Old 05-23-2014, 06:21 PM   #1275
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
Also, look ahead to your next corner/apex earlier. Right now, you're fixated onwhat's ahead of you. Look one more step ahead.
Originally Posted by ddeflyer View Post
Looking up is one of those things that takes a really long time to get programmed in.
If developing this habit is a priority, it can help if you slow down. (Kind of obvious, I know.)
dradernh is offline   Reply With Quote
The Following 2 Users Say Thank You to dradernh For This Useful Post:
becauseracecar1 (05-25-2014), CSG Mike (05-23-2014)
Old 05-24-2014, 03:02 AM   #1276
ShoShin
ShoShin's Avatar
Drives: WRB Premium
@becauseracecar1
Your rear came around because you stabbed at the gas pedal (based on what I can hear), with the steering wheel turned. Remember, at your level, your steering wheel dictates how much you can brake and gas.
If you're turning 20%, you can brake or gas 80%. If you're turning 50%, you can brake or gas 50%.
As far as inputs go, keep your hands at the same position on the steering wheel. I see your hands shuffling a lot.
The ride-along you gave from the other day was like 100% crazy regardless of what your steering angle was!!
ShoShin is offline   Reply With Quote
Old 05-24-2014, 03:36 AM   #1277
Simon99
Simon99's Avatar
Drives: 2013 BRZ Limited WRB
I have a quick one. How to you countersteer during a slide without turning the car into a 360 with the nannies off. ..
Originally Posted by VesperLynn
This car has allowed car enthusiasts to come from all different walks of life, car cultures, and brands. Just as a panda is black, white, and Asian; the 86 is Toyota, Subaru, and downright fucking sexy.
Simon99 is offline   Reply With Quote
Old 05-24-2014, 12:29 PM   #1278
ddeflyer
becauseracecar1: Another thing to realize is that "the line" is not the be all and end all of track driving. For a beginner it often becomes a safety blanket that is assumed to keep them on track. Because "the line" seems like a stable, understandable element in a foreign environment, there is a strong tendency to focus on each apex, often to the detriment of other, more important factors. It might feel like hitting your apexes perfectly is the determinant of what a good driver is, or that hitting those apexes might make you a great driver, the envy of all the beginners; it won't.
In reality the line is a placement on track that will be pretty darn good for most cars (assuming they have a good driver) to turn a fast lap time. By realizing that your apexing won't miraculously make you the next Andretti or Senna, you can start to relax about not being perfect. You can start to look up, see what is around you. Those flag stations will be visible much sooner and you will pick up alot more information about what happened in each corner. You will be able to start noticing what happens when you give the car one input vs. another and suddenly the meaning of being smooth will reveal itself much more than anything I, or anyone on this board, can tell you. Being smooth you will see that it is faster to keep a constant lock through a corner and accept being a foot or two off the school line rather than trying to steer onto the optimal path (not to mention you will learn to place the car faster by seeing where it arcs to).
Fun car leads to autocross, autocross leads to track days, track days lead to lemons, lemons leads to racing school, racing school leads to spec Miata...
No idea where it leads next!
ddeflyer is offline   Reply With Quote
The Following User Says Thank You to ddeflyer For This Useful Post:
Old 05-24-2014, 02:48 PM   #1279
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
@becauseracecar1
exactly, one thing to add, you may also want to practice squeezing the gas pedal as you open the steering wheel to gain better exit speed, it's like allocating those inputs/percentages more efficiently (reducing the turning input in other words opening and simultaneously increasing the speed).. it will become a habit after a while..effects of failure to do this even more dramatic with a high horsepower car (such as a V8 sports car) so if you're not really careful or patient with your input, it'll bite your as$
glamcem is offline   Reply With Quote
The Following User Says Thank You to glamcem For This Useful Post:
Old 05-24-2014, 06:43 PM   #1280
dradernh
Off the top of my head:
1) For a rear-wheel only slide, and if there's a significant amount of rear-end step-out, early enough that a tank-slapper doesn't get started because of the amount of countersteer required to catch the initial movement;
2) Very quickly; and,
3) With just the right amount of countersteer.
That will fix the 360 problem; whether it arrests the slide in the manner you wish is something else - sometimes you have to get creative with the controls. For example, it's possible for your car to pick up speed while it's in a major four-wheel slide, even when it's on a level section of track; in that case, and if the slide is going to take you off the track, it may be time for two feet in, or some brake and then throttle...whatever works. Obviously, learning this stuff on a race track is a bit dicey - that's why karting, autocross, rally school, winter car control school, etc. are there.
Old 05-24-2014, 07:49 PM   #1281
ZionsWrath
Thanks
ZionsWrath's Avatar
When you are swapping between track and street pads and have to compress the piston, are you opening the bleed screw? If so are you bleeding the brakes a bit after?
How will I know when rotors need replacement? Do I measure them or will it be obvious through braking feel and/or physical appearance?
Old 05-24-2014, 08:35 PM   #1282
jvincent
jvincent's Avatar
Assuming the street pads are somewhat worn, then you will probably need to compress the pistons. You don't need to open the bleed valve to compress the pistons, although it would make it easier and if you are planning to bleed anyway, then you can for that.
If you are going to track the car it's a good idea to change out the stock fluid anyway so I would plan on a full flush.
Sent from my Nexus 7 using Tapatalk
Old 05-24-2014, 08:38 PM   #1283
ZionsWrath
Thanks
ZionsWrath's Avatar
Yea I already did a full flush with Motul 600, After track day I will put stock pads back for street and since they are somewhat worn I'm sure I'll be able to put the in and press the brake pedal and be fine.
I mean in future when swapping back and forth. Sometimes am going to have to press the piston in to fit pads.
Old 05-24-2014, 09:34 PM   #1284
gramicci101
Off Topic
An easy way to compress pistons in a sliding caliper, like OEM calipers, is to use a bar clamp to compress the caliper and the bracket before you take the caliper off the rotor. The pistons will be pushed straight in because they're being pushed against the rotor, so you don't need to worry about getting them cocked in the bores.
Old 05-24-2014, 10:33 PM   #1285
CSG Mike
CSG Mike's Avatar
WHy are you sliding to begin with? The cause of the slide is, IMO, more important than anything else.
You countersteer by, literally, turning the direction is rotating. If the rear is swinging right, you turn right, and vice versa. Just know when to stop coutnersteering, or you'll snap back the other direction and spin the other way.
Old 05-24-2014, 10:33 PM   #1286
CSG Mike
CSG Mike's Avatar
But, but but... I just stay WOT...
(To the newer guys, don't do this)
becauseracecar1 (05-25-2014), glamcem (05-25-2014)
Old 05-24-2014, 10:35 PM   #1287
CSG Mike
CSG Mike's Avatar
Just push in the pistons by hand. Don't open anything.
If you're tracking with race pads, replace the rotors when the microfractures get big enough to make you notice.
From the CSG FB page:
ZionsWrath (05-25-2014)
Old 05-25-2014, 12:30 AM   #1288
RehabJeff86
RehabJeff86's Avatar
Drives: 2013 WhiteOut FR-S
Originally Posted by becauseracecar1 View Post
I did my first trackday about month ago and it was awesome. My car was 100% stock. Now I'm getting ready for my second track day at Homestead (now with race pads)!!
Thanks to @CSG Mike I have a better idea of how to adjust my tire pressures so I think I'll definitely play around with that.
Here are some videos of my first track day. Any advice on how to improve my driving there?
Thank you!!
Also a big thanks to everyone that responds to all the questions in this thread, it's a huge help and very much appreciated!!
Fast Lap:
In Car video @ about 4:20 you can see me lose the car a little
Sorry a lil off topic, i use RaceRender for track video, wonder wut r u using cuz i really like the turn number and cornering speed on ur track vid!
2013 Scion FR-S whiteout
2012 Porsche Panamera S carbon grey
2008 Range Rover Sport SS black - sold
2004 BMW M3 alpine wies - sold
RehabJeff86 is offline   Reply With Quote
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
