Old 05-25-2014, 01:23 AM   #729
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
Originally Posted by slicktop View Post
Well, yeah, but most of the wheels that I want are either $3k+ or they won't fit those rears. I just gotta keep my eyes open.
Are you looking at anything other than 18x9.5?
Old 05-25-2014, 02:26 PM   #730
Pablitomarrero
Pablitomarrero's Avatar
Drives: FR-S 10 series
I have a question for all of you meaty tire buffs. I just installed 18X8.5 +42 and 18x9.5 +43 rims on my car with 235/40/18 and 265/35/18 (front/rear respectively). My only suspension mod right now is the TRD springs which lower the car about .8 inches. Everything is perfect and I wouldn't have noticed rubbing (no sounds heard ever) except this morning while washing the wheels i noticed that the rear tires had a slight marking on them (pic provided) suggesting they were slightly rubbing on the fender wall (both sides). No other evidence of rubbing (No dents, no black marks no paint cracking. Don't plan to track this for now, so I only want the most practical solution that works. Any suggestions? I wanted to go with the whitetline camber adjustable bushings for the rear but don't know if that will be enough...dont want to spend 150$ on this to later find out I need control arms as well... I seems I only need a little more - camber?? SPC control arms? I know nothing. Thanks! @Sportsguy83 ?
Pablitomarrero is offline   Reply With Quote
Old 05-25-2014, 06:36 PM   #731
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by Pablitomarrero View Post
Attachment 79814
I needed a slight fender roll to fit 265 tires on the back. A slight fender roll will do the trick. My wheels are 18X9 +40. To adjust camber, SPC LCA is the way to go...
Old 05-25-2014, 08:13 PM   #732
Pablitomarrero
I hope fender rolling solves this
Old 05-25-2014, 08:26 PM   #733
Sportsguy83
Drives: Limited BRZ
It will. The mark shows very little is needed.
Sent from my SM-N900A using Tapatalk
Old 05-26-2014, 12:09 AM   #734
grostoine
Drives: Subaru BRZ
My contribution.
Gramlight 57DR 17x9 +38
Hankook Ventus RS3 245/40/17
grostoine is offline   Reply With Quote
The Following 16 Users Say Thank You to grostoine For This Useful Post:
DAEMANO (05-26-2014), eyedeez (05-27-2014), hmong337 (05-26-2014), humanshield (05-26-2014), jflogerzi (06-08-2014), Kace (05-30-2014), Nsot (05-26-2014), oldlostcory (05-28-2014), Pablitomarrero (05-26-2014), Powersfrs (05-26-2014), raul (06-08-2014), rookie (02-25-2016), ryann.mendoza (03-08-2019), Slipstream (05-30-2014), SuperTom (10-27-2018), UltraMarine86 (05-26-2014)
Old 05-26-2014, 10:17 AM   #735
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
The particular wheels I want come in 9.5 and 8.5 +45 (will be +34 with adapter).
Once my swap is done, i'll be around 500whp on 93 until the rear end is built. I'd like to get as much tire under there as I can.
slicktop is offline   Reply With Quote
Old 05-26-2014, 12:02 PM   #736
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
@grostoine
Looks perfect!
hmong337 is offline   Reply With Quote
Old 05-26-2014, 12:38 PM   #737
Powersfrs
Drives: Frs
Originally Posted by grostoine View Post
My contribution.
WOW!!
Powersfrs is offline   Reply With Quote
The Following User Says Thank You to Powersfrs For This Useful Post:
Old 05-26-2014, 12:45 PM   #738
humanshield
Drives: bucket
Originally Posted by hmong337 View Post
@grostoine
Looks perfect!
AGREED. are those STI brakes I see too? you know we want more now. so give it up.
humanshield is offline   Reply With Quote
Old 05-26-2014, 03:10 PM   #739
UltraMarine86
UltraMarine86's Avatar
Drives: Ultramarine '13 FR-S
Dang how did you even see those lol
Sent from my SCH-I605 using Tapatalk
UltraMarine86 is offline   Reply With Quote
Old 05-26-2014, 03:59 PM   #740
Nsot
Nsot's Avatar
Drives: Whiteout FR-S
If you click the picture it will take you to his Photobucket account with more photos. Looks like he only has a front brake set, looks amazing though.
Nsot is offline   Reply With Quote
Old 05-26-2014, 04:17 PM   #741
grostoine
Drives: Subaru BRZ
I am currently looking to find some rear brembo too. 2008+ model are very hard to find. They are all gone even before I could say i want them!
I will probably go with the 2004-07 model. I know I need the bracket adapter. I like them more over the 08+ model too.
Thanks for the good comment !!
The Following User Says Thank You to grostoine For This Useful Post:
Nsot (05-26-2014)
Old 05-26-2014, 06:01 PM   #742
Pablitomarrero
Went to get the fender roll and the guy found out that the tires werent rubbing at all!!! It appears that the culprit is a plastic tab from the bumper which is already "sanded out" by the tires. The line on the tires is basically melted plastic. The piece that was rubbing was extremley small. Gone now. So now perfect fitment without use of any camber or toe settings. Only dropped on TRD springs! 265 tires in the back will fit awesome!! Who would have known (wheel offset 43 btw)
The Following User Says Thank You to Pablitomarrero For This Useful Post:
Sportsguy83 (05-26-2014)
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 05:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 06:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 12:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 03:05 PM
