Old 05-29-2014, 11:20 AM   #687
Deathalo
Drives: 2013 WR Blue Limited Manual BRZ
@burmjeff or @milhouse I see you guys got Viper working, I have it installed but it doesn't seem to affect anything, how did you set it up?
Deathalo is offline   Reply With Quote
Old 05-29-2014, 11:50 AM   #688
DC2R
Drives: 2014 Scion FR-S
In regular Android there is a menu option in system settings to choose equalizer. It seems we gave no access to change the active equalizer
Sent from my SM-G900T using Tapatalk
DC2R is offline   Reply With Quote
Old 05-29-2014, 11:58 AM   #689
SPT Legacy
Drives: 2014 Lightning Red BRZ
No
Aw
SPT Legacy is offline   Reply With Quote
Old 05-29-2014, 03:15 PM   #690
Deathalo
I got Viper working! Turns out to get it working in Poweramp you have to turn off Direct Volume Control in the Audio Settings of Poweramp. Also, turn off EQU and Tone in the Equalizer screen in Poweramp. Then I turned on the equalizer in Viper for "Phone Speaker" and the audio changed as I manipulated the EQ, also worked in Pandora!
The Following User Says Thank You to Deathalo For This Useful Post:
DC2R (05-29-2014)
Old 05-29-2014, 03:26 PM   #691
Prog
Prog's Avatar
Drives: 2016 Cadillac CTS
Originally Posted by SPT Legacy View Post
Aw
They're like $13 on Amazon.
Prog is offline   Reply With Quote
Old 05-29-2014, 04:12 PM   #692
Deathalo
DEAL BREAKER
The Following 2 Users Say Thank You to Deathalo For This Useful Post:
DC2R (05-29-2014), Prog (05-29-2014)
Old 05-29-2014, 04:53 PM   #693
BennyBRZ
Drives: 14 BRZ Limited - DGM
Hey guys, I tried to get my USB adapter that I bought from the Amazon link in this thread working and it won't plug in.
Looks like the one I got has 4 pins in it and the plug in the car has 5.
Anyone able to confirm how many pins the USB adapter should have? I think I may have been shipped the wrong one, but I can take a picture if someone wants to compare.
Oh and the adapter I got was brown, not gray like the picture.
*Edit* Are you supposed to remove the oem cable plugged into the USB port and replace it with this adapter or does the adapter plug into the oem cable for the USB port? I'm a wiring noob when it comes to this stuff and I tried to remove the usb plug but its hard to reach so I thought I would ask first.
BennyBRZ is offline   Reply With Quote
Old 05-29-2014, 08:33 PM   #694
SubaSteve
Captain Cocoa
Drives: CBS BRZ MT
My dumb ass sold my brackets with my headunit where can I find some replacements?
SubaSteve is offline   Reply With Quote
Old 05-29-2014, 08:48 PM   #695
DC2R
The guy you sold it to
The Following 2 Users Say Thank You to DC2R For This Useful Post:
Deathalo (05-30-2014), Prog (05-30-2014)
Old 05-30-2014, 02:02 AM   #696
Deathalo
[ame]http://youtu.be/khSIYmTzt6U?t=8s[/ame]
Old 06-01-2014, 01:53 PM   #697
inositle
Drives: Subaru BRZ Limited WRB
Got mine in on Friday, installed it and most everything is working well. Forgot to wire up the amp power line on Pin #9 but luckily remembered people talking about that a few pages ago. My current problem is that there's almost no space for apps; also, I was trying to install Co-Pilot (20-something MB according to Play Store) and it said I didn't have enough space even though it looks like I had a few 100MB available.
I saw a few pages ago that there was talk of a firmware update that would resize the app partition potentially. Is this the case? Any solution to get more app space?
Thanks!
EDIT: I was able to install via side loading. Another question I have... is there a known way to replace the CaFi home screen? If not, is there a way to reprogram what app the GPS button & "CarNavi" GUI button open? Also, when I push the Radio button when I'm in another app, it typically switches to the next "mode" (e.g., FM1 -> FM2 -> FM3 -> AM1...). Any way to disable this? I just want to push radio & switch stations.
inositle is offline   Reply With Quote
Old 06-01-2014, 04:22 PM   #698
DC2R
Thanks!
Still waiting on that update...... partition size is ridiculous.
You can set GPS button in settings. I set it to Google now
Old 06-01-2014, 04:52 PM   #699
Prog
Prog's Avatar
Realized my lights on the unit stay on after the car is off with the headlight option enabled, as someone else pointed out. Anyone figure out a fix other than turning headlight option off?
Old 06-02-2014, 01:32 AM   #700
godzuki
godzuki's Avatar
Drives: frs
Can this unit share an iphone's (4 or 5) internet connection via usb tethering?
godzuki is offline   Reply With Quote
REVIEW: Ca-Fi Toyota Universal - Stock Fitment ANDROID Stereo SHIFTER Electronics | Audio | NAV | Infotainment 16 06-13-2017 07:23 PM
Android, bluetooth, Music, and the FR-S stock pioneer stereo JayNutter Electronics | Audio | NAV | Infotainment 27 12-18-2014 04:54 AM
How to: Torque on an android powered stereo with no hacking v. Ca-Fi Dashlinq4 SHIFTER Electronics | Audio | NAV | Infotainment 29 04-07-2014 05:58 AM
