Old 05-30-2014, 12:26 AM   #29
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Originally Posted by Scavanger View Post
Do you think I would need to build anything up to handle about 350whp I only plan on doing a 93 tune running 10psi
I would guess 93 with stock fueling and 10psi on a reliable long term tune will net you around the 300-310 range without changing the fueling setup, running a 3" catless exhaust, and having an aggressive tune. That being said, at that range the car is still very fast. My tires spin in third @8psi if I hit it too hard.
I'm running a stock block and regularly run my big boost (500+rwhp on E85.) It might not last forever, but I am looking to build it in a year or so.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Hawaiian is offline   Reply With Quote
Old 05-30-2014, 12:49 AM   #30
Scavanger
Avid searcher of things
Scavanger's Avatar
Drives: Scion Fr-s 10 series
I plan to upgrade to 900cc injectors and a new pump as well so i can push it a little more to get to that 350 and currently I have a full exhaust aside from headers due to the fact I would have no use for them after I get this but I also have the trd cold air intake which will be useless also. I can minimize my spin by getting better tires but if I try hard enough I can spin in third now if I turn off traction control and stability control haha
Scavanger is offline   Reply With Quote
Old 05-30-2014, 01:17 AM   #31
Hawaiian
That guy
Hawaiian's Avatar
I'm running 265 z1 in the rear though
Ultramarine mt FR-S
P&L stage 1 turbo
Old 05-30-2014, 08:20 AM   #32
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
You don't need 900cc injectors to reach 350 whp. You aren't injector limited, you are octane/knock limited in reaching 350 whp. I personally wouldn't run 350 whp unless you are on E85.
The Following 2 Users Say Thank You to King Tut For This Useful Post:
evo4g63 (05-30-2014), Hawaiian (05-30-2014)
Old 05-30-2014, 10:46 AM   #33
Scavanger
Scavanger's Avatar
If I run this system with a e85 tune I will be pushing well over 400 and I don't want that, also there isn't anywhere near me where I can get e85 so I would have no use for it currently
Old 05-30-2014, 10:54 AM   #34
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
If you do not have access to e85 it would be best to stay on the wastegate spring pressure. Unless you are willing to push the good old knock wall to hit your 350whp goal on pump. I would not rec to do that however.
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline   Reply With Quote
Old 05-30-2014, 11:07 AM   #35
Scavanger
Scavanger's Avatar
So I should just stick to about 325
Old 05-30-2014, 11:10 AM   #36
PrimeMotoring
PrimeMotoring's Avatar
Drives: FRS with 2jz, 2015 STI 9.68@147
350whp is relative to dyno. we see about 300-310whp on our Mustang on pump 93 on wastegate. Dynojet would bring you closer to your goals.
PrimeMotoring is offline   Reply With Quote
Old 05-30-2014, 01:30 PM   #37
P&L Motorsports
P&L Motorsports's Avatar
Drives: '13 Turbo BRZ (AT) & '13 FRS
Kind of a cool update on our exhaust components. We're now including a laser cut badge on all of our exhaust pipes! We will also be incorporating this into our intercooler piping and intake pipes in the near future.
P&L Motorsports is offline   Reply With Quote
The Following User Says Thank You to P&L Motorsports For This Useful Post:
PrimeMotoring (06-04-2014)
Old 05-30-2014, 01:47 PM   #38
Fear
Drives: Ft86
Originally Posted by Fear View Post
Specs on fronts?!?
Fear is offline   Reply With Quote
Old 05-31-2014, 06:42 PM   #39
DR 86
DR 86's Avatar
I have the NA header and want to upgrade to this kit next year. How would that work? Thanks!
Perrin CAI|Perrin MCB|P&L header|Motiv OP/FP|MXP catback|Tein Type Flex coilovers|Eibach F/R sway bars|GS front strut brace|Street:PM HC+800/Track:Carbotech XP10|StopTech slotted rotors/SS lines|SBC RPF1s|Street:FK453/Winter:Pirelli SottoZero3/Track:Toyo R888s|Leg Sport rear spoiler|EcuTek Tuned|OEM oil cooler|4th/F1 brake lights
DR 86 is offline   Reply With Quote
Old 06-02-2014, 11:26 AM   #40
P&L Motorsports
Pretty simple actually, you send in your existing header, we use it to fabricate the turbo manifold. This takes a sizable chunk of cost off the kit by reusing the NA header.
-Ty
Scavanger (06-03-2014)
Old 06-02-2014, 09:39 PM   #41
DR 86
DR 86's Avatar
What's the turn around for doing that and installing the kit? I'd prefer to have it installed either at P&L or Prime, and was thinking about planning a vacation around it lol.
The Following User Says Thank You to DR 86 For This Useful Post:
Old 06-03-2014, 12:08 PM   #42
Scavanger
Scavanger's Avatar
So if i get the OFH i can use that as my turbo manifold so it wouldnt be a waste of money?
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
Five Axis Edition FR-S Owners Thread digital_assassin FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 563 07-08-2015 09:22 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 12:58 PM
P&L Turbo Owners Topic Thread GTB/ZR-1 Forced Induction 4 09-01-2013 06:27 PM
