Old 05-19-2014, 03:05 PM   #491
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
Nice to know..saves a good chunk of change.
Yes, the 500lb/9k sound stiff. Do you offer 450lb/8k too? If yes, extra charge? I think 8k square would interest a lot of people.
I may have to just save up for T2's... buy right buy once.. right? lol
fooddude is offline   Reply With Quote
Old 05-20-2014, 02:12 AM   #492
fooddude
Is it me, or do these look like Takumi's coilovers?
The Following User Says Thank You to fooddude For This Useful Post:
Racecomp Engineering (05-20-2014)
Old 05-20-2014, 04:09 AM   #493
OjiGeorge
OjiGeorge's Avatar
Drives: White 2013 FRS
After tracking the car, and doing autox, I can confidently say the T2's are really great. My tires not so much. Need much better tires now to keep up with the awesomeness.
Get bushings as well people, you won't regret!
...And square. Learned that the hard way.
OjiGeorge is offline   Reply With Quote
The Following 2 Users Say Thank You to OjiGeorge For This Useful Post:
fooddude (05-20-2014), Racecomp Engineering (05-20-2014)
Old 05-20-2014, 11:27 AM   #494
450 lbs/in would be extra.
Honestly....the standard 7k springs are awesome for most people. Super sticky r-comps, maybe go firmer but you may not need to.
- Andy
Old 05-20-2014, 11:27 AM   #495
Old 05-23-2014, 12:45 PM   #496
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Ordered a set of T2's yesterday!
What sway bar endlinks are you guys going with? I assume the stock ones will be too long with a modest ~30mm drop, right? I am also running RCE hollow sways front and rear.
I need to grab some conical washers. Are those best sourced from the dealership?
Old 05-23-2014, 02:16 PM   #497
Conical washers are easily sourced from the dealer. Holla at us if they don't have them.
We went with Whiteline IIRC for our endlinks.
- Andy
ATL BRZ (05-23-2014)
Old 05-23-2014, 02:40 PM   #498
TrogDor the Burninator
TrogDor the Burninator's Avatar
Drives: 2013 Hot Lava FR-S 6 MT
Honestly, I know they are 500 bones ... but forget the conical washers and by the Raceseng CasCam plates ...
Night and day difference ...
2013 Scion FR-S Hot Lava 6MT Current Mods: KW V3 Coilovers - Raceseng CasCam Plates - Volk TE37SL Black Edition 18x9 +45 - Dunlop Direzza ZIIs 255/35 - Tomei Expreme Ti 60S - FT86 SpeedFactory UEL Catted Header
TrogDor the Burninator is offline   Reply With Quote
The Following User Says Thank You to TrogDor the Burninator For This Useful Post:
Old 05-23-2014, 04:33 PM   #499
ATL BRZ
ATL BRZ's Avatar
Do it once, do it right, right?
I thought about it some more and I know I'd want the CasCam's eventually anyways so I just bit the bullet on those too....and the rear shock tops....and whiteline front and rear end links. I'm feeling nauseous. Hope it's all worth it!
The Following 2 Users Say Thank You to ATL BRZ For This Useful Post:
fooddude (05-23-2014), TrogDor the Burninator (05-23-2014)
Old 05-23-2014, 05:01 PM   #500
fooddude
Sounds exciting!
Which rear shock tops? Do aftermarket rear shock tops work with the RCE coilovers without any additional washers/plates/perches?
Old 05-23-2014, 05:03 PM   #501
ATL BRZ
ATL BRZ's Avatar
Sounds exciting!
http://ft86speedfactory.com/raceseng...-top-1294.html
The Following User Says Thank You to ATL BRZ For This Useful Post:
Old 05-23-2014, 05:05 PM   #502
fooddude
Here's another good Q:
How much does RCE charge for the typical 36k/3year maintenance rebuild of T2 & T0? ...just the standard rebuild/refresh with new oil, seals, o-rings, etc. (not a special/custom revalve)
Old 05-23-2014, 05:19 PM   #503
FastWhite
Drives: Subaru BRZ Limited M/T
I had a set rebuilt, T2's for an STI. It cost me $160/damper plus shipping. This was a year ago.
Remember that prices do change.
This was also thru RCE. They provide you with the work order number and you then send it to KW in California for the rebuild
FastWhite is offline   Reply With Quote
The Following User Says Thank You to FastWhite For This Useful Post:
Old 05-24-2014, 02:28 AM   #504
enivid
enivid's Avatar
Drives: WRB JR BRZED
Tarmac II Settings in case some one needs this.
http://racecompengineering.com/instr...ingsbrzfrs.pdf
enivid is offline   Reply With Quote
Racecomp Tarmac II Clubsport coilover JoeBoxer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 47 11-17-2013 12:02 AM
Tarmac Zero Coilovers Specs? tintumz22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 06-14-2013 12:26 AM
KW CLUBSPORT COILOVERS W/ FREE SHIPPING FOR THE SCION FR-S/SUBARU BRZ!!! NJA Brakes, Suspension, Chassis 7 03-30-2013 09:26 PM
Wheel Directory: Enkei ES-Tarmac 16x7.0 +45 quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 09-12-2012 01:24 PM
Toyota 86 Tears Up Tarmac at 2012 TAS (TRD, N1, HKS, Up Garage Models) + LFA Roadster knoxviue FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 35 01-20-2012 02:44 AM
