Old 04-05-2012, 05:42 PM   #43
serialk11r
Drives: '06 AM V8V Coupe
Originally Posted by tranzformer View Post
Could that be the reason they say to use 93 gas?
Hmmm speaking of gas, seeing the very rich looking AFR, I wonder what E85 conversion can do...and what would happen with E85+supercharger :O
EDIT: actually I just looked back at the AFR, and I think it tells some of the story. AFR is going up in the torque dip range, which means it's a volumetric efficiency issue I think, so the intake tuning theory sounds plausible (Subaru boxer engines all have a manifold like that, makes sense that they'd all see the same drop like that). Below 3000rpm it runs quite rich, that looks like the extra fuel they're using to combat the internal EGR effect of advancing the intake cams. The high end being so rich is a mystery though...
Old 04-05-2012, 05:55 PM   #44
Jeff Lange
Jeff Lange's Avatar
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
Originally Posted by serialk11r View Post
Having all the wheels spin is more relevant than a single axle. Ideally you'd know transmission efficiency, effective moment of inertia of the drivetrain, rolling resistance, and power at the crank.
This is true, but it does take away from the numbers, and though you should never compare numbers between different dynos, people do it all the time anyway, and comparing numbers between an AWD and 2WD dyno is even worse, haha.
Jeff
2011 Lexus IS350 F-Sport 6MT with LSD
1986 Toyota Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
Old 04-05-2012, 05:57 PM   #45
dsgerbc
Drives: BRZ(sold), STI
So, no 93 gas in Oregon? Why would you dyno a car not on gas required for top performance?
Old 04-05-2012, 06:09 PM   #46
ubersoph
Because it's a realistic street spec dyno?
ubersoph is offline   Reply With Quote
Old 04-05-2012, 06:09 PM   #47
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Below 3000 it goes lean. Rich is lower, lean is higher on that graph.
Old 04-05-2012, 06:10 PM   #48
dsgerbc
I take it you're gonna be filling it with 92?
Old 04-05-2012, 06:17 PM   #49
serialk11r
Um, I know that, and below 3000 the AFR is lower than it is between 3500 and 4500 or wherever the "torque dip" is at.
Old 04-05-2012, 06:42 PM   #50
Crashoverride
here, there, any where
Drives: FR-S SOON!!!
with the ECU being open, its just a matter of time before a free maps end up here on the forums, cracking an ECU is no longer required so the cost is not justified, I can see ECU maps floating around for free or less then 50$ with AFR, and a good map, super chagers and turbos should be a snap.
Crashoverride is offline   Reply With Quote
Old 04-05-2012, 06:47 PM   #51
Jeff Lange
Jeff Lange's Avatar
EDIT: I am wrong. Interesting that they would want 93, I've never seen anything from Toyota require 93.
Jeff
Old 04-05-2012, 06:51 PM   #52
serialk11r
The manual actually says 93 is recommended, 91 is fine but may have slightly decreased performance.
Old 04-05-2012, 06:52 PM   #53
Jeff Lange
Jeff Lange's Avatar
Yes I see that now.
Jeff
Old 04-05-2012, 06:58 PM   #54
Turbowned
Turbowned's Avatar
I'm shocked nobody's mentioned it yet but:
WHAT KIND OF DYNO ARE THEY USING?
That makes a bit of difference when you compare it to other people's dynos. Also the altitude/air density would be useful to know, too.
Old 04-05-2012, 07:06 PM   #55
Jeff Lange
Jeff Lange's Avatar
Agreed, that information is good to know, along with knowing if they are corrected or uncorrected values.
Jeff
Old 04-05-2012, 07:20 PM   #56
Guff
Now w/ over 400 womprats!
Guff's Avatar
Drives: BRZ LZR
Originally Posted by blu_ View Post
Wrong cobb :P
Lol, I just realized this....
Never mind, I'm glad I went to the auto show...
- The Ancient BRZ Sacrament
by Zaku
DFW: BRZ at Cobb Plano Re-Grand Opening TheRipler Southwest 2 04-09-2012 04:14 PM
BRZ ordered - wanna pull it apart? hyteck9 BRZ First-Gen (2012+) — General Topics 26 03-27-2012 03:31 PM
Any publication strap this car on a dyno yet? mspeed6 Engine, Exhaust, Transmission 67 02-02-2012 04:48 PM
Will FT-86 pull 1g on skidpad stock? tranzformer Scion FR-S / Toyota 86 GT86 General Forum 31 04-15-2011 12:56 AM
2007 STi... should I pull the trigger? RRnold Other Vehicles & General Automotive Discussions 25 02-23-2010 09:37 PM
