Old 05-26-2014, 11:09 PM   #1
Doozer
Doozer's Avatar
Drives: gt86...among others
Racer-X Rear upper CA's
We finished the install last week and got to test these on the track. Great results.
Our camber gauge was zeroed for the OEM CA's and 2* were gained by the Racer-X arms. Very easy to make trackside camber adjustments as each full turn on the balljoint is approx .5*.
Front lowers will be installed soon, but we forgot to order ball joints before the race....
racing gods live deep in corners
Doozer is offline   Reply With Quote
The Following User Says Thank You to Doozer For This Useful Post:
Jeff@Racer X Fab (05-27-2014)
Old 05-29-2014, 05:30 PM   #2
neurokinetik
neurokinetik's Avatar
Drives: 2013 Scion FR-S Firestorm
What about adjusting for less camber, as some of us already have too much? Can I take out 1.5 - 2 degrees?
neurokinetik is offline   Reply With Quote
Old 05-29-2014, 11:26 PM   #3
Doozer
Doozer's Avatar
You should contact RacerX directly, he seems like a sharp guy and helped us with our tech questions.
Old 05-30-2014, 09:03 AM   #4
Jeff@Racer X Fab
Drives: Subaru BRZ, Toyota MR2 Turbo
Yes, they can also remove camber and should easily be able to take out 1.5 to 2 degrees.
Jeff@Racer X Fab is offline   Reply With Quote
The Following User Says Thank You to Jeff@Racer X Fab For This Useful Post:
neurokinetik (05-30-2014)
Racer X Fabrication: Upper rear control arms, in stock/ready to ship!! Jeff@Racer X Fab Brakes, Suspension, Chassis 25 01-24-2014 11:42 AM
Whiteline rear upper camber bushings Dpark27 Brakes, Suspension, Chassis 1 11-04-2013 12:57 AM
Adjustable rear upper control arms??? Supermassive Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 09-29-2013 09:17 AM
Oem rear upper control arms Jhon19lopez Brakes, Suspension, Chassis 1 08-25-2013 09:01 PM
Robispec rear upper tops Simmons Brakes, Suspension, Chassis 4 08-25-2013 06:28 PM
