#1317 |
Drives:
Nitrogen vs regular air in the tires for track day? Thanks!!
2014 Ultramarine Scion FR-S facebook.com/86motorsports |
#1318 |
Drives: Some rust bucket
| The Following 2 Users Say Thank You to ayau For This Useful Post: | becauseracecar1 (05-28-2014), kavanagh (05-27-2014) |
#1319 | |
i'm sorry, what?
Drives: Canada
do you have the ability to completely suction/cycle out the regular air and then refill with only nitrogen.. and then have support for a nitrogen refill? kinda pointless for the everyday joe
#1320 |
| The Following 2 Users Say Thank You to CSG David For This Useful Post: | becauseracecar1 (05-27-2014), SirBrass (05-27-2014) |
#1321 | |
Drives: '23 BRZ
Wheel rate is spring rate multiplied by the SQUARE of the motion ratio, so his wheel rates are: 550 lb/in * .95^2 = 496 lb/in front wheel rate 500 lb/in * .75^2 = 281 lb/in rear wheel rate I'd swap the springs front to rear to get: 500*.95^2 = 451 lb/in front wheel rate 550*.75^2 = 309 lb/in rear wheel rate And probably reconnect the rear sway, but then more likely to lift the inside rear... How on earth did this car end up with 57/43 weight distribution? |
#1322 |
Multiple posts got combined into one post there.. >>,
#1323 |
Drives: Used to Drive:Grand-Am GS #54 E36M3
#1324 | |
![]() See. I solved the obesity problem already. |
| The Following 2 Users Say Thank You to CSG David For This Useful Post: | becauseracecar1 (05-28-2014), kavanagh (05-27-2014) |
#1325 |
I brought a bike pump with me. Makes perfect sense to me.
Sent from my Nexus 5 using Tapatalk |
#1326 |
Off Topic
A [ame="http://www.amazon.com/250-PSI-12-volt-Air-Compressor/dp/B000KHH3U8"]12V air compressor[/ame] wouldn't work?
*note: not recommending that specific air compressor, merely providing a representative example. |
#1327 |
You do realize you have a Honda air compressor in the trunk of your CR...
#1328 |
Off Topic
This is like the family that only communicates via text. Don't you guys work together?
#1329 |
#1330 |
| Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 07:23 PM |
| Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 01:34 PM |
| Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 08:47 PM |
| Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) — General Topics | 11 | 05-31-2012 08:48 AM |
| Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) — General Topics | 20 | 01-10-2012 10:54 AM |
