Old 05-23-2014, 02:44 PM   #127
Pablitomarrero
Pablitomarrero's Avatar
Drives: FR-S 10 series
Originally Posted by UltraMarine86 View Post
So your doing 255/35 front and 265/35 rear?
Sent from my SCH-I605 using Tapatalk
No 235 front 265 rear
Pablitomarrero is offline   Reply With Quote
Old 05-23-2014, 03:10 PM   #128
Pablitomarrero
Size:  51.8 KBName:  ImageUploadedByTapatalk1400872190.380348.jpg
265 like a charm!! Very flush... Im looking at it still nice fit... It SHOULDNT rub... Ill see soon
The Following User Says Thank You to Pablitomarrero For This Useful Post:
Bimble Bamble (10-30-2016)
Old 05-23-2014, 03:22 PM   #129
Pablitomarrero
2 finger gap (one on top of the other) from spring up front with 235s, not ganna change that
Old 05-24-2014, 06:17 AM   #130
Pablitomarrero
Confirmed no rubbing in the rears: lowered w trd springs and on 265s
Old 05-24-2014, 10:40 AM   #131
UltraMarine86
UltraMarine86's Avatar
Drives: Ultramarine '13 FR-S
Have any shots of the whole car?
UltraMarine86 is offline   Reply With Quote
Old 05-25-2014, 11:02 AM   #132
Pablitomarrero
Wheel Directory: Enkei RS05RR 18x8.5 +42
I was wrong... I seem to be slightly rubbing on the outside of the wheels as confirmed by marks on the wheels. Cant be too much as i neither hear or feel it and must be when i go over dips at speed. Any suggestions? Prob a bit of camber?
Edit: only on the rears
Old 05-25-2014, 05:24 PM   #133
UltraMarine86
Are you on coilovers? Either add a little height or a bit of camber.
Old 05-25-2014, 05:26 PM   #134
Pablitomarrero
Cant im on springs... I was thinking going with the whitleine adjustable bushings for the rear. Think .7 deg of camber can fix this?
Old 05-25-2014, 05:38 PM   #135
UltraMarine86
I wouldn't even know as I'm on coilovers which makes it easier. The meaty thread should be able to help
Old 05-25-2014, 05:40 PM   #136
Pablitomarrero
I posted there but still no replies
Old 05-25-2014, 06:21 PM   #137
Pete156
I like to eat!
Originally Posted by Pablitomarrero View Post
I was wrong... I seem to be slightly rubbing on the outside of the tires as confirmed by marks on the tires. Cant be too much as i neither hear or feel it and must be when i go over dips at speed. Any suggestions? Prob a bit of camber?
Edit: for my sake.
I think you are correct, the tires are touching the rear fender wells when suspension gets loaded. I would be concerned a large bump could potentially cause fender damage. You could chalk/powder your fender to see where it rubs. It should be evident.
Solutions: Roll fenders, more camber, stiff coilovers, 255s, a combination of these, aftermarket fenders, drive only on smooth roads. That's all I can think of.
Pete156 is offline   Reply With Quote
The Following User Says Thank You to Pete156 For This Useful Post:
Pablitomarrero (05-25-2014)
Old 05-25-2014, 08:06 PM   #138
Pablitomarrero
Thanks for the edit lol. Yes 255 did not rub at all but left so much exposed rim its was bothering me (im starting to think brand of tire has alot to do with this as ive seen pics in this forum of 255's completley covering a 9.5 incher without as much stretch... Im gonna try adding a bit of neg camber to see what happens, roll fenders next if i have to
Old 05-25-2014, 08:22 PM   #139
Pete156
I like to eat!
You are correct again. My 255 Michelin PSS fill my 9.5s nicely
Old 05-25-2014, 10:27 PM   #140
UltraMarine86
Continental Extreme DW in 255 are a very little stretched. If you look at jive turkeys set up his tires seem perfect.
Wheel Directory: Enkei Raijin 18x8.5 +45 / 18x9.5 +45 GuerillaRacing Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 221 08-01-2019 10:30 AM
Gauging interest Enkei RS05RR 18x9+40/18x8.5+50/18x8.5+42 THMotorsports.com Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 09-19-2013 04:33 PM
Wheel Directory: BBS LM 18x8.0 +50 stoneman155 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 20 07-08-2013 07:55 PM
Wheel Directory: BBS RE 18x8.0 +50 DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 06-25-2013 08:49 PM
