Old 05-21-2014, 04:20 PM   #71
billwot
Drives: '11 Cayman , '14 Camry, '11 Tacoma
Originally Posted by ft_sjo View Post
First google result: http://cochise.uia.net/pkelley2/DynamicCR.html
I'm not qualified to comment, it's a very complex subject and none of us will have the source data required to calculate it.
Actually, its very simple.
Final Compression Ratio (FCR) = (Boost / 14.7) + 1) x CR
Boost = Maximum Boost
14.7 = Psi. at Sea Level
CR = Engine Static Compression Ratio
http://www.xcceleration.com/cr-boost%20101.htm
And here's a calculator to make it even more simple:
http://www.gtsparkplugs.com/Effectiv...ssionCalc.html
billwot is offline   Reply With Quote
Old 05-24-2014, 03:31 AM   #72
350matt
Drives: toyota mr2/ Toyota GT86
so you guys are all on stock internals? all at 12.5:1 CR?
are you restricting the boost below 5000 rpm to avoid breaking rods?
350matt is offline   Reply With Quote
Old 05-24-2014, 04:47 AM   #73
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
380ft pounds below 5000 on stock internals.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Old 01-29-2015, 05:31 PM   #74
Mikeez
Engineering Student
Drives: Scion FR-S 2015
So is it better to have a lower compression ratio?
12.5:1 (Stock Engine FRS) with 7PSI boost yields a 18:1 ECR (effective)
Is that good for pump gas
There’s no time to stop for gas, we’re already late
Mikeez is offline   Reply With Quote
Old 01-30-2015, 05:32 PM   #75
Reaper
Reaper's Avatar
Drives: violent
I'm stock compression ratio and make 450+whp. Another local frs is 9.5:1 and can only make 350whp. My old tuners car is 13:1 and makes more power than me on e85. I've also seen stock compression cars make more whp on pump gas than my local buddy's low compression motor by a long shot. Don't go below 11:1 or you will lose power.
The Following User Says Thank You to Reaper For This Useful Post:
ATL BRZ (01-30-2015)
Using Subarus other turbo Boxers as an idea, how much HP could a turbo BRZ/FR-S have? HitTheGas BRZ First-Gen (2012+) — General Topics 12 02-21-2012 02:24 PM
Turbo FR-S Mino Engine, Exhaust, Transmission 24 12-16-2011 09:42 AM
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? fred_boosted Engine, Exhaust, Transmission 215 12-12-2011 08:23 PM
turbo yes BMWDAD BRZ First-Gen (2012+) — General Topics 79 12-06-2011 01:58 AM
Geneva Preview: Techart to debut 911 Turbo, Turbo S vh_supra26 Other Vehicles & General Automotive Discussions 1 02-22-2010 07:20 PM
