Old 05-30-2014, 04:12 PM   #99
ModBargains
ModBargains's Avatar
Drives: FRS, M3
Thumbs up sweet Coilovers
Nice pick on the coilovers.
ModBargains is offline   Reply With Quote
Old 05-30-2014, 10:22 PM   #100
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
What's the max lower front/back?
And, what's the max lower front/rear with the addition of HVT fronts and RaceSengs rears? (ie: how much more lowering adjustability do the top plates additionally give?)
If I got these ohlins, and want to lower 1.25-1.5" all around, do I need to get the HVT front plates and also the RaceSeng rear plates? ....or, do I only need to get the rear plates?
From what I've read, it's only the rears that can't lower the car much (but the fronts lower it pretty decently)...correct?
fooddude is offline   Reply With Quote
Old 05-30-2014, 10:35 PM   #101
dp1
driving smoother faster
Drives: Sold
Originally Posted by Dezoris View Post
@dp1 @Racecomp Engineering @mav1178
Do you guys remember the TQ value for tightening the 5mm allen heads on camber plate bolts?
Sorry, I don't wrench on my car...mostly limited to swapping wheels and pads for track/street use...perhaps @Prime Motoring could advise
dp1 is offline   Reply With Quote
Old 05-30-2014, 11:12 PM   #102
kster1
kster1's Avatar
I just checked the Ohlin's instruction manual and it states 12-14Nm for the camber adjustment screws.
kster1 is offline   Reply With Quote
The Following 2 Users Say Thank You to kster1 For This Useful Post:
Chazzzy (08-04-2016), Dezoris (05-31-2014)
Old 05-30-2014, 11:15 PM   #103
kster1
kster1's Avatar
Anyone know how I can replacement springs? I'd like to go a little stiffer in the rear (7kg) assuming the shocks can handle this without a rebuild.
Old 05-30-2014, 11:40 PM   #104
CSG David
CSG David's Avatar
You'll need to measure the spring diameter (ID and OD) and spring length.
The Following User Says Thank You to CSG David For This Useful Post:
kster1 (05-30-2014)
Old 05-30-2014, 11:43 PM   #105
kster1
kster1's Avatar
That would be a problem since they are installed on the car.
Old 05-31-2014, 12:05 AM   #106
Dezoris
Dezoris's Avatar
Talk to racecomp or Jeff at Ohlins. swift and a few others have compatable 2.5ID springs that will work.
The Following User Says Thank You to Dezoris For This Useful Post:
kster1 (05-31-2014)
Old 05-31-2014, 01:50 AM   #107
fooddude
What if you want to keep the cute Ohlins yellow/gold color scheme and don't want to get Swift/Hyperco? ..does Ohlins offer their own coilover springs in many diff rates?
Old 05-31-2014, 08:14 AM   #108
Dezoris
Dezoris's Avatar
Ohlins outsources spring production to a few various japanese companies.
BPM (08-19-2019)
Old 05-31-2014, 02:02 PM   #109
Anthonytpt
Anthonytpt's Avatar
Drives: '13 Argento 6MT FR-S
They may be Eibach springs. That's what the rep at Performance Shocks Inc. told me.
Anthonytpt is offline   Reply With Quote
Old 05-31-2014, 03:01 PM   #110
fooddude
I just want to keep the pretty yellow color if I change to 7k or 8k all around lol.
Old 05-31-2014, 03:09 PM   #111
kster1
kster1's Avatar
Please send me a PM if you do end up getting new springs. Then I'll just follow in your footsteps.
Old 05-31-2014, 03:19 PM   #112
fooddude
ohlins road and track shock absorbers CyberFormula Suspension | Chassis | Brakes -- Sponsored by 949 Racing 31 11-11-2014 05:00 AM
>> OHLINS Road & Track Coilovers - First Shipment IN - FT86 Special - FREE Shipping! Circuit Motorsports Brakes, Suspension, Chassis 90 08-16-2013 12:39 PM
Ohlins Road & Track Coilovers - IN STOCK!!! RallySport Direct Brakes, Suspension, Chassis 7 05-28-2013 04:11 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
Ohlins Road & Track Subaru BRZ and Scion FR-S HP Autowerks Brakes, Suspension, Chassis 0 04-24-2013 03:27 PM
