Old 05-25-2014, 01:35 PM   #1695
mike the snake
They are the shroud and Spal fans offered by Full Blown.
The shroud and fans, with the radiator moved forward (something everyone should do IMO) my temps are rock solid.
The Following User Says Thank You to mike the snake For This Useful Post:
Boba_kz (05-25-2014)
Old 05-26-2014, 07:36 PM   #1696
69Marshall69
69Marshall69's Avatar
Drives: 2013 Subaru BRZ-S
Hey guys, just wanted to ask and see what others were using for springs in their Tial 50mm BOV. mine wasn't releasing and I checked and found a brown spring with a 12 psi release rating. What are most of you using?
Dan
69Marshall69 is offline   Reply With Quote
Old 05-27-2014, 10:44 AM   #1697
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Drives: Faster than you
Originally Posted by Boba_kz View Post
Kit radiator fans doesn't work. Anybody else who experienced the same problem?
Tested it, seems motors not functional. Fuses are ok. It was second day after kit installed.
Second this.
The slim fans didn't hold up to Miami heat after first day. Shroud+Spal+Radiator haven't had a problem since, about 4 months now.
Ironsquid is offline   Reply With Quote
The Following User Says Thank You to Ironsquid For This Useful Post:
Boba_kz (05-27-2014)
Old 05-27-2014, 11:16 AM   #1698
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by eazyace View Post
Quick question guys as i am in curious in buying this kit. How often do you clean the intake and is difficult to get to it once bumper is installed?
Thanks
It uses a standard K&N filter which doesn't need to be cleaned for 50,000 miles unless you are a rallycross driver and driving off road often. You will have to pull the bumper to remove the filter and clean it.
Old 05-27-2014, 11:17 AM   #1699
King Tut
NASA SpecE30 Racer
King Tut's Avatar
I ended up using an 11 psi spring with a couple washers. What do you mean yours wasn't releasing? How much vacuum are you pulling at idle?
Old 05-27-2014, 11:20 AM   #1700
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Real men run open turbo inlet, no filter
Old 05-27-2014, 11:24 AM   #1701
eazyace
Drives: wish
Haha sure they do. Thanks for the response.
I wanna see some of these cars live, anyone of you go to any meets or something like that ?
eazyace is offline   Reply With Quote
Old 05-27-2014, 11:25 AM   #1702
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Real men run GTX35s too.
Reaper (05-27-2014)
Old 05-27-2014, 11:34 AM   #1703
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
Real men run compound turbos with naws
I'm thinking about running open inlet though, but my Varis hood vents concern me that I might suck up a small animal like a moose or something.
blackfireball5 (05-27-2014)
Old 05-27-2014, 11:36 AM   #1704
Ironsquid
King of Kiwi Palace
Ironsquid's Avatar
If you're ever in Orlando, we meet every Friday night @ Logan's on University around 7:30
Old 05-27-2014, 11:48 AM   #1705
Dipstik-sportech
Dipstik-sportech's Avatar
Yay I'm part of the club!!
I have a 10psi spring in my bov but I want to try a 9 cause I'm still getting some compressor surge
The Frozen North
Old 05-27-2014, 12:14 PM   #1706
Boba_kz
Second this.
Thank you
Ordered
Boba_kz is offline   Reply With Quote
Old 05-27-2014, 01:39 PM   #1707
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Here is another one with our base kit on e85.
FullBlown is offline   Reply With Quote
Old 05-27-2014, 02:27 PM   #1708
Brzzee
Brzzee's Avatar
Drives: 2015 Subaru BRZ WRBP Limited 6MT.
Some pics with text on your radiator mount modification, please.
- When men make plans the gods laugh.
Brzzee is offline   Reply With Quote
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 09:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 09:15 PM
