#883 | |
Drives: MT WRB BRZ Limited, 2007 911s
Well in that case I may pick up a front lip. I'm getting tired of having to continuously rub off that rubber residue every time I was the car. Sent from my iPad using Tapatalk |
| The Following 2 Users Say Thank You to was385 For This Useful Post: | Scooby South (05-31-2014), Turkish (05-31-2014) |
#884 | |
Drives: '87 Corolla GTS, '13 FR-S 6MT
Then wouldn't that make the Whiteline diff cradle inserts illegal since it also adds a big metal plate? Wait, is it illegal!?
#885 | |
Conedancer
Drives: 2013 Subaru BRZ SWP
The Whitelines have 'washers' to hold them in.. and they are 99% urethane and the go on Diff mount on subframe. ![]() Bill
Join my BRZ/FRS FB Group ![]() Thanks to:Kartboy/Wheeldude/Nameless Performance /Gaurd Transmission LSD |
#886 |
Drives: BMW 135i, soon to BRZ
That's the Blue Series stuff, right? I'm still of the hopeful mindset that you won't even have someone challenge that in class, but if they do it's on the basis of "model". Though model does start down the road of "appearance" as a signifier of difference, ST already has the clarification that all parts of a 3-series generation is considered the same model. AKA it's why the 325's and 328's have M3 bumpers. That can only guide the PC though, and isn't official. Might be ripe for a clarification just in case of weeny protests.
| The Following User Says Thank You to mrazny For This Useful Post: | Scooby South (06-02-2014) |
#887 |
Car Nut
Drives: BMW 335d, Toyota Echo RS, FRS
For STX with no power mods do you guys recommend to stay with a 245/40/17 on a 8" wheel or a 255/40/17 on a 9" wheel?
#888 |
Dodging cones
Drives: 2013 BRZ Limited, 93 Z28
If you're buying new wheels, go with the 9s. If you're already on the 8s, dont spend the money until you're well acquainted.
#889 |
Serial Cone Killer
Drives: '14 BRZ - WRB Premium 6MT
How do y'all feel about wheel spacers? Specifically, I'm considering 5mm on all four wheels. Will I need longer studs to be safe for autocross or will oem be fine? I'm currently using the stock wheels until I can afford rims and tires.
Sent from my SM-G900V using Tapatalk
#890 | |
Dodging cones
| The Following 2 Users Say Thank You to Kido1986 For This Useful Post: | Scooby South (06-02-2014), Turkish (06-02-2014) |
#891 |
Drives: 22 GR86, 13 FR-S, AP2 S2000
I would stay away from 5mm. I tried a 5mm spacer with a set of 17x9 Rota DPT wheels and felt really uncomfortable when I could only get 3.5 revolutions with a hand tighten. 3mm was just enough for breathing room w/ stock spring perch and 255 RS-3s.
3mm gave me 6+ revolutions with a hand tight plus maybe 1 more after torqueing the lugs. |
| The Following User Says Thank You to AyJay For This Useful Post: | Turkish (06-02-2014) |
#892 |
Grip>Drift
Drives: FRS
I run 5mm spacers but I have 10mm extended studs. It was a worthwhile upgrade.
#893 | |
Conedancer
![]() Bill
#894 |
Car Nut
#895 |
Dodging cones
I'd still say wear out the set of tires you're on first, unless throwing around $1500 for wheels and tires is easy money for you (I'm a poor SoB lol)
#896 |
Car Nut
My RS-3s are less than 25% tread right now so its time anyway, I will recoup around $1000 for my Volks most likely.
| Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
| SCCA sway bar rules | gmookher | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-01-2012 06:48 PM |
| Suggestion for vendor rules... | Tainen | Site Announcements / Questions / Issues | 31 | 08-15-2012 01:53 PM |
| Rules for posting in this section | Hachiroku | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 06-25-2012 11:02 AM |
