
tracerit
so stock will work then?
I read in the XXR 527 thread that those wheels needed new longer lugnuts and recall someone mentioning any aftermarket wheel would need longer ones.
Old 06-02-2014, 12:22 AM   #144
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
get m12x1.25 thread pitch lug nuts with properly "coned"/tapered ends and you will be good to go.
Length isn't a huge deal. the long ones will stick out and be obvious, the shorter ones (closed or open) will probably look cleaner. Length is for style and also for making it easier to get a good amount of thread "captured" so you get a good hold. Any "after market" tuner style lug nut, as long as it is the correct size (m12x1.25) will work fine for you
Note His gold ones are long, his black ones are short, so pick your style preference
The Following User Says Thank You to SkAsphalt For This Useful Post:
tracerit (06-02-2014)
Old 06-02-2014, 02:27 AM   #145
Boxer486
Drives: small
Originally Posted by Goya View Post
Rota Titan Hyper Black 17x8 +45 5x100
These are wedssport tc105n replicas
no spacers
RSR super down springs
stock 215 tires
I didn't think anyone has posted pics of the Titans in Hyper silver yet.
I'm pretty happy with the wheels. Even with the weak offset, they still have a slight concave look.
I tried out some gold lug nuts but I wasn't really feelin it. Threw black ones on there after. Heres pictures with both
Mind if I ask where you got them and how much?
Boxer486 is offline   Reply With Quote
Old 06-02-2014, 12:20 PM   #146
Goya
Goya's Avatar
Drives: 2013 SWP BRZ
The gold lug nuts are BLOX, i think they were about $65-70 on ebay.
The short black ones i have now are mutekis. I bought them for about $50 at Touge Factory.
Goya is offline   Reply With Quote
Old 06-02-2014, 12:21 PM   #147
Boxer486
Drives: small
The gold lug nuts are BLOX, i think they were about $65-70.
Nah, the wheels man. ;P
The Following User Says Thank You to Boxer486 For This Useful Post:
Goya (06-02-2014)
Old 06-02-2014, 04:05 PM   #148
Goya
Goya's Avatar
oooooooh ha! I got the wheels from an ebay seller called WheelBay for $730. I would not recomend buying from them at all. There was confusion in their listing with the wheel's offset and they only sent 3 wheel caps.
I should have bought them from WheelDude, ive only heard good things.
Old 06-02-2014, 04:54 PM   #149
Boxer486
Drives: small
Problem is wheeldude never shows having any 17x8 5x100 45s in hyper black.
Old 06-02-2014, 05:22 PM   #150
Goya
Goya's Avatar
I learned shortly after I placed my order that you can just email or send a PM to wheeldude requesting the spec and color. Im pretty sure he will have them.
The Following User Says Thank You to Goya For This Useful Post:
Boxer486 (06-02-2014)
Old 06-13-2014, 03:01 PM   #151
MokSpeed
Granny Shifter
MokSpeed's Avatar
Drives: 2014 FR-S
no spacers
stock 215 tires
Are these in Hyper Black finish or Hyper silver? You stated both so I wanted to make sure to order the right finish. Thanks for your response in advance!
MokSpeed is offline   Reply With Quote
Old 06-13-2014, 04:50 PM   #152
Goya
Goya's Avatar
They are called Hyper Black. There is no hyper silver, i just mistakenly say that sometimes because they are actually silver in color.
Old 04-15-2015, 11:01 AM   #153
CombatFetus
Drives: 2013 Raven FRS
Do stock lugs work on these?
CombatFetus is offline   Reply With Quote
Old 04-15-2015, 11:29 AM   #154
Goya
Goya's Avatar
No, stock lug nuts and wheels use whats called a Ball Seat. Aftermarket wheels are made for cone seat lug nuts. Most aftermarket lug nuts are cone seat lug nuts by default.
Group Buy - Rota Slipstreams or Rota Grid davidsolarbell Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 12-17-2013 12:04 PM
Wheel Directory: Rota Grid 2 17x8.0 +38 stvrjs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 27 09-02-2013 04:08 AM
Rota SDR in Gunmetal? zooki Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 11-10-2012 12:08 AM
Wheel Directory Rota PWR 18x9.5 +35 gabeg86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 10-31-2012 01:38 PM
