Old 05-27-2014, 05:07 PM   #15
thill
Originally Posted by TylerLieberman View Post
Seriously? Do you have a link to this review?
I'm not questioning you, but I'm genuinely interested to see how the rest of their test/review varies from other magazines. That's pretty cool though that it still is only one gear change for the wrx.
Sure thing, no problem:
http://www.caranddriver.com/reviews/...al-test-review
Here are the stats from their test:
C/D TEST RESULTS:
Zero to 60 mph: 4.8 sec
Zero to 100 mph: 13.1 sec
Zero to 130 mph: 25.3 sec
Rolling start, 5-60 mph: 6.3 sec
Top gear, 30-50 mph: 12.1 sec
Top gear, 50-70 mph: 7.9 sec
Standing ¼-mile: 13.6 sec @ 102 mph
Top speed (gov ltd, mfr's claim): 144 mph
Braking, 70-0 mph: 160 ft
Roadholding, 300-ft-dia skidpad: 0.95 g
The Following 2 Users Say Thank You to thill For This Useful Post:
sc0urge (05-27-2014), TylerLieberman (05-27-2014)
Old 05-27-2014, 05:20 PM   #16
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
The WRX is very conservatively tuned. it would trump the stock STI with a reflash I am sure.
Old 05-27-2014, 05:41 PM   #17
wbradley
Sarcastic SOB
wbradley's Avatar
I am taking delivery on a 2015 WRX hopefully this Fri. While Road and Track did 14 consecutive clutch dumps from redline to attain the fastest 0-60 times on Subaru's engineers insistence, that only proves the transmission is tough.
Wait until Cobb get's their AP tunes up and going. Then we will see what it can do.
I decided on the WRX over the STI not due to price, but the fuel economy, more modern and less peaky engine. This will be my daily driver and likely never see a track, so it made sense. When you get the revs up high, the STI is clearly more powerful, but for daily driving the WRX should feel every bit as fast for most people. And aside from a not quite as tight steering gear, it feels just as tight in the handling dept with the new artificial torque vectoring which does the job of the mechanical LSD's. The Brembos are nice, but again only really useful in a track environment. I dont need to adjust the torque distribution to drive to and from work either.
In another lifetime I would have loved to go to lapping days regularly, but in reality I just don't see that happening. Plus, the wing is pure rice IMHO.
All the write ups say they did a good job of tightening up the handling compared to the previous generation WRX.
The Following User Says Thank You to wbradley For This Useful Post:
SirBrass (05-27-2014)
Old 05-27-2014, 07:02 PM   #18
thill
It looks that way. One tuner was able to achieve 50hp and 35ft lbs of torque on a tune alone (meaning stage one with no other bolt ons).
Old 05-28-2014, 06:19 AM   #19
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
Love getting Nudered. Coed skinny dipping is the best!
I am pretty sure that the WRX & Foerster Run lower compression allowing them to run lower quality gas.
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
Hawaiian is offline   Reply With Quote
Old 05-28-2014, 08:04 AM   #20
sshole
From cars101.com:
all new engine for 2015 WRX
2.0L 4 cylinder, DOHC, Boxer engine
twin scroll turbo, intercooled
Turbo is water cooled, the bearing is oiled
aluminum block and head
multi-spray fuel injectors
direct ignition by Subaru
bore x stroke 3.39" x 3.39" (86mmx86mm)
compression 10.6:1
Redline 6600rpm,
Speedometer to 180mph
new on 2015- timing chain (no replacement required)
firing order 1-3-2-4
idle speed 700 +/-100
ignition timing BTDC 10* +/-10*
spark plugs- NGK ILKAR8H6
battery 12v, 48ah, CCA 390a
fuel, Premium 91 octane
oil- 5w-w0 synthetic, 5.4 US qts
emissions: Tier II Bin 5/Lev II Lev
The twins have a what... 12.5:1 ratio?
sshole is offline   Reply With Quote
The Following User Says Thank You to sshole For This Useful Post:
Hawaiian (05-28-2014)
Old 05-28-2014, 11:15 AM   #21
Hawaiian
That guy
Hawaiian's Avatar
Originally Posted by sshole View Post
From cars101.com:
12.1:1 i thought, but yes.
Ultramarine mt FR-S
P&L stage 1 turbo
Old 05-28-2014, 11:39 AM   #22
blackhawkdown
blackhawkdown's Avatar
Drives: 2012 WRX, 2003 RSX Type S
STi will always be faster and a better buy then the WRX. Funny how WRX owners always try to out class the STi, not happening. And this is coming from a WRX owner. EJ257 is not a bad engine, it has great power and tq even if it is from 2004. It has improve since its introduction 10 years ago. There is to much difference from the WRX and STi.
Originally Posted by fatoni View Post
saying they wanted to add weight to improve handling is like saying people wear condoms to improve sex.
blackhawkdown is offline   Reply With Quote
Old 05-28-2014, 12:13 PM   #23
tahdizzle
So elite I'm 1338
Drives: WRB Subaru BRZ
2015 WRX is a different car compared to the previous WRX in every way.
What exactly is different in the 2015 STI compared to the 2014?
So that generalization from perceptions past owners had doesn't really hold any weight.
Old 05-28-2014, 01:54 PM   #24
thill
Off the top of my head the differences between the 14 STI and 15 are:
- Much stiffer chassis
- More bracing
- Stiffer springs
- Larger sways
- Much tighter steering rack
- Torque vectoring
- Upgraded interior
- The changed the throttle mapping in the 15, and supposedly it is more responsive
I am sure there is more. I think the big change is going to be the handling and suspension. Subaru really focused on that with this car and it shows if you drive one. They feel very different from the previous car.
Old 05-28-2014, 01:56 PM   #25
tahdizzle
So elite I'm 1338
- More bracing
- Stiffer springs
- Larger sways
- Torque vectoring
- Upgraded interior
So the only reall difference between the WRX and the STI is the fa20 and the EJ25.... :p
Old 05-28-2014, 02:28 PM   #26
thill
No, I thought you were asking about the 14 STI and 15 STI.
15 Sti and 15 WRX (outside of engine) are pretty typical of previous years:
- Better gearbox in the STI that can most likely hold down more power
- Stiffer suspension
- 6 way adjustable center differential
- Brembo braks
- 18" wheels and wider/griper tires
- Tighter steering rack
- More standard amenties
etc, etc.
Old 05-28-2014, 05:21 PM   #27
serialk11r
Drives: '06 AM V8V Coupe
Actually the WRX has a higher compression ratio than the STI because it has a newer engine that doesn't suck. However 10.6 is still quite low, the typical 10.5-11 range port injected engine these days runs fine on 87 naturally aspirated, and this engine being direct injected should be able to run some decent amount of boost on 87 without knocking. You just don't get full power, obviously.
12.5
Old 05-28-2014, 10:33 PM   #28
Hawaiian
That guy
Hawaiian's Avatar
The comparison was the twins having to run 93 vs 87 like the wrx, not the wrx vs the sti.
Ultramarine mt FR-S
P&L stage 1 turbo
0-60, 2015, debate, sti, wrx
2014-2015 Winter Tire & Wheel Discussion Black Tire Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 153 07-02-2016 09:45 PM
Fantasy Football 2015 - Discussion, Help & Advice ihaskrayon Off-Topic Lounge [WARNING: NO POLITICS] 27 11-19-2015 01:31 PM
2015 86CUP rules discussion - What changes do you want and what can we improve? CSG Mike Tracking / Autocross / HPDE / Drifting 64 01-05-2015 02:10 AM
Subaru VIN Decoding: What all the numbers and letters mean eikond BRZ First-Gen (2012+) — General Topics 22 07-28-2013 01:40 AM
