Old 05-27-2014, 11:48 AM   #2381
WhiteFRS69
WhiteFRS69's Avatar
Drives: 2014 Scion FRS
owned the car for about 6 months so far
2014 model
i HATE the radio reception. my previous cars never had a problem picking up radio stations around town, even with shorty antenna's. this car i cant get a decent reception anywhere around town
even switched HU's and still nothing, thankfully it got me out of the habit of listening to the radio
Old 05-27-2014, 01:16 PM   #2382
Lavalover
Drives: 2014 FR-S Monogram Hot Lava
I wish that there was a display of the individual tire pressures like in Porsche. Since we have the stinking TPMs anyway.
Lavalover is offline   Reply With Quote
Old 05-27-2014, 02:00 PM   #2383
HunterGreene
Hail Magnet
HunterGreene's Avatar
If you are that anal about tire pressure....
It has priests in it?
Old 05-27-2014, 02:13 PM   #2384
Davey
Drives: BRZ Limited
I would rather have a lid on the center console than cup holders... So far that's about it.
Davey is offline   Reply With Quote
Old 05-27-2014, 02:55 PM   #2385
acg2010
Drives: 4 wheels/engine/seats
Put in the JDM armrest. It is a lid and armrest.
acg2010 is offline   Reply With Quote
Old 05-27-2014, 02:59 PM   #2386
Davey
Drives: BRZ Limited
Thanks! I'll check that out!
Old 05-28-2014, 05:06 PM   #2387
Lavalover
Anal is relative as I'm sure you know.
Old 05-28-2014, 05:09 PM   #2388
HunterGreene
Hail Magnet
I lul'd
Old 05-28-2014, 05:30 PM   #2389
dnieves
Drives: FR-S 10 Series
Originally Posted by Chazbo View Post
The cup holders. I have never had to reach behind me to grab my drink in the drink holder console.
The paint. Jesus. I would have paid an extra grand for paint that doesn't scratch if you breath on it.
Water based paint, this applies to every manufacturer.
dnieves is offline   Reply With Quote
Old 05-28-2014, 05:39 PM   #2390
driftartist
Kurenai Samurai
driftartist's Avatar
Drives: Red and manual
i think i just hate the ignorant frs brz owners that are "know it alls"
driftartist is offline   Reply With Quote
The Following User Says Thank You to driftartist For This Useful Post:
xoxomichaela (05-30-2014)
Old 05-28-2014, 08:11 PM   #2391
notout86
Drives: GTS 86 auto
Originally Posted by gramicci101 View Post
Rear shifter bushing + Motul 300 + MTEC springs. Clean precise shifts.
more information please
GTS86 Auto (Australia)
Old 05-28-2014, 08:15 PM   #2392
notout86
Drives: GTS 86 auto
Cannot prove but I think our paint is toughening/hardening with age
Old 05-28-2014, 08:19 PM   #2393
notout86
Drives: GTS 86 auto
I stumbled across an aftermarket thing you can get to do this. Sorry , no link
The Following User Says Thank You to notout86 For This Useful Post:
Lavalover (05-28-2014)
Old 05-28-2014, 09:33 PM   #2394
gramicci101
Off Topic
Sure.
The rear shifter bushing locates the rear bar the shifter slides on and rotates around. The OEM shifter bushing, like all OEM bushings, is soft and floppy and ineffective. Fortunately, there are a number of solutions available to us. I bought [ame=http://www.amazon.com/Energy-Suspension-8-1105R-Shifter-Bushing/dp/B00CYDGFW8/]this one[/ame] because it was cheap and I had an Amazon gift card. There are other brands available as well; [ame]http://ft86speedfactory.com/drivetrain-41/shifter-bushings-99/[/ame] Here's a handy guide by @F1point4 on how to install them; [ame]http://www.ft86club.com/forums/showthread.php?t=19767[/ame] His guides are great, and most of them are doable from jack stands. The new shifter bushing makes a huge difference in the feel of the shifter. It isn't vague anymore; instead it's precise, with solid engagement. A+++ mod, especially for the price. And an easy install.
However, it could be better. This is where MTEC Shift Springs come into play. Your shift springs are what pushes the shifter towards the center of the gates, basically the return-to-zero mechanism. The MTEC springs are stronger, so there's more force pushing the shifter to the center. This will obviously make things like shifts from 2-3 or downshifts from 5-4 better, but it goes past that. Because there's additional pressure to move the shifter to the left or right, it becomes very clear what gear you're in. I've found that every upshift or downshift has become much more defined as a result. Again, super A++ mod. And it's cheap. The install is a bit more technical than the above bushing, but that's because leftover locktite clogs the threads. It was a 20 minute job for me. @FT-86 SpeedFactory has a video tutorial on the install on their product page. This thread covers some of the issues and proposed solutions to the locktite and the tools needed. I chimed in on page two, with a solution that worked very very well for me.
Lastly, the transmission fluid. Motul 300 is rated for both GL4 and GL5, so it's suitable for both the transmission and rear differential. Do both. The magnetic drain plug for my transmission had a light coating of metallic gunk on it; the drain plug for my diff was COVERED. Get that shit out of there. Motul 300 is much higher quality than the OEM fluid. F1point4 wrote another great tutorial, which I followed to the letter. I ordered my fluid from @AZP Installs, and I'll order from them again in the future. Great to work with. I don't know how much difference this made on its own, because I did all three items at the same time. It does make an improvement though. This was the only item here that wasn't cheap, and even then it was <$100.
Super lastly, I also installed a Whiteline Positive Shift Kit transmission mount insert. This doesn't directly affect shifting, but it does limit movement of the transmission. That lets the shifter do what it's supposed to be doing instead of flexing the transmission mount around. Be warned, this does transmit noise into the cabin. Not much, and mostly low gear low rpm, but some. Harder bushings always will, that's just part of the game. F1point4 wrote another outstanding tutorial. I combined that with this thread and had it replaced in about 5-10 minutes.
Since you'll be under the car already, you might as well do them all at once. My shifter is now incredibly precise and defined, at the cost of a little gear noise from the transmission. I would do it all again in a heartbeat.
edit for some reason, two of my links under the rear shifter bushing won't link. Stupid Internet.
The Following 2 Users Say Thank You to gramicci101 For This Useful Post:
jeffsquared (05-29-2014), xmadror (05-29-2014)
ha ha!, hate, playerhatersball, potatopants
Errr... Hate to ask... Crash Testing?? slusoccer00 Scion FR-S / Toyota 86 GT86 General Forum 55 07-12-2015 03:03 PM
Hate those ugly visor warnings? avusblue Cosmetic Modification (Interior/Exterior/Lighting) 28 12-17-2014 03:16 PM
I hate you Jaguar [I love you!] Ryephile Other Vehicles & General Automotive Discussions 2 04-04-2012 03:56 PM
Why hate Justin Bieber? LSxJunkie Off-Topic Lounge [WARNING: NO POLITICS] 29 03-27-2012 10:09 AM
dont hate me for asking.. weight? carbonBLUE Scion FR-S / Toyota 86 GT86 General Forum 27 03-08-2012 02:09 PM
