#99 |
Drives: 13 White MT FR-S
$24 for one of those latches!
#100 |
Drives: Scion FRS Firestorm
I'm having this issue really bad on my car. Both sides. Bumpers been off a ton of times so i'm sure whatever holds it in is pretty worn down. :/ Wish there was a DIY fix for this. I might just try jamming some 3M tape in there and see what happens. :P
#101 | |
Drives: 2013 BRZ Limited WRB
Go to the dealer, TSBs exist for that issue
#102 |
Will they honor it knowing that my car is heavily modified? And do you know what the TSB number is?
#103 | |
I only have the canadian tsb number, shouldnt be too hard to find by going at the dealer. And unless you have an aftermarket bynper, I dont see why they would deny it
#104 | |
#105 | |
Put the stock one back on ? Get the new clips, reinstall aftermarket ? I dont know man,but worst they can say is no !
| The Following User Says Thank You to Simon99 For This Useful Post: | blackfireball5 (05-28-2014) |
#106 |
This says it isn't a service bulletin but then I don't know what it is. lol.
S-TT-0042-12 (Not a TSB): Body panels that aren’t flush http://www.ft86club.com/forums/showthread.php?t=21868 Ah, it stands for Tech Tip http://www.tundraheadquarters.com/bl...lity-problems/ |
#107 |
Drives: 2013 black AT, OFT, 4.65
I'm not going to let this die. this is my front bumper driver side bumper is only been removed once and been scratched a couple times from ground clearance issues but never hit directly in the front.
#108 |
Yup mine is still bad too. I maintain the bumper plastic is too soft and the clips are too short
#109 |
Drives: 2013 Raven FRS 6MT
this worked for me.
http://passwordjdm.com/PasswordJDM-Q...P4746C329.aspx |
#110 |
Ugh those stance bumper elastic things, yeah no thanks
#111 |
Drives: 2013 FRS
I guess I have been lucky. Pulled the front bumper off 3 times without this happening. I did forget once to put the clips back in above the sidemarker housing both sides and it was popping out a bit there until I realized I had forgotten to put them back.
#112 | |
Drives: 2013 Scion FRS
I bought and replaced these 2 parts and the problem still there.
it is not going away. Quote:
| Front Bumper Black Vinyl | Juanito08 | Exterior Parts (Aero, Lighting, Etc.) | 37 | 09-18-2015 04:09 PM |
| Front bumper holes... | BRZ88 | BRZ First-Gen (2012+) — General Topics | 29 | 08-14-2012 12:19 PM |
| Other than SR front bumper this is the only other one I like | Hanzo | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 07-09-2012 03:30 PM |
| BRZ to FR-S front bumper swap? | r4m3n | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 04-20-2012 05:29 PM |
| Buy this front bumper for G37 Coupe? | WhatIs86For | Other Vehicles & General Automotive Discussions | 12 | 02-26-2011 02:24 AM |
