05-24-2014, 08:37 PM | #99 |
Emperor JDM
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Any update on this bad boy?
05-25-2014, 10:03 AM | #100 |
Drives: Hydra EMS Powered FRS Raven Black
The car is on a break from racing as we test the oil pressure more and work on a dry sump. The oil pressure is inadequate for the power levels we seek and we are working on a solution. For now I'm just driving it as much as I can for R&D sake and it nust did a round trip from DC to Atlanta.
We will be testing a new oil pump but I first need to replace my oil pressure sensor as it appears to be responding erratically. I might have a temporary solution to the dry sump (accusump) but I need that oil pressure to come up some. @puma For our custom valved BC Suspension we run anywhere in the 6-10 kg/mm range for a street application. For custom racing stuff it just depends on how much tire and downforce the person is running. |
05-25-2014, 10:09 AM | #101 |
1337
Drives: 2013 BRZ WRB S/C
It's fantastic to see this car back up and running again. I can only imagine how much work it needed to rebuild it after the fire, awesome job!
05-25-2014, 10:28 AM | #102 | |
Our STi is pushing over 700 whp and I've grenadesd a second 6 speed transmission at Watkins Glen last weekend so I want to put the FRS program back into high gear |
10-21-2014, 10:03 PM | #103 |
Drives: white subaru brz
11-15-2014, 07:50 AM | #104 | |
Drives: 2013 FRS / 2013 427 Vert
Fun watching your early TT3 escapades. I will be at the NARRA Sebring event next weekend running in that category and even with my E85 tune making 205whp it's still way outside the 8.75-10 range for that class. In Jan I plan to make a decision regarding FI, leaning towards a SC for heat management but "Turbo Lust" is a difficult temptation
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor 2016 Audi TTS APR Tuned |
11-15-2014, 09:36 AM | #105 |
Well just go out there and have a great time. NARRA is excellent and the Whelen USTT runs the best tracks of any series!
People have contacted us about engine builds after spinning bottom end bearings in NA form unfortunately. I suggest using 10w30 for racing even if you have an oil cooler. If you're already at the track you can put a hand vacuum transfer pump on the dipstick tube and suck out 2 quarts and then repleace with 20w50 to bring the average viscosity of the 0w20 up. At 1.2 g I don't think you have much to be worried about in terms of "oil starvation" with the FA20. Keep the oil level full after each session and you'll be fine. Many of the tracks I raced at with NARRA the FRS was at a disadvantage because it was so light. That means less HP and at high speed tracks like Watkins Glen, Road Atlanta, and VIR where HP nkt weight rules. Next year they brought back NJ and two rounds at Pittsburgh so I think on these tighter tracks the FRS/BRZ is going to shine. Last edited by Element Tuning; 11-15-2014 at 11:31 AM. |
11-15-2014, 09:38 AM | #106 | |
I sold mine to a friend but they are Skyline rear fender flares from Chaser Aero. The carbon ones I had are around $500 a pair from what I remember. |
11-15-2014, 10:43 AM | #107 |
12-16-2014, 04:42 PM | #108 |
A little update for the Time Attack FRS
Photo by: Liz Weeks After spending many months working on the engine and the oiling system we were finally able to run reliably at 9k RPM. Not without trials and tribulations, one being the failing rocker that some have experienced. You can see the inconsistent manufacturing to secure the axle Internal engine modifications along with a 3 quart oil accumulator, modifying the rocker arms, and the Perrin Oil Cooler now have her running strong. The first test back was a race at Lime Rock Park for the Whelen USTT and Trans Am series championship. Given that this was the first race back with all the internal engine modifications and external to allow for enough oil pressure, I was nervous about the engine. We also had a new wing design to test. The engine however was not something to worry about and was screaming along reliably. Check out the video. Duking it out with the race prepped Vipers and Corvettes however took a toll on the transmission and 4th gear busted. We put up a good fight but had to settle for second place. Also on our problem list was the STi Brembo front brakes with the OEM rear brakes. For whatever reason I just couldn't brake aggressively without the front wheels locking up. Whenever this would happen the ABS system would fault and turn off. With one more gearbox left we knew we needed to make a change for the last race at VIR with NASA. We also knew the brake bias was an issue so we decided to go back to the OEM front rotors and calipers to see if we could restore some balance to the brakes. We needed a slight detune for NASA TT2 due to their tire rule but we knew it wasn't going to be enough to keep the transmission in one piece. We custom fabricated a transmission cooler and pump all in hopes of reduced temperatures keep the gearbox alive. With a nice Perrin shift knob and drift button I was hoping our transmission was going to play nicely! What can I say but our Perrin Oil Cooler, Perrin 3" Exhaust System, Perrin Lightweight Pulleys, along with the Element Tuning Hydra EMS, Pro Comp Engine, Oil Accumulator, and transmission cooler kept the powertrain singing and reliable! Our custom valve BC Racing BR coilovers and Whiteline sway bar allowed for tenacious grip with those huge 325 slicks and we were able to set a new NASA TT2 lap record at VIR turning a 1:58 lap! [ame]http://youtu.be/7hS2dsVVglQ[/ame] Special thanks to Perrin, BC Racing, Whiteline, and Hydra EMS for their support. |
The Following 5 Users Say Thank You to Element Tuning For This Useful Post: | ATL BRZ (12-16-2014), DarkSunrise (12-16-2014), djdnz (12-28-2014), Lawnik (12-26-2014), Pat (12-16-2014) |
12-16-2014, 05:13 PM | #110 |
No Money, No Problems
Granted it's a bit far from stock, but I love seeing that the twins are just as capable a sports car as any other for racing purposes.
12-16-2014, 05:50 PM | #111 |
Thanks. It's not too far removed from stock In all seriousness I try really hard for a few years to keep our cars relatable to the hardcore enthusiasts. Two suspension mods, custom BC coilovers and a Whiteline front sway bar. Lots of bolt on braces and stiffeners, and over pipe and 3" exhaust all from Perrin. As you can see we try to run as many bolt-on from great companies that support these cars. There is $$$$ in the motor but that was a necessity for reliability for this level of racing. The car still has AC!
Hopefully lots of stuff the average enthusiast can model their car after, buy, and install themselves. Next year will bring a new look to the car and some big improvements. |
12-16-2014, 06:13 PM | #112 |
Drives: 2023 BRZ
Why retain the A/C?
Director of Rocky Mountain 86CUP
Similar Threads | ||||
Raven (black) FR-S automatic available at Oakland, CA | TJatOneToyota | Dealer Cars | 5 | 06-08-2012 11:43 AM |
Toyota working on Scion FR-S Playstation-compatible track day black box | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 51 | 06-06-2012 10:47 PM |
Raven (black) FR-S available now at Oakland, CA | TJatOneToyota | Southern California | 2 | 06-02-2012 09:52 PM |
$110 Track day at Willow Springs- Big Track -May5 in SoCal | Louie | Southern California | 3 | 05-04-2012 01:05 AM |
$110 Track day at Willow Springs- Big Track -March24 in SoCal | Louie | Southern California | 1 | 03-10-2012 01:31 AM |
