Old 05-29-2014, 10:38 PM   #1135
Thrustin
Drives: 2014 BRZ Limited, 2013 Focus ST
Originally Posted by SeanRTR View Post
I run these in the rear of my car, see page 2 of my build thread.
I've had success with them. I'll be updating the thread with this weekends results soon.
http://www.ft86club.com/forums/showthread.php?t=41955
Do you (or anyone else) think there'd be a problem running that size/model in the front.
Thrustin is offline   Reply With Quote
Old 05-29-2014, 11:14 PM   #1136
SeanRTR
C-Street AutoX
SeanRTR's Avatar
people have reported that it fits just fine I may try it myself but right now I'm content with a staggered set up.
-2013 Scion FR-S C-Street
Gearhead Homes - Homes geared towards car enthusiasts: https://www.facebook.com/GearheadHomes.RealEstate
SeanRTR is offline   Reply With Quote
Old 05-30-2014, 08:42 AM   #1137
AustinTX
Pawn in game of life
AustinTX's Avatar
Drives: 19 STX BRZzz
I'd like to hear how the car changes when you switch the larger tires to the front and the smaller tires to the rear. It'd be a good direct comparison of whether wider tires actually increase grip on this car
Autocross nut
AustinTX is offline   Reply With Quote
Old 05-30-2014, 10:04 AM   #1138
SeanRTR
C-Street AutoX
SeanRTR's Avatar
I can probably do this for you... If they make a good course this weekend, I'll try it sunday. Strange local club format allows us to run whenever we want essentially....
Old 05-30-2014, 10:53 AM   #1139
renfield90
The Stig's German cousin
VERY interested in this as well.
Old 05-30-2014, 12:39 PM   #1140
simpleisbest
Senior Citizen
Drives: Scion FR-S
I'm thinking of picking up a lightly used set of 245/40/17 BFG Rivals to use in CS. Does anyone here have any experience with that size/model tire for autoX purposes (with stock size rim of course)? Thoughts?
We've run them. They are difficult to mount, so your tire mounter may not like you much after.
We noticed good lateral grip vs 225. Feel after initial turn in is a bit more vague and there may be a slight increase in understeer but it can be dialed out with tire pressure, fsb setting/choice, alignment.
simpleisbest is offline   Reply With Quote
Old 06-04-2014, 08:24 AM   #1141
travisb
travisb's Avatar
Drives: N/A
Originally Posted by Kido1986 View Post
Nearly everyone is using the OEM camber bolts with ~.8-1.5 degrees of negative camber
@Kido1986
I have my second autox in the BRZ this weekend, fully stock. The last time out I felt like I was sliding all over almost the entire time. Air temp was about 80 and loose pavement.
My questions are:
1. How should I set up my alignment (caster, f/r camber, and f/r toe) for autox and DD without too much excessive wear on the Primacys?
2. What PSI should I be aiming for in the autox? Last time PSI was around 38-40 (with my cheap gauge). It should be around 90 air temp this weekend and same location.
travisb is offline   Reply With Quote
Old 06-04-2014, 08:56 AM   #1142
avp1
Drives: Traded BRZ for Supra
Originally Posted by travisb View Post
@Kido1986
My questions are:
If you want grip, start with tires. Stock ones are useless in any competitive driving. Get grippiest street tires you can fi d and feel the difference. Suspension tuning should only be next step after that.
avp1 is offline   Reply With Quote
Old 06-04-2014, 08:59 AM   #1143
travisb
travisb's Avatar
Drives: N/A
But right now I still have the stock tires. I hope to get new tires in a few months. So I am looking for recommendations with my current setup.
Sent from my SGH-M919 using Tapatalk
2014 BRZ, SWP, OFT, Kosei K4R 17x7 with ZII SS
Old 06-04-2014, 09:17 AM   #1144
edj
edj's Avatar
Drives: 2022 Toyota GR86
get the crash bolts for the front and max out the camber.
castor really isn't adjustable.
0 degree toe in front.
+0.1 toe-in for the rear tires.
camber isn't adjustable.
tire pressures: 35 psi all around.
the OEM tires do not grip so no need to change psi from stock.
have fun!
Eric
2022 Toyota GR86 Steel
edj is offline   Reply With Quote
Old 06-04-2014, 09:30 AM   #1145
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
after two years on the stock tires doing a bit of track and a bit of autocross I can tell you that just keeping them at stock pressures works perfectly well,
there's nothing there for you to chase
Old 06-04-2014, 09:32 AM   #1146
vroom4
Hell be chasing the back end of the car as it passes him if his experience is anything like mine with the car in 100% stock trim
vroom4 is offline   Reply With Quote
Old 06-04-2014, 09:42 AM   #1147
Kido1986
Dodging cones
Kido1986's Avatar
Drives: 2013 BRZ Limited, 93 Z28
@Kido1986
My questions are:
have fun!
@travisb , What this guy said ^^
Originally Posted by trevorovert View Post
Originally Posted by mrbillclintong View Post
If you guys spot any riced frs/brz post them here just for laughs no hating please.
Isn't there already a thread like this? It's called aggressive wheels or summat...
C Street Build/Progress Questions about C Street Autocrossing?
Kido1986 is offline   Reply With Quote
Old 06-04-2014, 09:46 AM   #1148
travisb
travisb's Avatar
Drives: N/A
How maxed out is maxed out? Should I really ask for as much as I can get for a DD or is there are good target number to shoot for?
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
