Old 05-25-2014, 07:24 AM   #15
dp1
driving smoother faster
Drives: Sold
Originally Posted by SubieNate View Post
I know lotus refuses to put any kind of LSD into their cars as they believe they interfere with cornering. What's with that?
Some loti have LSD
dp1 is offline   Reply With Quote
The Following User Says Thank You to dp1 For This Useful Post:
CSG Mike (05-25-2014)
Old 05-25-2014, 10:46 AM   #16
DougW
Drives: FR-S stock for now
So now that we all agree a LSD is good thing who makes the best one and at what price?
DougW
DougW is offline   Reply With Quote
Old 05-25-2014, 11:10 AM   #17
DriftEm
DriftEm's Avatar
Hey Mike, how is Quaife ATB Differential different than the stock torsen type?
DriftEm is offline   Reply With Quote
Old 05-25-2014, 12:46 PM   #18
SubieNate
SubieNate's Avatar
Drives: 2013 FR-S Ultramarine
Originally Posted by dp1 View Post
Some loti have LSD
Which?
SubieNate is offline   Reply With Quote
Old 05-25-2014, 01:15 PM   #19
xwd
Lotus added the LSDs at least to US Elises/Exiges later on. They traditionally didn't because the Elise/Exige have a lot of weight in the rear of the car, do not use a rear swaybar, and have a more advanced and well-tuned suspension. The story is they added them for US people autocrossing the Elise because autocrosses have tighter corners. On a track Lotus still says all the LSD will do is make you slower. We aren't driving Lotus cars...
All LSDs add some parasitic loss because the moving assemblies are heavier. Some clutch type LSDs weigh a lot and clutches always add parasitic loss, but it's nothing really in the grand scheme of things.
Quaife and stock Torsen work the same way but different internals to get there. They both multiply torque from the spinning wheel to the wheel that isn't spinning.
I had a 1.5-way Kaaz LSD in the rear of my WRX and 1-way Cusco mechanical LSD in front. It made a huge difference. The Cusco Type-RS is a "Salisbury" type LSD which is mechanical but acts like a clutch type LSD. The Kaaz LSD was super noisy at low speed, but it worked. It probably needed a little less abrupt lockup but I never got around to changing it.
My Jeep Rubicon has "locking" diffs. In 4WD mode with the diffs locked the turning radius is huuuuuuuge. You don't want the wheels turning the same speed all the time.
I'd use an OSG in this car or the Guard Transmission one, but the Guard one is probably at least 2x the cost of the OSG which is already one the higher priced LSDs.
The Following User Says Thank You to xwd For This Useful Post:
Old 05-25-2014, 01:51 PM   #20
CSG Mike
CSG Mike's Avatar
How it works is different, but the end result is the same. It needs resistance on both wheels to work, and once one wheel spins, it's effectively open.
Old 05-25-2014, 01:52 PM   #21
CSG Mike
CSG Mike's Avatar
DougW
The Cusco and OS-Giken units are the most popular choices down here. We carry and configure both.
The Cusco RS is 1520, while the OSG is 1690.
Old 05-25-2014, 11:40 PM   #22
Poodles
Drives: 2015 Series.Blue
It sounds like you had a badly matched LSD for whatever car you drove. A properly matched and tuned LSD will feel exactly how you described a Torsen, but more progressive, and more effective.
As with suspension tuning, you can't just blindly throw on parts, and expect it to improve your car.
Both were factory parts. But the inherent difference between a clutch type and a torsen is that the clutch is "dumb" and will fight any difference in the speeds of the axles while the torsen acts as an open diff until slip happens. Usually why people feel clutch types "push"
Then again, that's only for spring based LSDs (which mine was) and not for ramp styles which is where I would put most performance clutch types into.
As it is, the only weird "bad" LSD I've driven is an old Miata viscous. Then again they're known for being essentially an open diff after 60K miles.
LSD's are a bit subjective and what's best is often opinion (so long as they're actually functioning). Of note, many very high end cars have run torsens (McLaren F1 ran a torsen, GTRs run them, Audi, etc).
Interesting subject
Old 05-26-2014, 07:48 AM   #23
Quentin
Drives: ‘16 4Runner, ‘19 Corolla HB
"- You will not suddenly spin if you suffer loss of traction on just one side of the vehicle"
You should probably clarify that you are talking about spinning a tire... and not the car. Haha
So, what are the downsides of aftermarket LSDs? Cost, required tuning, etc? I've found that it is pretty rare that there is a no compromise choice out there.
Quentin is offline   Reply With Quote
Old 05-26-2014, 10:11 AM   #24
mid_life_crisis
Drives: FR-S 10 #103 AT
Think of the last time you pulled out of a sidestreet where the roads were clean and the turn was sharp. If you had an LSD, one tire probably chirped because they needed to spin at such different speeds and the LSD wouldn't let them. In short, on a really tight turn, an LSD can induce a loss of traction to one tire. This is why for many years only off-roaders and drag racers used them.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 05-26-2014, 10:32 AM   #25
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
Hi Mike
can you add to your original post the real world effects of 1, 1.5 and 2.0 LSD? Like, how do they affect corner/exit approach and inputs.
Old 05-26-2014, 12:24 PM   #26
xwd
Cusco and ATS have some good diagrams and whatnot on 1-way, 1.5-way, and 2-way LSDs. Matt from Guard did a good writeup on either here or NASIOC on what it really means but I can't seem to find it now. They don't use those terms, they consider them made up by the JDM brands as a simplified way to describe the operation.
Aftermarket amp/sub on stock brz limited h/u Wonderbar Electronics | Audio | NAV | Infotainment 2 03-29-2013 10:31 AM
Is the Limited slip differential identifiable? jabbajaw99 Engine, Exhaust, Transmission 10 09-14-2012 07:23 AM
Video: FR-S / BRZ Torsen Limited Slip Differential Explained Hachiroku FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 20 06-29-2012 07:22 PM
Scion's Explanation of BRZ FR-S Limited Slip Differential stalon320 Engine, Exhaust, Transmission 5 06-22-2012 11:26 AM
Video: FR-S / BRZ Torsen Limited Slip Differential Explained Hachiroku BRZ Photos, Videos, Wallpapers, Gallery Forum 1 06-20-2012 04:48 PM
