Old 05-23-2014, 11:15 PM   #85
sirsol66
Drives: 2013 FRS- Hot Lava
The one thing I missed the most from my past cars (Evo VIII, Evo X, DSM's) was the clutch weight. So, I did this today too, removed the e clip with two screw drivers, pushed out the pin with a flat head, and then pushed out the spring.
I haven't driven it yet but just from actuating the clutch a few times, I'm not impressed. The first 1/2" or so feels very light, with essentially no feedback. I'll drive on it a for a few days to see how I like it but I already plan to re-install it. What I found is that if you put the spring in a vice and zip tie it, you can push it back into place and re-insert the pin. Then just cut the zip ties and you should be back to stock.
sirsol66 is offline   Reply With Quote
Old 05-23-2014, 11:25 PM   #86
zdr93523
zdr93523's Avatar
Drives: 2013 BRZ Limited
Make sure that you adjust the pedal down to just above the brake pedal height. It will get rid of that free travel. My clutch now feels amazing with this mod.
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523
Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car
www.makesmodels.com
www.camautomag.com
zdr93523 is offline   Reply With Quote
Old 05-24-2014, 12:28 AM   #87
DJCarbine
Thupercharged
DJCarbine's Avatar
Just did this... feels good man.
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
The Following User Says Thank You to DJCarbine For This Useful Post:
zdr93523 (05-24-2014)
Old 05-24-2014, 03:14 AM   #88
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Recently done this and noticed the clutch doesn't engage until the pedal is let out almost all the way regardless of how high/low I adjust the engagement point. It basically just shortens the overall throw of the pedal.
Anyone else experience this?
Old 05-24-2014, 08:01 AM   #89
sirsol66
Will do that today and report back.
The Following User Says Thank You to sirsol66 For This Useful Post:
zdr93523 (05-25-2014)
Old 05-24-2014, 06:02 PM   #90
P@ul
Apostle
P@ul's Avatar
Drives: JesusMobile
I used a mallet and a socket extension to knock the assembly loose after removing the pin with a screw driver.
I think it's great! It gets rid of the non-linearity that I disliked before. The force required to push the pedal in is greater, but the length of travel feels shorter. The clutch point however still feels as vague as before.
I have not adjusted anything else, as I'm pretty happy so far. The old feeling of spring assist reminded me of the MazdaSpeed 6, the worst clutch I've ever used.
P@ul is offline   Reply With Quote
Old 05-25-2014, 09:06 AM   #91
xxBrun0xx
xxBrun0xx's Avatar
Drives: 2014 WRB BRZ Limited
Sounds like you adjusted the clutch pedal height too low. This mod does not affect overall pedal throw in any way. The only difference between having the spring and not having the spring is being able to feel your clutch or not being able to feel your clutch.
Good info here on going back to stock. I also had that initial loose feeling up top but it seemed to stiffen up over time and feels identical to stock now. Could just be that my foot got used to it. Either way, that dead zone is a good thing, imo: you know when your clutch is disengaged.
xxBrun0xx is offline   Reply With Quote
Old 05-25-2014, 09:56 AM   #92
Slysdexia
Slysdexia's Avatar
Drives: '14 Monogram 6MT FR-S - Hot Lava
That's the slack in the system before forcing the throwout bearing to engage the clutch fingers. If you want to get rid of it, you can adjust the clutch pedal downward a bit.
Sent from my PO-T4T0 with Eyes.
Slysdexia is offline   Reply With Quote
Old 05-25-2014, 11:11 AM   #93
xxBrun0xx
xxBrun0xx's Avatar
I was under the impression that this slack was necessary in order to ensure the clutch was completely disengaged while your foot was not on the pedal. Is this not the case? Wouldn't mind reducing some of the slack, but don't want to prematurely wear my clutch.
Old 05-25-2014, 11:44 AM   #94
Slysdexia
Slysdexia's Avatar
You can reduce the slack a bit and be fine, but too little slack can lead to throwout bearing wear, similar to sitting stopped with the clutch pedal held down.
I don't have an issue with the slack, but I'm 6'6, so I pass through the dead spot in an instant.
Old 05-25-2014, 07:09 PM   #95
Andrew025
Andrew025's Avatar
Thing is though, the pedal travel is still pretty long before it engages.
That's what I meant when I said it doesn't matter how high or low I set it.
Old 06-05-2014, 04:19 AM   #96
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
Was reminded of this in another thread. Figure this is worth bumping in case anyone hasn't seen it yet. Just read through this thread, the comments speak for themselves.
Interesting you mention Evos too. I liked the pedal feel in an Evo IX but didn't like it too much in an Evo X. How is the clutch now?
I feel just like @xxBrun0xx does. I installed the quickshifter today, and have done the other common mods - helper spring, clutch height, MTEC springs, Pentosin fluid. Driving in a straight line, shifting at 3k actually feels fun now, and is easy to do smoothly.
unsurety is offline   Reply With Quote
Old 06-05-2014, 04:23 AM   #97
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
That's the thing, I can't even recall where the engagement point was when everything was stock. I think it was right at the top of the pedal. It was just too vague feeling... I did the pedal height mod first, so I couldn't tell you now.
and oops... yes, I know how to multi-quote. Just lazy.
Old 06-05-2014, 04:53 AM   #98
Andrew025
Andrew025's Avatar
At this point, I have no idea where the stock height is since I've messed with it a lot since pulling the spring.
My concern was that the engagement point is always at the top of the pedal no matter where I adjust it to (after removing the spring).
clutch helper spring, helper spring removal
Clutch engagement issue. Possible clutch cylinders upgrade? wu_dot_com Engine, Exhaust, Transmission 42 04-05-2016 12:11 PM
Special Deals on Clutch Masters Clutch & Flywheel Combo! KronosPerformance Transmission and Driveline 15 08-25-2012 12:22 PM
Clutch Masters Clutch and Flywheel Kits for FR-S and BRZ available at Redline360 Redline360 Transmission and Driveline 2 07-30-2012 10:01 AM
Clutch Masters Clutch Kits | Island Import Performance IslandImportPerformance Transmission and Driveline 1 07-20-2012 12:06 PM
