Old 05-11-2014, 04:02 AM   #99
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
Here's the link: https://www.dropbox.com/sh/eueghzbz9...KMUoVPXMs_pDga
Td-d is offline   Reply With Quote
The Following User Says Thank You to Td-d For This Useful Post:
steve99 (05-17-2014)
Old 05-11-2014, 04:04 AM   #100
steve99
Drives: FT86
Originally Posted by Td-d View Post
Steve, I've got all the roms - want me to Dropbox them to you?
Sent from my iPad using Tapatalk HD
Mate that would be great thanks probably just the latest revision of each
Old 05-11-2014, 11:40 AM   #101
dsgerbc
Drives: BRZ(sold), STI
So I was looking at OEM transient ignition retard tables in RomRaider and Ecuflash. Those looked normal in RR and off by about 20 in Ecuflash with 32BITBASE file I got from OP. So it would seem like the offset is off by that 20 in the base.
Old 05-11-2014, 11:55 AM   #102
Td-d
The link in the OP is to the wrong (standard) 32bitbase. This is the one that needs to be used:
https://raw.githubusercontent.com/TD.../32BITBASE.xml
Old 05-11-2014, 12:11 PM   #103
dsgerbc
Ok, this one has proper scaling reference, thanks.
Old 05-11-2014, 07:55 PM   #104
steve99
Drives: FT86
fixed link in OP thanks
Td-d (05-12-2014)
Old 05-18-2014, 09:53 AM   #105
steve99
Drives: FT86
added latest roms from each series to original post thanks
Old 05-23-2014, 12:31 PM   #106
Td-d
Can someone test this out for me for A01C, fuel system status:
FFF8DC0F
8 bit value
For A01G it's FFF8D2E3
Old 05-23-2014, 05:09 PM   #107
steve99
Drives: FT86
FFF8DC0F
8 bit value
On A01G rom I have been using
FFF8D2E2
8 BIT
NO SCALING
it been returning fuel system status for ol cl fine
do you want me to test FFF8D2E3 ??
Old 05-23-2014, 08:18 PM   #108
steve99
Drives: FT86
Originally Posted by vgi View Post
Try it and we'll see. Maybe it's PI/DI status?
Can you also tell me your scaling for MRP and min/max vals you get?
no problem will try it and log result
maybe my brains off today whats MRP ?
the logcfg.txt file im usng is attached to first post
Old 05-23-2014, 10:21 PM   #109
steve99
Drives: FT86
FFF8DC0F
8 bit value
@Td-d tried FFF8D2E3 on G rom always logged "0"
FFF8D2E2 appears to be correct address for suel system status ol/cl ect.
see attached files :-)
Old 05-23-2014, 10:24 PM   #110
steve99
Drives: FT86
sorry, manifold relative pressure
best I have is MAP manifold absolure pressure for G rom
;paramname = MAP
;paramid = 0xFFF87C60
;isfloat = 1
;scalingrpn = x,0.133322368,*
Old 05-24-2014, 03:42 AM   #111
Td-d
Exactly. Dale's put you ether a useful script for naming he ODB routines - there are two parameters that are in that routine, want to check if the other is Di/pi
Old 05-24-2014, 03:44 AM   #112
Td-d
Thanks, oh well...
ecuflash, tactrix, taxtrix, tuning
ECUFlash - Getting close! xjohnx Software Tuning 698 03-22-2015 12:10 PM
EcuTek Flash finished but now it shows only a Partial Flash... Cross Software Tuning 32 02-12-2014 10:55 AM
Tactrix Openport jamesm Engine, Exhaust, Bolt-Ons 1 01-28-2014 08:27 PM
Visconti Tuning - Latest BRZ Flash Info Visconti Software Tuning 6530 12-24-2013 10:18 PM
Overboost Protection With OFT/EcuFlash? FrX Software Tuning 9 10-23-2013 07:27 AM
