Old 05-27-2014, 05:20 PM   #1331
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
Originally Posted by gramicci101 View Post
A 12V air compressor wouldn't work?
I had no luck with them at all; they either failed or were a pain to use. The bike pump just works - it even has a built in gauge for those who don't have one and don't want to borrow one.
dradernh is offline   Reply With Quote
Old 05-27-2014, 05:23 PM   #1332
gramicci101
Off Topic
Originally Posted by CSG David View Post
We work from everywhere. I AM BATMAN! Batman...baatman...ba...
I'm not going to blow that one up from using it so much. It's also going to blow the fuse on non-CR cars too.
You'd think that Batman would have access to better tools...
Old 05-27-2014, 05:26 PM   #1333
CSG David
CSG David's Avatar
All about that utility belt.
Old 05-27-2014, 05:28 PM   #1334
gabe0807
Drives: '13 FR-S (White)
Everybody laughs at me for bringing a bike pump. I'm also the guy everybody asks to borrow the bike pump to pump up their tires after the track day.
See. I solved the obesity problem already.
The worst part about using a bike pump is everyone interrupting you to tell you where you can drive to get air. Using a good quality floor pump is not as traumatic as most people seem to envision. Depending on how much air you need, it is generally only a couple of pumps per tire.
gabe0807 is offline   Reply With Quote
Old 05-27-2014, 05:30 PM   #1335
CSG David
CSG David's Avatar
Originally Posted by gabe0807 View Post
The worst part about using a bike pump is everyone interrupting you to tell you where you can drive you get air. Using a good quality floor pump is not as traumatic as most people seem to envision. Depending on how much air you need, it is generally only a couple of pumps her tire.
Save energy and get a pump out of it (Arnold)! Gas and electricity are expensive!
Old 05-27-2014, 05:57 PM   #1336
mokinbird87
BOXER FR
mokinbird87's Avatar
Drives: WRB BRZ Limited
Mike, what`s your opinion on Michelin Super Sports? for everyday / occasional track days is it ok or should I get something more devoted like the RS3s?
mokinbird87 is offline   Reply With Quote
Old 05-27-2014, 09:18 PM   #1337
D K
Stig's dark passenger
Why not just go to autozone and buy a 20 dollar air tank and fill it up??
D K is offline   Reply With Quote
Old 05-28-2014, 01:11 AM   #1338
Doozer
Doozer's Avatar
Drives: gt86...among others
Originally Posted by ZDan View Post
Actually, it's worse than that.
Wheel rate is spring rate multiplied by the SQUARE of the motion ratio, so his wheel rates are:
550 lb/in * .95^2 = 496 lb/in front wheel rate
500 lb/in * .75^2 = 281 lb/in rear wheel rate
I'd swap the springs front to rear to get:
500*.95^2 = 451 lb/in front wheel rate
550*.75^2 = 309 lb/in rear wheel rate
And probably reconnect the rear sway, but then more likely to lift the inside rear...
How on earth did this car end up with 57/43 weight distribution?
Can anyone help explain to a novice how wheel rate/motion ratios are calculated? .75, .82 rear values, I don't understand?
The car is nose heavy because it's still a DD for the owner but the seats and spares are removed for race and track days. No weight is removed from the front of the car.
First I'll learn about suspension, then become a weight Nazi. Maybe sometime after I'll learn to drive...
Thanks guys
racing gods live deep in corners
Doozer is offline   Reply With Quote
Old 05-28-2014, 02:20 AM   #1339
TrogDor the Burninator
TrogDor the Burninator's Avatar
Drives: 2013 Hot Lava FR-S 6 MT
I switched from 400lb/7.1Kg springs on all 4 corners to 340lb/6.1Kg springs on the front and left the 400lb/7.1Kg on the rear, and I can tell you it made a huge difference in rotation of the car through corners.
Other suspension pieces such as front and rear sways are stock, yet I do have much wider 255/35 R18 wheels and tires ...
It was shocking actually how much softening up the front by 60lbs of spring rate did for the handling.
FWIW ...
2013 Scion FR-S Hot Lava 6MT Current Mods: KW V3 Coilovers - Raceseng CasCam Plates - Volk TE37SL Black Edition 18x9 +45 - Dunlop Direzza ZIIs 255/35 - Tomei Expreme Ti 60S - FT86 SpeedFactory UEL Catted Header
TrogDor the Burninator is offline   Reply With Quote
Old 05-28-2014, 02:39 AM   #1340
D K
Thanks guys
Google: motion ratio
Old 05-28-2014, 02:57 AM   #1341
CSG Mike
CSG Mike's Avatar
In irvine? If you're worried about rain/wet, get the RE11.
Otherwise, RS3.
Old 05-28-2014, 02:58 AM   #1342
CSG Mike
CSG Mike's Avatar
FWIW ...
YES, someone else who runs ~15-20% stiffer springs in the rear!
I feel like I'm finally getting my point across
Old 05-28-2014, 01:17 PM   #1343
mokinbird87
BOXER FR
Otherwise, RS3.
I dunno if they fixed it on the RS3s, but my previous experience with the RS2s is that they would get greasy really fast, but I have never noticed it when running on the RE-11s.
some of the track instructors swear by the pilot sports, so I was just wondering if it`s the overhype or if it is really worth the extra $$.
Old 05-28-2014, 01:23 PM   #1344
Thongpocket
Master Troll
Thongpocket's Avatar
Drives: 2013 BRZ Limited
Originally Posted by ddeflyer View Post
I setup some cobra seats on a planted base in my car. I hard mounted the seat and was able to get a nice upright position with about half an inch of clearance where before I was having to recline the seat a substantial amount just to get in while only rubbing the headliner with my helmet (I'm 6'). Further drop would have been possible if I had used steel mounting plates instead of the thicker aluminum ones or if I didn't like such a upright position. If you were needing more and were willing to modify the floor pan then you could probably get quite a bit more drop but that would involve alot of work.
I'm 6'2" so I'm going to need a bit more. I wish there was a place that had seats in stock for me to try near by.
Sent from my XT1080 using Tapatalk
Thongpocket is offline   Reply With Quote
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
