#29 | ||||
Drives: 2015 Series.Blue
Most modern engines are zero balanced, meaning that each part is individually balanced and not balanced as a unit. Older stuff sometimes have external counterweights, and any built motor is usually zero balanced then balanced as an assembly for good measure. Quote:
Bingo. Saving a small amount on each part is a huge difference in mass production. I also love people putting one piece driveshafts on cars like this, they really need to learn what a driveshaft critical speed is and realize why the OEM's run multi piece shafts. If you want to lose rotational mass, use a light weight flywheel and clutch assembly. Then again, the heavy flywheel is nice for drivability, and it's a nice big heat sink as anyone that's ever welded a clutch disk to the steel insert in an aluminum flywheel will know... Quote:
Who has more money into these cars, Subaru/Toyota or Perrin? In essence, it's "above my pay grade." Quote:
Keep in mind who's trying to sell you stuff... Also, good luck going after said person that sold you stuff if it does cause damage. This has been the norm in the car scene forever (and most recently FA20club showed how easy this is to get away with). It's a sad reality, but I'll take the opinions of engineers that made the car. In essence the part res ipsa loquitur. Quote:
First part is still up for question. Much like getting any low level tech's answer through customer service, it's not dependable. Second part, come on, they're making and selling the parts, of course they're going to talk it up. Watch any infomercial and see how marketing works in action. It's not really dishonest, you just have to know that they're really there to make money and sell you something. |
| The Following User Says Thank You to Poodles For This Useful Post: | stugray (05-26-2014) |
#30 | |||||
Perrin: Quote:
The more information I'm reading, the more I get that subaru does not use harmonic dampener or balancer, it's just a crank pulley.
| The Following 2 Users Say Thank You to suaveflooder For This Useful Post: | Apoc (05-26-2014), DoomsdayJesus (03-29-2015) |
#31 |
Drives: small
A drilled see thru hole is usually for alignment. Dimples are for balancing.
#32 |
Drives: Ft86
Just read this whole thread and i figured it out ....
The answer is yes. Have a nice day
#33 |
you must be FAER.
#34 |
Drives: Ft86
#35 | |
Drives: '11 Cayman , '14 Camry, '11 Tacoma
#36 | |||
That's a bunch of crap... They're a small shop making parts and don't even understand the concepts behind the part. Hell, the part isn't SFI rated so this is all pointless anyway. Of course if you want info from someone who does make SFI rated pulleys and knows what they're there for, look no further than ATI: http://www.atiracing.com/products/da...mper_dinan.htm I'd say Dinan is far FAR larger than these three people you've linked are together. Also of note, the higher your output, the larger the damper has to be to handle it. This is why some of the Supra guys run custom ATI dampers (and guess what motors haven't blown...) Complete BS as aluminum can be cut extremely fast and on a cylindrical piece like this (that is ALSO machined steel) it would be cheaper for the OEM's to use them. Not a single one of them does. A single step process vs a multiple part process will always be cheaper, so they honestly have no idea what they're talking about. Hell, look at the cost of one of their pulleys vs a real damper from ATI... Still hearsay and I'm still not convinced it's real. I'm inclined to believe it's fake simply because anything like that would have passed their legal department on the way and had a disclaimer about how it could potentially hinder warranty claims on the engine/drivetrain. Quote:
Oh this is comedy gold. Unorthodox's pulleys have been well known in the car scene for causing failures (oil pumps, front main bearings, etc), but I'll at least humor what you highlighted. - First part is false as if the pulleys DID move, they hammer the hell out of the keyway in the crank. They're a press fit, that's why they require pullers to remove. - Wrong again, it's flexing of the crankshaft that would damage bearings (and has been shown over and over with their products). Forged cranks have no effect on this other than they will flex more before breaking. - Part about bolt on pulleys is false as well as there is still a part that is a press fit on the crank after they are removed. Miata is like this, and guess who have oil pump failures from Unorthodox's pulleys? - Wrong and wrong...and wrong. It's there to damp the big huge pulsing thing under the hood called an internal combustion engine. The accessories don't have pulses at all, and even if they did, they're attached solidly to the motor and attached to the crank with a rubber belt. Dual mass flywheels are used for more than that (yes it does help with gear clash in the transmission), and freewheeling alternators are for economy. Quote:
Hundreds of thousands? You're wildly overestimating how many of these things are in the wild. It's ok, you can be happy about your car going hundreds or even thousands of miles, I'd prefer mine to go hundreds of thousands of miles. People have had failures is less time than the average person changes their oil... So the pulley that Subaru doesn't look like all the other cars on the road that run harmonic dampers?
| The Following User Says Thank You to Poodles For This Useful Post: | stugray (05-27-2014) |
#37 | |||||||||||||||||||||
#38 | |
Drives: 2013 GBS BRZ Limited
"what is the definition of a harmonic balancer" MY stock BRZ has a harmonic balancer from the factory. It looks like this: ![]() Perhaps yours does not. |
#39 | |
Drives: Raven FR-S 6M
"About SFI Foundation The primary users of SFI standards, or specifications (specs), are equipment manufacturers whose products are tested and self-certified to the appropriate procedures. SFI Specs are included as part of the rules of race sanctioning organizations. Ultimately, the consumer benefits from the SFI program because it establishes recognized levels of performance or quality for a given product which results in a safer racing environment"
“The World is Flat”
[||•]=(86)=[•||] Last edited by Apoc; 05-27-2014 at 01:59 AM. |
| The Following User Says Thank You to Apoc For This Useful Post: | suaveflooder (05-27-2014) |
#40 | |||
One thought, rubber makes it harmonic balancer. Harmonic balancer balances the engine. Cool Other thought, rubber decreases NVH from the crank shaft. Cool. Yet another thought, rubber helps balance the pulley itself (due to weight, this is important otherwise it could actually create a vibration). Double cool. Quotes one and two cover this above. The pulley is blanced from the factory, so it doesn't sound like a harmonic balancer/damper (whatever poodle wants to call it). Because the crank is short, forged and has opposing pistons, it shouldn't need a harmonic balancer/damper like a V-engine. I can tell you this, looking through subaru forums looking for this information has given me some interesting insite to this "damper", or "pulley" whatever you want to call it. When the stock rubber wears out, it JACKS up your crank! Here's one from a mercedes owner on one of the threads I came across, but this was common on subaru engines as well when the stock rubber failed. Quote:
| The Following User Says Thank You to suaveflooder For This Useful Post: | Apoc (05-27-2014) |
#41 | ||
Because these people put their money were their mouth is. Just about anyone with a good CNC machine can make a crank pulley... Quote:
You're missing the point. It's NOT a balancer, it's there to damp the torsional harmonics on the crankshaft. You're confusing the terms and their applications. Also, a large V8 is going to have a more substantial damper because of it's inherent vibration issues. Just because a flat-4 has a smaller one doesn't mean it's still not doing it's job. Coming from inline-6 motors (which are considered "perfect" in balance and the only engines that equal it are V12's and flat-4's), the damper is smaller, but it is still a damper and still quite necessary as tolerances are never perfect in a motor. |
#42 | |
Add lightness!
Drives: 17' WRX
| Ishii Motors, VTR, or ? | Yamaha_R6 | Northwest | 24 | 01-29-2014 06:13 PM |
| Clint E. @ Heuberger Motors | Scoobybrz | User/Vendor/Sponsor Reviews, Feedback, Comments | 1 | 09-09-2013 12:42 PM |
| WTB Core/Full Motors | Dustin@Dynosty | Engine, Exhaust, Bolt-Ons | 2 | 07-07-2013 01:36 AM |
| New Car by ELIO MOTORS coming soon. | Motowalt | Other Vehicles & General Automotive Discussions | 30 | 01-26-2013 12:07 AM |
| Lotus to help make motors? | e10rice | Engine, Exhaust, Transmission | 6 | 03-16-2011 06:25 AM |
